Sound Reactive 2.1 Audio Amplifier (flashy Ipod Dock)
36,680
239
14
About: I am a Design Technology Teacher currently teaching Electronics but have trained / taught and studied everything under the D&T umbrella
This is my version of the LED boxs that i have seen on this site. This formed the final part of my degree course as a trainee Secondary Design Technology Teacher.
Its pretty simple. I took the flashing circuit for an led box and built it into a ready made 2.1 system, then made a new housing for it.
Have a look here for a video of the finished product:http://youtu.be/0kvhXYVkGGU
Credit to motadacruz for his instructable as it was his awesome guide that got me doing this one, anyway have a look at this for the circuit but forget about the stereo cable as we are going to hard wire this into our audio circuit
https://www.instructables.com/image/FMZXXB8G5W7R47J
The Circuit to control the LEDs consists of a NPN transistor (everyone recommends tip31 but i used tip 121 as thats what we had in the electronics cupboard). The base (left leg) connects to the signal source i.e the positive wire on the speaker. The collector (middle leg) connects to the first negative leg in the chain of LEDs (the amount of LEDs you can run depends on your voltage) the emitter connects to the 0v rail on your power supply. Thats it. there is no need to ground the negative audio signal like everyone else states.
Supplies:
Step 1: Getting the Circuit and Testing
So this is the build:
I chose a cheap 2.1 system, stripped it down and played with the circuit. Although this system was AC (i live in the UK) it had transformer and bridge rectifier to lower the voltage and produce DC current. A fiddle with the multimeter showed it produced 17V
Sand down the rails to expose the copper before drilling holes to run your power leads from (i drilled 3 holes so i could have lights on the left, right and bass)
once you have run a power supply off the amplifier board and created your circuit you should get something like this:
http://youtu.be/h99rDZ19_vs
(i have these LEDs in series and paralel in order to test but basically they are superbright Blue LEDs, they have a safe working voltagge of upto 5.5v       17/5.5 = 3.09 so i can have 3 LEDs in series and a protector resistor.
Now plan out how you want the lights and it will determine the design of your housing.
I  went for 3 lights around each speaker and flashing bass ports. The spacing of the volume and bass dials could bot be changed so I placed them in the middle of the housing.
To difuse the lights around the speakers i used acrylic rod, drilled at one end at 5mm to accept the LEDs and sanded at the other with 400 grit wet and dry to defuse the light. The bass tubes are acrylic tube drilled 5mm again to accept the LEDs but this time the lenses of the LEDs have been sanded away as i want the light to diffuse through the side of the led and not protrude into the tube.
My design looked like the last picture on this step:
Step 2: Creating the Housing
So the housing. i went with MDF as its easy to work and doesnt have any grain to worry about.
Decide of the size of your box, I cut lap joints into all my boards with a table router, this made sure it would stay square and add extra strength. i also added escape ports to the back panel so the audio from the main speakers did not rattle around and cause a noticeable delay. mark out holes for your switch, audio input (originally this was a twin RCA but I created a 3.5mm stereo jack instead) and powr cable
This takes a little time but its worth it to get a decent finish......about 5 days work)
1) Cut out your front panel, sand down and clean. i ran the holes through the router to profile them and give a better finish.. then cut your back panel.
2) Glue everything together (not your back panel) but put the back panel in to make sure it all snug and doesnt warp Clamp it and leave overnight
3) fill any gaps with car body filler (easy sand stuff not glass fibre). leave 20 mins to dry and then sand back till flat (i used 320 grit paper)
4) run it through the router to profile the corners (if you are going to)
5) give it a coat of white primer and leave overnight to dry (This makes it easier to see how much you have sanded off)
6) Fill any imperfections and seal the newly rounded edges with filler, again sand back.
7) when happy spray with highbuild primer and leave to dry
8) rub back with 400 grit paper till smooth. then repeat high build (leave again overnight) and sand
Now you are ready for the coating, I chose stone chip paint as it is cheap and provides an anti scuff / scratch finish. some people recommend truck bed spray but in the UK this is not readily available and so that means its expensive
make  sure you are happy with the finish as a final coat will show any imperfections up.
Spray a coat of stone chip. leave over night, spray again leave over night.
Next we are going to create the compartments for the audio to reverberate in....
Step 3: Creating the Compartments
Right, do all of this with your box face down an old towel, this will stop it getting too marked.
I separated both sides of the box and created a compartment for the Volume and Bass knobs to sit in. This takes some time and effort as it needs to be a tight fit so its doest move around with the vibrations later. Work out the best design for your circuit but make sure you have a space around your speakers in give it a better sound.
Once happy with that cur a board that will sit on-top of these divisions and seal them off, i chose to use the same 6mm mdf that the rest of the box had been made from, this should stop it vibrating. Again it must be a tight fit so take your time and do it properly.
Now i want my bass tubes to protrude through to the rear compartment as that is were the bass speaker will sit. so after i have worked out its position in-line with the front and cut the hole its time for a test. i also need the escape tubes for the left / right audio through the back so these will move through the centre division and out of the back panel. Taking into account the thickness of the lap joint these are marked out and drilled. again time for another check
The bass speaker is a little large so mine was mounted at an angle. to do this i cut away the piece that covers the volume control as this doesn't really matter anyway.
Right, lets get all the electronics in...
Step 4: Final Push (get the Circuit In)
Ok, this is the hardest bit.
Lets do it step by step.....
