Solid Wooden Sunglasses
46,787
955
31
About: Hi, I'm Alex Harris, Engineering student and "YouTube woodworker". For more about me, visit my website: http://thiswoodwork.com/
Mid last year I made these sunglasses and I thought I would share them here. Check out the video above to see how I made them! Thanks to my beautiful baby sister for kindly modelling these! It's much better than seeing them on me.
Supplies:
Step 1: The Lenses
First up, we'll need some lenses. I ripped some out a plastic pair of sunglasses I got free!
Step 2: The Templates
Using the original sunglasses I produced some 1:1 cutting templates. If you are using similar sized lenses you can download the ones I used from my website: http://thiswoodwork.com/making-wooden-sunglasses-summer-woodworking-project/
Step 3: Attaching the Templates
Next, the templates are stuck to the rough blank with a little wood glue.
Step 4: Cutting Out the Frames
Using the scrollsaw the frames are cut roughly to shape, If you don't have a scrollsaw you can do this by hand, it's just going to take a while!
Step 5: Cutting the Frames 2
To cut the opening for the lenses drill through the blank and thread through the blade. Leave the cavity slightly over-sized at this point.
Step 6: Cutting the Temples
The temples (or arms) are cut out in the same way.
Step 7: Fitting the Lenses
Align each lens properly and trace around them with a pencil. Sand close to the marked line, leaving a small rim just under 1mm (IMPORTANT) I used a drum sanding attachment at the drill press to do this.
Step 8: Shaping
The final shape cannot be achieved on the scrollsaw, so using a small handsaw cut away the remaining material and use a hand-file to shape. The original sunglasses serve as a good reference when doing this.
Step 9: Shaping 2
Using sanding attachments, sand to the final shape. (If you don't have these some careful filing and sandpaper should work.)
Step 10: Fitting the Lenses 2
Now to cut the rim for the lenses. Using a rotary cutting disk mounted in the drill press for ease, I cut a shallow groove around the edge of the lens cavity, for the lens to slot in to. This will take some care and a bit of trial and error, but should work if you are careful.
Step 11: The Hinges
Next is the hinges. I could have made some tiny wooden hinges, but it was far easier to cut them off of an old pair of cheap plastic ones!
Step 12: Fitting the Hinges
To attach the hinges mark the position and cut a small cavity on both the front and temples of the glasses. (I used a small drill bit to do this.)
Step 13: Gluing the Hinges
The hinges were glued into the cavities with some quick-set epoxy.
Step 14: Applying the Finish
Finally a finish can be applied to the glasses, before the lenses are pressed into place. For a finish I used mineral oil just to be safe, but I am sure that some spray lacquer would be fine too!
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    31 Discussions
    farraha
    3 years ago
    Great
    jrow00
    3 years ago on Introduction
    what kind of wood did you use and where do you recommend we get it?
    Marker1024
    4 years ago on Introduction
    Well done! You should treat yourself and those frames to a nice pare of polarized lenses! Its a disgrace to use the cheep ones in when you've crafted the rest of the sunglass so nicely! Great cheep project though.
    BenMercierMarker1024
    Reply 3 years ago
    Do you know where to buy the polarized lenses for this style of glasses? I can't find any for under $30
    buck2217
    They are great but knowing me I would either leave them in the pub or sit on them -- cue heart broken!!
    kdorais
    Definitely gonna try to make these this summer, but with actual lenses since I have terrible vision :P These are so cool!
    sabladask
    4 years ago
    You glasses looks grate:) i like that they are crafted by hand ( no cnc).
    mjackson-1Spokehedz
    Reply 4 years ago on Introduction
    Just don't forget that prescription lenses factor in pupilary distance and have a focal point... there's a lot more precision required than for non-corrective lenses.
    Wow they look awesome! You've got some nice skills! You make the sunglasses yourself while others buy them for a lot of mony at a (desing) shop!!
    keep your work up - i'm looking forward to seeing new projects
    acaig
    4 years ago
    That takes proper skills nothing I could do they look lovely I imagine you could sell a few of those
    I was always annoyed at school the boys got to do woodwork and girls had to do home economics it was so unfair from a very early age I used to stare longingly in to the workshop classrooms and my brothers told me id do them for at 11 lying watsits
    Dandie
    This is great, admirable.Very nice work, congratulations!!
    kodiwoedee
    4 years ago
    Awesome! People love hand made items. Do u sell any on Etsy?
    CK101
    4 years ago
    How do you attach the lens at the end
    ThisWoodworkCK101
    Apologies, looks like I missed that! They are just pressed into the rim cut on the inside edge of the frame. It is easy to see what happens in the video.
