Voice Controlled Arduino Drone
158,104
1,183
296
About: Hi, I'm Tamas (Thomas), a 19 years old Hungarian guy. My hobby started more than 10 years ago. I learn electronics, physics, programming, IoT and I'm sharing my projects with you, hope you like it!
The drones are very good toys and tools, but usually they haven't any extra skills. I love to fly any R/C model and I just wanted to make a R/C drone that's a little bit smarter than the usual models. That's why I developed this mini voice controlled tricopter robot. The main concept is pretty easy, the drone is based on an Arduino Pro Mini board, the motors can be controlled through PWM pins. I made a bluetooth connection with my Android smartphone and using an app the phone transmits words through serial communucation to the HC-05 bluetooth module to the Arduino board. The best thing is that this project didn't costs more than 11 dollars.
I made a "motor shield" or something like that using a few transistors that increase the current of the digital output pins. I used 2N2222, but would be better to use a SMD power transistort. The drone works well with both. The propellers and the motors are bought from eBay.
Some features:
• speech controlled
• Arduino Pro Mini based
• voice recognition with a smatphone
• moves left, right, backward, forward, upand down
• hasn't build in gyroscope, you should make a code that holds the drone in balance, this can be made after a few experiments
• low weight, 22 grams, you can add 5 extra gramms
I made a tricopter because I have only 3 motors with propeller, but of course you can make a quad or hexcopter.
You'll need some experience in soldering, but isn't so hard. Only the motor shield requires some skill.
Supplies:
Step 1: The Sofware
Before gathering materials write upload this code to your Arduino Mini Pro. If your drone is made perfectly this code will work. If isn't you should modify the code at the end. To programm the Arduino Mini I used an Arduino Uno that was set on 3.3 volts.
1. Arduino Mini Pro to Arduino Uno
2. RX --> TX
3. TX --> RX
4. VCC --> 3.3v
5. GND --> GND
6. RST --> RST
Now upload the code and you'll have a programmed board. I wrote some explanations in the sketch, but if you have questions feel free to ask. The Arduino analyzes the word through serial reading and reacts to them.
Step 2: How the Code Works?
The code is relatively simple. Analyzes the voice variable and reacts to them by controlling the motors. After turning left or right the Arduino quickly changes its value to the original, so your drone doesn't need a gyroscope, because automatically turns back in his oroginal position thanked to the sofware. This makes your flight safe and fun. :)
//copy this code in the IDE
<p>String voice;<br>int motor1 = 3; //Connect motor 1 To Pin #3 left motor
int motor2 = 9; //Connect motor 2 To Pin #9 rear motor
int motor3 = 11; //Connect motor 3 To Pin #11, right motor</p><p>//--------------------------Call A Function-------------------------------//</p><p>//the values after each anlogWrite commands are controlling the motor's speed, the max value is 255</p><p>//if your drone isn't in balance try to modify the values, example change 130 to 135 if your drone goes backward </p><p>void middlespeed() {
  analogWrite(motor1, 130);
  analogWrite(motor2, 130);
  analogWrite(motor3, 130);
void fastspeed() {
  analogWrite(motor1, 255);
  analogWrite(motor2, 255);
  analogWrite(motor3, 255);
}</p><p>void lowspeed() {
  analogWrite(motor1, 100);
  analogWrite(motor2, 100);
  analogWrite(motor3, 100);</p><p>}
void setup() {
  Serial.begin(9600);
  pinMode(motor1, OUTPUT);
  pinMode(motor2, OUTPUT);
  pinMode(motor3, OUTPUT);
void loop() {
  while (Serial.available()) { //Check if there is an available byte to read
    delay(10); //Delay added to make thing stable
    char c = Serial.read(); //Conduct a serial read
    if (c == '#') {
      break; //Exit the loop when the # is detected after the word
    voice += c; //Shorthand for voice = voice + c
  if (voice.length() > 0) {
    Serial.println(voice);
    //----------Control motors----------//
    if (voice == "*start motors") {
      lowspeed(); //The motors start spin, and the drone slowly comes downer if already flies
    else if (voice == "*fly low") {
      middlespeed(); //Fly the drone, stay in one place
     else if (voice == "*fly higher") {
      fastspeed(); //Maximum motor speed, the drone will go upward very fast
    }</p><p>    //----------Directions----------//
    //The drone can be controlled the best in middlespeed state
    else if (voice == "*go left") {
      delay(450);
    else if (voice == "*go right") {
      delay(450);
      analogWrite(motor3,130);
    else if (voice == "*go backward") {
      delay(300);
     else if (voice == "*go forward") {
      analogWrite(motor2, 200);
      delay(350);
     else if (voice == "*right back") {
      analogWrite(motor1, 200);
      delay(350);
     else if (voice == "*left back") {
      analogWrite(motor3, 200);
      delay(350);
    }</p><p>    //-----------------------------------------------------------------------//
    voice = "";
} //Reset the variable after initiating</p>
Step 3: Parts and Tools
Tools:
For this project you'll need a soldering iron, a glue gun, a variable power supply unit and a PC with Arduino IDE.