I wired up my LEDs and transistors earlier so i could just stuff everything in. Have a look at the first pic in this section. I made them all on flying leads as i really couldnt see the advantage of creating circuit boards for them. i have 3 circuits going in, 2 identicle ones for the Left / Right audio and then 1 transistor with 2 LED strings running off it for the bass tubes. dont forget to include protection resistors for this part of the circuit, you dont want the LEDs to pop after a week. i used 330Ohm
1) Firstly fix your speakers in place, then wire the signal input (Audio + on the speaker ) to the base leg of the transistor (the left one)
2) make sure you use either heat shrink or insulation tape on all your joints here, if something touches here its not going to work and you aren't going to fix it. i screwed my sransisrors to the inside casing to stop them vibrating and moving around.
3) push your LED diffuses into their positions around the speakers and then mount the LEDs into them. i suggest using a glue gun or superglue here to fix them in place and fix the wires down also.
4) Put your dividing cover in place and run all your wires through, at this point i sealed around the edges of the compartment with hot glue.
5) Wire the LEDs to the power output from the main board, (remember to do positive and negative)
6) at this point i fixed my volume control in its little compartment with araldite as the original threads were not long enough to poke through and wired my last transiistor circuit to the positive terminal of the bass speaker.
7) Make sure everything is wired up then mount your bass speaker. i created a mount to hold it at a 25 degree angle but thats your design.
8) put the bass tubes in and insert the LEDs. when happy again fix them with glue. look at the front ogf the housing to check the position of the bass tubes then glue them in place inside.
9) wire up the led string and run all the required cables through the back panel. This for me was the power. switch and audio input.
10 ) screw your main board down. transformer etc and glue the cables down to stop vibrations.
11) Put the back on, and give it a test.
With mine the bass and left/right LEDs flicker at different rates as they have different inputs. as you turn the bass control down there is less signal so the lights go out, same with the volume.
I made the 3.5mm connection rather than using the twin RCA cables as this took up less space on the rear panel and everyone has a spare 3.5 to 3.5 cable now a days (they have green plugs at each end and come with your shiny new computer monitor)
Hope this has been of some use to you.
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    14 Discussions
    hfisher3
    6 years ago on Introduction
    haha ohh !!! The rails are the spikes on the bottom of the transistor!!!? If thats correct, why did u drill 3 holes on ur like mother board thing? i have not drilled holes...yet.I will send you a post.
    Thanks again !
    woody2khfisher3
    Reply 6 years ago on Introduction
    Right let's start again. Read the whole thing. The board thing provides the voltage for.the leds. I drilled them so I can put wires in and solder them. That is what we call a positive or +v rail. The other holes are the negative rail or 0v. Read the whole post then ask me again.
    hfisher3woody2k
    The base (left leg) connects to the signal source i.e the positive wire on the speaker. The collector (middle leg) connects to the first negative leg in the chain of LEDs (the amount of LEDs you can run depends on your voltage) the emitter connects to the 0v rail on your power supply. :) so if i do 3 led strips 1 wire from each one goes to one of the 3 holes ? 1 strip goes to 1 hole....?
    woody2khfisher3
    Right ok lets put this in less than Layman's terms. The transistor has three legs, a base a collector and an emitter. you have copied and pasted above the correct bit. If you look at my pics i drilled 6 holes. thats 3 in one part and 3 in another part. One part is the supply voltage (my +v) and the other is the ground (0v) so as it says above....
    The base (left leg) connects to the signal source i.e the positive wire on the speaker. The collector (middle leg) connects to the first negative leg in the chain of LEDs and the emitter connects to the 0v rail on your power supply.
    so one lot of LEDs connects to one hole in the +v one hole for the 0v and one of the speaker terminals. Just read the whole thing
    hfisher3woody2k
    omg i did not see the other 3 -.- sorry about that! makes more sence now! So LAST QUESTION then ill send u a post of my finnished product! Does it matter where i drill the 6 holes ? aslong as its not going through a component ...obvs?
    woody2khfisher3
    Yes it matters. On an audio amplifier there is normally a positive and negative voltage. This increases the potential difference ( means there is a larger difference between +18v and -18v rather than +18v and 0v) if you drill the holes where I did you define have +18 v and 0v. Anywhere else on the board you could have a totally different voltage. ALSO MAKE SIRE YOU DO NOT TOUGH THE CONTACTS ACROSS THE BOTTOM OF EITHER OF THE LARGE CAPACITORS. the are used to turn the +18v current from the wall into dc current for the board. If you short out one of those (touch both pins at the same time) the capacitor will discharge and trust me that is about a hundred volts. That will hurt.
    hfisher3
    Hi sorry just one question........... the LED strip also supply's the power ( or whatever you nerd call it ;) ) to the + port thing of the speaker then u just wire the - as normal ...? if not ...please explain ? and whysand and drill 3 holes in the amplifier ? is that to attach the LED strip to also?
    tcop
    7 years ago on Step 4
    very nice!
    It is obvious you have many skills (electronics,woodcrafting,painting etc)
    Cool mod, would fit nicely to any living room
    woody2ktcop
    Thanks, this project will be sitting nicely in my classroom in September
    usbg3rd
    hi woody2k
    nice project i have a suggestion that u can use transistors with a very high resistance at the base .. when u do this u will be able to use as many Led's as u can without dropping the sound of the amplifier or distorting it too... :)
    btw keep up the good work....
    woody2kusbg3rd
    The tip 121 transistor is a Darlington pair with a built in diode meaning that there is no feedback through the component and the signal is effectively amplified. I'm only running 3 LEDs off a transistor because they are in series, there is no problems with distortions whatsoever.
    The LEDs on the bass tubes/ports are 2 series strings of 3 LEDs running off one transistor in parallel (6 LEDs in total)
    bowlen199
    very cool. how the quality of the sound from the amp you built compared to say, a 12 V £30-£40 car stereo amp?
