Sound Lamp
15,449
171
10
About: MTTR MGMT is an award-winning design practice that ranges widely in discipline, methodology and media. MTTR MGMT’s focus lies on the investigation, representation and innovation of prototypes for the fringe ...
During my residency I am developing an omni-directional loud speaker that can both play given sounds, as well as generate its own soundscape. This instructable is to document the scale model development for this project.
Step 1: Design of the Sound Lamp
The basics of the initial design were born out of an installation we produced in Los Angeles in 2014. To further this exploration, the sound lamp was developed into a more precise project that would take advantage of the tools available at Pier 9, specifically the DMS 5 axis router. To build the scale model, however, several technologies needed to be used in order achieve a reliable and accurate result quickly.
Step 2: Prototype Production
The initial scale model, or prototype, was 3d printed in multiple parts and then assembled. Using tight tolerances and a very limited amount of Tacky glue, the entire object was printed and assembled in under 24 hours.
Step 3: Prototype Base and Cover
Instead of having this prototype simply float in space, I put together a base and enclosure that would ground the piece while also protecting it. The base is made out of solid walnut that is milled on the DMS, and the cover is a simple glass cloche that I purchased off amazon.
Step 4: Milling the Base - Test
Before dedicating the toolpath to the walnut, I first tested it on a block of foam to ensure that no problems would be encountered. This was imperative, as I had to run the job several times to work out kinks in the toolpaths that would have ruined the walnut.
Step 5: Milling the Base - Final
Once all toolpaths were proven, the final pass was made on the walnut using full 3+2 functionality.
Step 6: Prototype - Final
Once all pieces were finalized and finished, the prototype was assembled into its final form.
Step 7: Final Thoughts
Initially, the purpose of this prototype was to suss out any formal issues with the complex geometry. What happened in addition was an opportunity to learn and develop the skills necessary to operate the same equipment that I will be using to produce the larger final object. It was a fantastic experience and the DMS is an amazing machine.
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    10 Discussions
    At the start of this post, "During my residency I am developing an omni-directional loud speaker that can both play given sounds, as well as generate its own soundscape. This instructable is to document the scale model development for this project."
    darcydh
    4 years ago
    good going.
    tony17837
    4 years ago
    Is it a lamp? Is it a speaker? Both? Neither? Inquiring minds want to know.
    ryeaxlee
    4 years ago on Introduction
    So this is a model of the bigger, working version to be built?
    What will the working version do? Play sound thru built in speaker(s), plus ????
    Excellent model btw, that milled walnut base is superb.
    Eric Rocher
    4 years ago
    This is pretty cool. I love the look of it.
    15, 11:51 AM.jpg
    ma77er
    4 years ago
    Ninja Bunny - the scale model or the object it represents?
    Snailios
    4 years ago
    This sounds like fun! Can't wait to see it in completion!
    tomatoskins
    4 years ago
    That looks amazing! I'm excited to see what the final project looks like!