Parts:
Main, most important parts:
Arduino Pro Mini 3.3v clone, but it's better to buy the original Arduino Mini 05 board
3 Motors
HC-05 Bluetooth Module
Secondary parts:
• 2N2222 transistors (local hobby-shop, $0.1)
• 3 Propeller Blades (you can buy together with the motors)
• A Battery (mine is from an MP3 Player)
• Straws and a small lightweight plastic piece (from any store)
• Rubberbands (from a store)
• 100Ohm resistor (local hobby-shop, $0.05)
• Some Wires (local hobby-shop or salvage from other electronic stuff)
You can buy all main parts on the eBay. Click on it to open the link.
Step 4: Soldering...
  • Arduino Mini Pro to HC-05
  • RX --> TX
  • TX --> RX
  • VCC --> 3.3v
  • GND --> GND
Solder the two circuits together using short wires. It's very easy.
Step 5: How to Build the Tricopter's Frame?
Insert the motors in the bigger straws and glue a frame with the other straws, just like on the pictures. I bought very strong straws from a local supermarket and they hold the motors very strong, so they won't fall down. Behind the design are a lot of physics calculations. I can't explain these now formulas and rules but if you're interested read this article. Using those formulas given in link, you can design an own frame and drone.
Step 6: The Rear Motor
You need to make a small difference between the vertical axis and the rear motor's axis otherwise the drone will spin. 10 degrees are enough for this.
Step 7: Motors
You can see some metal sticks on the first picture, I plugged them into the endings of the motors. This is important, because you'll have a joining piont for soldering.
Step 8: Check the Polarity!
On the pictures you can see how my motors should spin. I used my PSU unit and tried out every motors on 2.1 volts.
Step 9: The "motor Shield"
Now you should make a small circuit that can be easily attached to the Mini Pro board. The circuit schematic shows you the connections but I missed the 10kOhm resistor because its value is too high, so it's better to use 100Ohm resistors. This circuit should be very small. Solder connection legs to the 9, 3, 11, GND and VCC pins just like me.
On the schematic are corrected the RX and TX with red font color.
Step 10: Soldering the Transistors
The appearence of this circuit is bad, but it's small and has a low weight. I soldered one more connector for the battery.
Step 11: Adding the Motors
And now it's time to use your soldering skills to solder the motors to the positive voltage source and to theirs transistor's collector. Sorry I haven't more pictures for this step, but I hope it's clear what should you do.
Step 12: The Done Circuit
The harder part is done. We are close to finish the project. Take your Arduino board and slowly connect to the motor shield. Be careful, do not damage or shortcircuit the circuits. Connect the battery to the device, and if the circuit's power LED lights you did a good job. :)
Step 13: Stabilize the Circuit!
Use two rubberbands and fix the circuit on the frame.
Step 14: The Application
Download this application from the Playstore: BT Voice Control for Arduino. Charge up your battery with a PSU or with a lithium polymer battery charger. If you're done try it out.
Step 15: First Flight
As you can see at the first time I din't flew very good, but later after an hour of practice I became a good pilot. Sorry for the bad pictures, but the drone moved in the air. I crashed a few times, but nothing happened with my new gadget.
Step 16: How to Balance in the Air?
If your drone can't stay in one place in the air modify the analogWrite values in the code.
Step 17: Video
This video is made by a $5 Keychain Car Camera and has a very bad resolution and date is bad too: 2012... I don't know why. But you can see how the drone flew up the came down. The commands cannot be heard because of the very bad microphone of the camera. And wasn't very stable, because of the weight of the camera, so I can't move right or left in this video, only up, down, and forward.
