Solder LED Fume Extractor
10,196
205
9
Hello,
I made this fume extractor because I didn't want to inhale the toxic fume's that are released when soldering.
I had made a fume extractor al long while ago, but the platform that it was standing on wasn't reliable and would fall a lot. The platform that this one is standing on is very stable.
I hope you will also make some kind of fume extractor yourselves!!
things you need:
-old lamp
-2x Led strip's
-3,6k ohm resistor
-some wire
-switch
-active carbon pond filter
-hot glue gun
-electrical tape
-computer fan
Step 1: Lamp
Choose an old bending lamp, the ones that you can attach to an table.
Step 2: Lamp
I was lucky, my lamp has these cut's or shafts on the back, that is convenient because the air can flow out again.
Step 3: Switch
Step 4: LED
I was very happy about these led strips, they give a lot of light.
(if you are using led strips you need to be careful that you don't burn them!)
Step 5: Activated Carbon
place the carbon against the inside of the lamp, so it seals the inside wall.
This helps to filter the fumes out, I bought this one at my local pet store.
they are originally used to filter water in an aquarium.
(sorry bad photo, but it's behind the fan.)
Step 6: The Circuit
I'm not an electrician so I tried to draw the circuit as simple as possible,but I think you get the idea :)
I used 9v but you can use less power.
I used a 3,6k ohm resistor, this way I had enough light and enough fan speed.
My lights didn't burn out, but do this project at your own risk.
-the negative wire of the power supply goes to the negative wire of the fan and negative side of the LED.
-the positive wire goes to the switch and leaves the switch, then one wire connects to the positive wire of the fan and one to the 3,6k ohm resistor then it leaves the resistor to the positive side on the LED.
Step 7: Putting It Together
1) Run the wires trough the hole of the lamp,secure the switch with tape.
2) Make the solder connections.
3) Cut the carbon slightly larger than the round of the lamp, and push it in.
4) put hot glue around the edge of the lamp and quickly push the fan against it, and let it cool.
MAKE Sure YOU KNOW WICH WAY THE FAN SUCKS THE AIR IN.
Step 8: Voil√°
hope you enjoyed this project, and solder safer now.
*i'm new to instrucktables, so a few tips could come in handy ;)*
  • Classroom Science Contest
  • Fandom Contest
    Fandom Contest
  • Arduino Contest 2019
9 Discussions
IamGutter
3 years ago
Light goes in ..... Smoke goes out. Perfect!!! This is on my list. Thanks.
lyzux
3 years ago
I actuallly made one a while ago and i took two 3d models from thingiverse to put it together, that thing is super effective and the active carbon filter on the front is catching all the scents from soldering, i can only recommend making one.
Nobilis
3 years ago
Useful and nice!
I like the flexible basement and the interior LED lights are a big bonus!
Until now I just used a PC fan to blow away fumes, but I do want to build this little tool!
Thanks for sharing the idea!
(I recognised that your lamp is from Ikea.)
lor123Nobilis
Reply 3 years ago
haha, it was a real struggle to get the lamp electronics out of it's housing.
unplug the power cord.
1. poke the plastic thing out of the 'lamp hole'
2. twist the head of the lamp, so it comes of the neck.
3.pull the wire trough it's neck, so you have more room to work with.
4.get the light bulb out of the head of the lamp.
5.the head has on two sides, some kind of clips that hold it in place.
6.use something flat to get between the clip and the housing.(so the flat object is now between 2 plastic pieces)
7.press the two flat object's to the outside, and gently pull out the plastic middle that originally would hold the light bulb.
8. now you can deconnect the wires of the lamp.
don't do this if you have the power cord plugged in.
<the square on the black plastic housing is where the clips would go>
anilbot
3 years ago
Very useful 'ible....
Thanks for sharing...
seamster
3 years ago
Very nicely done! This is a good looking little extractor, and a very good first instructable. Keep it up! :)
