Solder Fume Extractor
10,350
278
20
About: I am an electronics engineer, doing a PhD at the VUB in Belgium. I have a passion for making things, both useful and cool.
Soldering is one of the key activities in electronics, but are you soldering safely?
The fumes released by the solder are not healthyat all; therefore, one should always solder in a well ventilated area, or even better, while using a fume extractor. However, commercial fume extractors can be quite expensive. It's basically a fan that pulls the fumes through a carbon filter, so why not make our own?
It's a very simple and cheap build, and something that everyone should own. To make it even easier to use, we'll power it via USB. That means it could also be powered by a USB battery bank. Let's build it!
Supplies:
Step 1: Parts List
  • Computer fan
  • Fan grill x2
  • Box/case (size depending on fan diameter)
  • M4 screws & nuts OR M5 screws
  • Active carbon filter (for aquariums)
  • USB cable or 12V power adapter
  • Boost converter (only when using USB)
The fan & fan grills can easily be taken from an old PC. The carbon filter can be found at a pet supply center or simply online. The boost converter can be bought on ebay, amazon, or even aliexpress; it steps up 5V to 12V.
The case I used is a simple hard plastic container, but it was of the perfect size.
Total cost < €10
Step 2: Prepare the Case & Fan
Now onto building the fume extractor; we'll start by making the necessary modifications to the case.
Start by putting the fan grill on the lid of the box, and trace around it. Also mark where the holes need to be drilled.
Cut out the shape with a rotary tool (Dremel) or an X-acto knife and drill the 4 holes.
When that's done, draw a circle on the bottom of the container (the size of your fan) and cut it out.
Furthermore, drill a hole in the corner of the box, and feed the USB/power cable through. Also, tie a nut in the wire.
If you have a tap & die set, we need to make a little modification to the fan. Take an M5 tap, and tap the holes that are already present on the fan. Now the M5 screws can easily thread in the fan, and no nuts are needed. You could also try using the screws themselves to make the threads. Otherwise, use M4 screws and nuts.
Now, we'll solder the boost converter to the fan. Make sure the USB/power wire is fed through the case and solder the red and black USB wires to the 'IN' markings. Attach a multimeter to the 'OUT' pins, and turn the potentiometer (on the boost converter) until you get 12V. When you're sure the boost converter outputs 12V, solder the red and black fan wires from the fan to the 'OUT' markings. I glued the USB wire in place, because the wires were very fragile. If desired, a switch could be added. At this point, it's a good idea to test the fan.
For a nice explanation on how boost converters work, take a look here.
Step 3: Assembly
The final step is the assembly, which is quite straightforward.
Start by pushing the screws through the lid of the container. Next, add one fan grill, the carbon filter, and the other fan grill. Now, thread the screws into the fan, or secure with nuts.
The carbon filter should be thin enough, so the airflow is not too weak. Mine was about 3 cm thick, so I cut it in half with a knife. This is the part that adsorbs the fumes and should sometimes be replaced.
Finally, the case can be closed. When using a metal box, the boost converter should be isolated with a bit of tape. Otherwise, just push it in the case.
Plug in the USB cable, and the fan should start spinning. When soldering, the fumes will be dragged into the carbon filter and adsorbed, keeping the air fresh and clean!
Happy soldering!
Safety Challenge
Runner Up in the
Safety Challenge
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    20 Discussions
    sspence
    3 years ago on Introduction
    Where does it extract them too? If it's just moving them around, it's not very effective. Needs a vent.
    sspencesspence
    Reply 3 years ago on Introduction
    a HEPA filter is designed to better filter particles (i.e. smoke, fume), while activated carbon is designed to better filter odors (i.e. volatile organic compounds, smelly chemicals).
    ThomasVDDsspence
    I'm certainly no specialist on the subject, but I've found that activated carbon should also work. Many commercially available products contain these. A HEPA could be even better, but I don't doubt the effectiveness of the carbon.
    sspenceThomasVDD
    You should doubt carbon. Science says it's ineffective. Commercial units that use carbon filter alone are scams. Her's some more info - http://sentryair.com/blog/solder-fume-control/comparing-solder-fume-extractors-its-all-about-the-filter/
    StephanoHsspence
    Reply 1 year ago
    You're able to buy a professional extractor if that makes you feel better. There's also lead-free solder.
    ThomasVDDsspence
    That source is quite biased, as it really promotes its own products. But you may be right that carbon filters are not the most efficiënt ones. Either way, the fumes get extracted, away from your face, and get filtered to a certain degree. On top of that, my workspace is already quite well ventilated; so I think it should be sufficient.
    ThomasVDDsspence
    Carbon filters work with a substance called 'activated carbon'. It adsorbes (not absorbs) the particles in the fumes. For a detailed explanation I'll refer you to wikipedia ;)
    sspenceThomasVDD
    Activated carbon removes odors , not lead and flux particles (90% of solder smoke is particulates). This is not helpful to a solderer. I already understand detailed explanations,that why I asked the question. You need a HEPA filter if you are recirculating, or just an outdoor vent with no filtering.
    RobertC2sspence
    Reply 1 year ago
    You are being overly alarmist.
    Lead does NOT vaporize at those temperatures. Therefore there is ZERO lead in the fumes. They are ALL from the flux.Still harmful but no lead. As long as the fumes are forcefully directed away from the face, his setup is perfectly fine for hobbyists in reasonably ventilated rooms.
    wgg
    2 years ago
    I couldn't find the usb step up converter on amazon can you provide a link please?
    ThomasVDDwgg
    Reply 2 years ago
    Search for "boost converter"
    Yonatan24
    3 years ago
    Looks like a really easy project, Since I've made a solder fume extractor soldering has turned out to be a lot funner, Now I'm working on an upgrade for my old one!
    rbli63
    I have a contraption for the same purpose made from an old lamp arm, some water pipe and a fan, but I never thought of the carbon filter. So good on you!
    Now that you mention it, I wonder if a different filter material, e.g. used in paint masks, would be even better. After all, soldering, especially with the old leaded solder that many hobbyists still use, also releases lead fumes. In small doses (hobby work), it'd be harmless, but still.. Any thoughts?
    ThomasVDDrbli63
    Thanks man :) I like the carbon filter, because it's not too dense. Other (denser) materials could certainly work, but the fan should be more powerful then. Let me know if you try it out ;)
    Treker2
    3 years ago
    Stupid mobile app
    Treker2
    3 years ago
    Whoops
