Speed Up Laptop / PC
5,196
19
8
About: How to Everything.
FOLLOW US ON OUR WEBSITE :- http://www.creativitybuzz.org/
Hello Friends,
Here I show you how to speed up your laptop or computer at home.
Laptop speed can increase by install SSD Drive instead of HDD Drive.
Step 1: Disassemble Battery of Laptop.
First of all Disassemble your laptop battery by pulling out.
Step 2: Open Two Screw.
Then open two screw shown as per picture.
Step 3: Disassemble Upper Case of Laptop.
Then pushing upper case and disassemble this.
Step 4: Open Two Screw of HDD Drive.
Then open two screw of HDD Drive.
Step 5: Disassemble HDD Drive.
Then Disassemble HDD Drive from Laptop.
Step 6: HDD Drive Case
There are four screw on HDD case.Open this four screw and disassemble from case.Then take SSD Drive and install in the case.
Step 7: Insert SSD Drive
Insert SSD Drive in to Laptop and Install OS (Operating System).
Step 8: Test Speed of SSD and HDD.
Here SSD take 13 Second for boot and HDD take 26 second.
    • Build a Tool Contest
    • Paper Contest
      Paper Contest
    • Weaving Challenge
      Weaving Challenge
    8 Discussions
    rafununu
    1 year ago
    The laptop itself isn't 5 times faster, the drive access time is faster, but not 5 times. SSD aren't compatible with XP as well.
    rcorrigarafununu
    Reply 4 months ago
    SSD's most certainly do work with XP.
    warhawk8080
    10 months ago
    You could also use program to ghost the already installed OS from the old slow HDD over to the super fast solid state drive....biggest and cheapest way to maximize the speed of a computer...max out the RAM...if you can put 16GB in it...put it in it
    wilf3
    1 year ago
    Clean the laptop please!!!
    painfull
    1 year ago
    I have to agree with rafununu and russ_hensel. Current read / write speeds of SSD's are at least 5 times that of HDD's, but that alone will not make your computer 5 times faster at everything it does. Your video proves exactly this; 13 second boot is only twice as fast as 26 second boot.
    Definitely over-selling your project here. If you want to add some punch to your project landing page, advertise the fact the SSD will also make your computer lighter, less susceptible to data loss if dropped, and in most cases extend the battery life (depending on the condition of the battery). Those are all good selling points when it comes to laptops, because they are the most common gripes about laptops :)
    oragamiunicorn
    1 year ago
    Surely step 1 is to make a disc or usb of your operating system, otherwise you have a newly upgraded brick
    russ_hensel
    1 year ago
    SSD drives are great, and perhaps one of the best comparisons is boot up since it is largely IO bound. But often a compute intensive program runs with almost no disk IO. The 5x speed up does not seem to be supported even by your text, I think you are somewhat overselling what is in fact a good thing.
