Spread a Deck of Cards 3 Different Ways!
About: I'm an accomplished magician and musician with a desire to educate the masses.
Whether you want to look like a professional card handler or just want to impress your friends, this is a surefire way to do so.
Supplies:
Step 1: What You Will Need
1. A deck of cards
2. Your hands
Step 2: The Ribbon Spread
This is an elegant table spread. It is the simplest of the four spreads. This is good for magic tricks done in an intimate table setting. Steps:
1. Hold the deck with the thumb and middle finger on the short ends.
2. Pull the deck to the side, guiding it with the index finger.
Step 3: One-Handed Forwards
This is a showy spread, good for showing off. It's good when no table is available.
Steps:
1. Hold the deck with thumb on top and fingers below.
2. Apply gentle pressure from the bottom, using the thumb as a pivot
Step 4: One-Handed Reverse
This is a good, showy spread that can be used to show the deck as blank. Steps: 1. Hold the deck with the thumb on top and fingers curled below 2. Apply pressure with the fingers and push
Step 5: BONUS!!!
The Turnover is basically a fancy addition to the ribbon spread that shows how good you really are at card handling. Steps: 1. Ribbon Spread 2. Slide finger under bottom card 3. Turn it over and guide the wave with your finger.
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
