Spike Ring
20,524
196
9
About: I make things. DIY author and blogger at Studs-and-Pearls.com. Studs & Pearls: 30 Creative Projects for Customized Fashion available at Barnes & Noble, Amazon and UrbanOutfitters.com!
This ring creates the illusion of a spike going through your finger, although the ring is SO lightweight you probably won't even feel it. **This project DOESN'T use actual spikes, they're just simply cone bead caps! Much easier to find than real spikes.
Supplies:
Step 1: Supplies
Supplies:
- Jewelry pliers
- Super//E6000 glue
- Adjustable ring blank
- 2 cone bead caps
Step 2: Prep Ring Blank
If your ring blank has a loop on it, twist it off with the pliers. Separate the two ends of the ring to widen up it up a bit.
Step 3: Bend Ring Blank
Bend each of the ends out, making them as flat as you can.
Step 4: Glue Bead Caps
Glue one of the prongs into the inner top part of a bead cap.
Step 5: Repeat on Other Side
Repeat on the other side. Let dry.
Step 6: Wear It
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    9 Discussions
    EverydayKiki
    7 years ago on Introduction
    I love this idea so much, I tried it, but ended up supergluing all of my fingers together!
    haha, I will have to try again with different glue.
    Avatar_I_AmKiteman
    Ah... nothin' is classier than an arrow through th ehead, except a sword through the torso.
    That said, Cool Ring! Nice!
    simplebeep
    How marvelously excellent!
    Hm, I'm thinking this could be even more fabulous if the ring on the underside of the finger was "hidden" with a little costume latex, à la this instructable. That way the illusion would work from more angles… but it would be a bit more of a hassle.
    ilpug
    this is great in its simplicity and style. nicely done.
