Solder USB Power Cable to Raspberry Pi
65,645
320
19
Micro USB plugs are rare in my household, but a bunch of USB cables have been lying around. So maybe it is possible to solder a USB cable directly to the Raspberry PI? Yes it is, Paul Bealing describes it very well here: http://www2.pmb.co.nz/blog/?p=1767.
Step 1: Cut the USB Cable, Remove the Data Lines
We just need the red and black power wires from the USB cable. Remove about 5cm of isolation and cut the white and green data wires.
Step 2: Wrap the Strain-relief
To avoid the wires to be torn away, the cable is wrapped once around the video out. Please keep the orientation as shown in the image to avoid unwrapping. Then plunge the two wires through the hole in the middle of the board.
Step 3: Solder the Supply
Finally solder the wires to the board. Red (+5V / Vcc) is connected to the polyfuse F3 and black (0V / Gnd) to the protection diode D17. - Enjoy.
    • Weaving Challenge
      Weaving Challenge
    • Remix Contest
      Remix Contest
    • Epilog X Contest
      Epilog X Contest
    19 Discussions
    Actually, that's exactly the reason why you want to use pin 2/4 and 6/9, when you want to make something much heftier/secure than the polyfuse, especially when higher voltages are involved like in automotive applications (you really want serious filters there) or when you need stronger (but related) power sources (the 2.5" hard disk or your Arduino/Servos kinda need to be on the same GND, but powering from the USB or the GPIO (suicidal option) is going to leave your RPi dry...)
    hillary3
    2 years ago
    works fine, i used same model in this guide.
    Victor805
    2 years ago
    Thanks, it worked with my Raspberry model B
    Hoagie
    4 years ago on Introduction
    You can also feed power into the GPIO with 5V on Pin 4 and Gnd on Pin 6, but BEWARE, it bypasses the input fuse. It does avoid soldering to the Pi though.
    msmiley2
    4 years ago
    no micro USB cable available but lightening, everything is possible in DIY oO
    app0msmiley2
    Reply 4 years ago on Introduction
    Yeah, especially looking at the prices of these lightning cables, lol.
    Offtopic: woah, i still have that Shana userpic here.
    Obi-Wahn
    And if you solder a Mini-B-USB-Plug onto the PI, you just need to connect that cable then to the PI and there you have it: infinite powered PI
    xD
    LeeG
    4 years ago
    Probably of more use for compact model a projects than for the model b.
    jbrown120
    4 years ago
    Awesome for saving space
