Solar Powered Electric Car
89,181
307
99
After converting 1995 Aspire to electric vehicle ,I decided to go 1 step further. I installed 6 solar panels on garage roof , with batteries and inverter in garage. Car charges during the day and I drive it on after work missions. Works great driving around town (usually only 5-10 mile trips) will go 55 mph. If it is cloudy a few hours charging continues due to batteries in garage.
Step 1: Remove Engine
First step is removal of engine and components, radiator , tailpipe , muffler ,etc
Step 2: Build Racks for Batteries
Using angle and square tubing to build battery racks. Rack at rear and front 3 batteries are suspended between frame members. Five batteries under hood , four in rear. Rear batteries are sealed in plastic container with fan exhausting under vehicle during charging.
Step 3: Install Electric Motor
Mount motor to adapter plate with shaft coupler. Bolt unit to transaxle and either run motor slow (connected to small battery) or turn front wheel , checking for alignment. I also braced motor with angles ,as engine was attached to motor mount originally.
Step 4: Main Wiring
Wiring is next after installing batteries , speed controller , throttle Box ,and contactor . Welding cable is used to connect batteries in series and from contactor to speed controller to motor. Throttle box is connected to cable from gas pedal and wired to speed controller. Ignition switch controls main contactor.
Step 5: More Wiring
Converter to change 72volts to 12volts (to run headlights etc) is mounted and wired to 12 volt car battery. I mounted 12volt vacuum pump (for brakes) in gas tank because it is noisy. 120 volt Battery charger is connected to main battery bank, and mounted in back of car. Volt and ammeter mounted and wired.
Step 6: Solar Panel Setup
Build mounts for solar panels from 1/2" conduit and 2 by 4. Wire 6 panels together inside fused electrical box. Run large gauge wire from box into garage.
Step 7: Garage Set Up
Power from panels flows thru charge controller (keeps batteries from overcharging) to eight 6 volt golf cart batteries . On a clear day 30 amps is available from panels. A 1000 watt inverter is connected to battery bank with large gauge wire. Cars 120 volt charger is connected to inverter.
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    99 Discussions
    SomashekarR
    9 months ago
    how to connect solar panels to mppt to batteries to controler to motor
    can anyone help
    SomashekarR
    Question 9 months ago
    can anyone help
    hkedia1
    2 years ago
    Hi. Thank you for sharing it. I have a question though.
    Why didn't you remove the transmission as well thereby reducing some more weight and increasing the efficiency a bit more? I mean, we all know that electric motors have much more precise control over torque. Do you actually need gears?
    daenergymon
    3 years ago on Introduction
    this makes me miss my 86 Subaru that was converted. It finally was too difficult to continue to repair (rusted out).
    davelayde
    5 years ago
    How did you get your hands on a motor like that, I've been looking for a long time but never found anything
    mikes4222davelayde
    Reply 4 years ago on Introduction
    You could use a golf-cart motor, or possibly a starter motor from a pickup truck or other large vehicle.
    How do you get it passed state inspection? When you convert the car, do you need license plate and automobile insurance?
    jjaan
    5 years ago on Introduction
    kindly mail me in brief means which motor shall i used and list of components which i can buy here in pakistan to manufacture these and explore more about it knidly mail me?
    ritesh jainjjaan
    Reply 4 years ago
    I want to make a car..solar based...
    plz mail details about its components ..design..and all other things...plzzzz. ..
    acunliffe1
    Great instructable. You could have a hydroelectric generator going 24/7 to power it. 12 motors acting as water wheels then use a DC to DC boosting circuit to get them to 10V each. 10 x 12 = 120V. You could then charge the batteries. 24/7 power and you wouldn't need as any batteries because it would run continuously therefore you wouldn't need as much voltage or motors. Let me know what you think of it, if there are any flaws and any ways to improve it. Thanks.
    ANDY!
    What's your optimal RPM for your motor? I have a differential with a 1:3.5 ratio that I'm considering mounting a motor on, but not sure if I should hook it up with a transmission in between.
    bhvm
    5 years ago
    a job well done! a true, pure home made Electric car. why don't you use one of the batteries 12v for headlights rather than 72v to 12v converter? also please think about putting Solar panels on roof and hood. those 100w something may improve driveability of the car!
    Da Falls Guy
    5 years ago
    Frankly.. I think this is a great project. Might change the batteries, voltage & motor a little.. But all else for me is on project ! I'm building a high horsepower for drag racing. Hoping to have a car that will certainly turn some heads and not thinking they have a category for electric cars yet t soul .
    please can i hav the complete explanation for this electric car this is my email (georgekaycares@gmail.com)
    You could try putting vents at the top of the bonnet (Windsheild end) to help the air flow freely through and reduce drag.
    I don't know if it will work but could be worth trying :)
    Planecrazy361
    10 years ago on Step 7
    Where in IL are you? I'm in Buffalo Grove, and would love to see the car someday if you're not too far away! Regards, Steve
    speedy4442001Planecrazy361
    Reply 7 years ago on Step 7
    Yes, I too am in IL and wondering how far away from you I am. Also wondering if you do conversions for other, mechanically challenged people? And you total costs? I am very impressed!! Good job!
    misterwelder
    Awesome job. I've been wanting to go electric with and old beetle for a while now. I hope to have the success that you have.