Step 18: The End
Thanks for watching! If you liked don't forget to give me a kindly vote. I really hope you'll enjoy to build this drone, it's very fun to make and to fly with this gadget.
Robotics Contest
Runner Up in the
Robotics Contest
5 People Made This Project!
  • Arduino Contest 2019
  • Fandom Contest
    Fandom Contest
  • Gardening Contest
    Gardening Contest
296 Discussions
Sembot
Question 5 days ago
Hai:
Fantasties project
I can start the drone via the app, but the other commands give no result
The voltage on the motors is 3.5 volts and the power supply is 5V
The explanation refers to 2.1V per motor
How can I decrease the 3.5V voltage, this is by changing the 100 ohm resistor, and how: increase or decrease ?????
My rotors may be too big, but I had them and first use them as test material
I also had to use an arduino Nano because my arduino pro mini no longer worked
I also used a 2nd power supply to feed the motors
Who can help me with the other commands so that I can rise and fall, thanks in advance
If someone knows such a project (only flying with software), please report this, maybe there is positive information
The PCB was first made for an arduino pro mini, but by connecting pin 11 with a wire I can also use the pcb for an arduino Nano, the microprocessor will stick out a bit , no problem seeing that the loose pins touch nowhere
noorqamarfatimah
7 weeks ago
HI
I have tried to copy and bast the code in IDE of Arduino ,but the code didn't verify and I have got this error (expected unqualified-id before '<' token) for this line( <p>String voice;<br>int motor1 = 3; //Connect motor 1 To Pin #3 left motorleft motor). please help me and thanks.
saikiranmekala
1 year ago
I connected as per the circuit diagram but if I give commands through my phone bluetooth module unpairs and gives a message "device connection lost" please help..
saikiranmekalaFolterW
Reply 2 months ago
It's due to the insufficient power supply. I used three batteries one for motors,one for bt module,one for Arduino mini pro. It worked for me but it becomes too heavy to lift up. My suggestion is to try using three batteries as I did. I hope it works if not there might be problem in Bluetooth module
FolterWsaikiranmekala
Reply 2 months ago
my bt module starts and works with mobile, but not recognize the commands :c
Reply 2 months ago
If hc module works fine,then the problem is in dumping the program into Arduino.Make sure the program dumped successfully.As per my knowledge,when it starts receiving commands the motors consume more power which turns off Bluetooth module automatically.so I suggest u to use different power supplies for motors and Bluetooth module.
Reply 2 months ago
hello saiki thanks for your help, about the module hc 05 , works and the mobile is connected, but when i send the message of start motors or fly high, the motors not response or the signal bluetooth to arduino dont work :/,ummm maybe the code or the commands not work properly :c
Reply 2 months ago
saikiranmekala i used a 5.0 usb cable and nothing works, i need another power supply?
Reply 2 months ago
hello saikiranmekala, i use a 3.7 v battery and hc module with 9600 bauds, i need more voltage ?
ayesherry
Question 1 year ago
hello, i'm done with the structure and programmed my aurdino pro mini chip but when i give commands via android app, it's not working :/ Can you help me please?
I'm using this app https://play.google.com/store/apps/details?id=appi...
Also tell me that above mentioned code works fine? or it needs some changes for the app? thank you
1 answer
FolterW
Question 3 months ago
I use te voice commands but the drone not had a response, please help
fahadshameem0
Question 8 months ago
Hi,
I am using a arduino nano
Can i use the 2n2222 transistor?
What is the rating of resistor i should use with base of transistor if i apply 7.2v?
PLEASE HELP
FelipeB92
2 years ago
Great project! We're are trying to build 2 drones with our students, based on your project but we bumped into a problem: we got 5v arduino pro mini boards. Can the project be adapt to it? If yes, any suggestion on how?
Thanks
purushottamd3FelipeB92
Reply 1 year ago
yes you can. i am facing the same problem,but i am using whole different Circuit and programme
TejasT2
1 year ago on Step 2
Hey can you give the circuit diagram for adding a ultrasonic sensor module(for collision avoidance) as well as LED lights,and an add on MPU-6050 accelerometer module(for stable flight)?
