Arduino Automatic Plant Watering System
21,452
232
23
About: I'm an Electronics Engineer who likes to make Doze Lamps, Lumen Powered Thingamajigs, Almighty Brainy Buttons, Tweeting Weather Stations and share them on Instructables.
Meet Sprout - the Modern Indoor Planter which automatically waters your plants, herbs, vegetables, etc and will revolutionize your gardening game.
It consists of an integrated water reservoir from which water is pumped & keeps the plant's soil hydrated.
A soil moisture sensor is calibrated such that it periodically measures the moisture of the soil thereby regulating the water flow. If the soil is too dry, the water pump automatically switches ON and goes OFF when the soil moisture has reached the desired level.
If you're the person who underwaters their plants, Sprout will ensure you will never have to worry about being a bad gardener again. And if you're the sort of person who overwaters their plants to compensate for absenteeism, it means your not in danger of drowning your plants or seeds.
Sprout's water reservoir capacity is around 500 ml / 17 fl oz, which allows you to neglect your plants for as long as a month before it needs a refill.
The optional Bluetooth feature can be used to manually toggle & control the water pump wirelessly from your smartphone.
Develop:
Are you a programmer, engineer or designer who has a great idea for a new feature/design in Sprout? Maybe you're just a beginner or you've spotted a bug? Feel free to grab our code, schematics, 3D design files & laser cutting files from Github and tinker with it.
Sprout: GitHub
Step 1: Electronic Design
Electronic Components List:-
Arduino Nano: AliExpress
DC Water Pump: AliExpress
Soil Moisture Sensor: AliExpress
HC-05 Bluetooth Module: AliExpress
LM7805 Voltage Regulator: AliExpress
IRF540 MOSFET: AliExpress
220 Ohm Resistor: AliExpress
IN4001 Diode: AliExpress
Header Pin Strips: AliExpress
DC Barrel Jack: AliExpress
Screw Terminal Block: AliExpress
PCB: AliExpress
AC-12VDC Adapter: AliExpress
Tools:-
Soldering Iron: AliExpress
Solder Wire: AliExpress
Power Block
The 7805 regulates the supply voltage and reduces it to a constant 5V making it suitable to run the Arduino & Soil Moisture Sensor.
Pump Control
The MOSFET acts as a switch which is controlled by the Arduino. We use the MOSFET since the Arduino cannot directly power the DC Pump. The resistor connected to the gate of the MOSFET prevents the MOSFET from getting damaged. The flyback diode connected across the pump provides a path for dissipation of stored energy when the pump is switched off. The Anode of the Diode is connected to the Drain of the MOSFET. The Cathode of the Diode is connected to the 9V supply rail. The Source of the Diode is connected to GND.
Moisture Sensor
The sensor feeds an analog value to the Arduino. The threshold level of moisture is calibrated by the user depending on the type of plant used.
Bluetooth Module
Uses Serial Communication to transfer data between the Arduino and your Smartphone.
Step 2: Electronic Assembly
A 1x Scale printable PCB as well as the board view and schematic is available in the GitHub repository.
Sprout: GitHub/Electronics
The repository also contains an A4 size PDF which contains multiple PCB's on a single page. This can be used to make multiple PCB's at a time for mass production
Solder all the components according to the given Schematics.
The editable Eagle files are available below.
You can Order the PCB here: PCBWay
Step 3: Software & Bluetooth Configuration
Software
The Moisture Sensor is connected to an Analog Input pin of the Arduino. A threshold value determines whether the Pump should be ON/OFF.
You can find the code at Sprout: GitHub/Code
Feel free to modify & contribute to the GitHub repository.
Smartphone App & Bluetooth Configuration
The HC-05 Bluetooth module is the intermediate block between the Smartphone & Arduino. It uses Serial Communication to send data from the Smartphone to the Arduino & acts as a Remote Control.
The app transmits the value '48' or '49' which represent 'ON' & 'OFF' respectively. The pump can hence be controlled wirelessly.
Simply open the app, scan for discoverable devices & pair with the HC-05 module. then click on 'Switch Mode' and toggle the onscreen button.
The app is available at Bluetooth App
Step 4: Mechanical Design
The main body of Sprout is a 30cm X 15cm X 19cm Box made out of MDF.
All Mechanical Design steps have been clearly demonstrated in the video attached at the start of the Instructable. You can also check it out at Sprout: Video/Mechanical Design
The box is divided into two sections:
  1. The larger section contains the Soil & Plants
  2. The smaller section is further divided into two more sections such that one section contains the Circuit Board while the other contains the Water Reservoir.
The water reservoir is a 500ml plastic bottle.
The MDF box has 8 separate interlocking faces which can be laser cut and slotted into each other.
The Laser Cutting files, Fusion 360 Design file (3D Design file), isometric as well as orthogonal views of each face can be found at Sprout: GitHub/Mechanical Design
You can also find editable Illustrator files in the GitHub repository which can be modified to your specific requirements/dimensions and then can be laser cut.
Step 5: Mechanical Assembly: Bottle Preparation
The water reservoir is a 500ml plastic bottle. A typical 500ml plastic Soda bottle can be used for this.
The maximum diameter of the bottle should be 74mm. The maximum diameter of the cap of the bottle should be 50mm. The maximum height from the base of the bottle to the lowest part of the cap should be 18.5 cm.
The bottle must be cut about 50mm above its base so that the pump can be placed within it. Holes must be cut into the bottle such that the Outlet Pipe and Power wires can be fed through the bottle.
Once the Outlet Pipe and wires have been taken out through their respective holes, the bottle can be sealed again. To seal the bottle we must use an Epoxy Compound which will harden within a few hours. This will prevent any water from leaking out.
The water can be refilled from the top of the bottle by simply opening its cap.
Step 6: Mechanical Assembly: Box Preparation
Once you have successfully laser cut the 8 different faces of the box, Apply several coats of a high-quality wood varnish to each side of each face.This makes it highly water repellant & makes it resistant to moisture & humidity.
Mount the Power Jack on the Back Plate too & connect it to the Circuit Board.
Mount the Circuit Board on the Back Plate of the Box such that it fits within their respective section.
Pull the Pump Outlet Pipe through the given holes such that it reaches the Plant soil section. Do the same for the Moisture Sensor wires.
Don't forget to connect the Water Pump to the Circuit Board as shown in the Schematic
Begin interlocking the different faces of the Box and ensure that bottle fits snuggly into its designated area.
Apply wood glue or an adhesive to seal the entire box
All these steps have been demonstrated in the Video found at the Start of this Instructable.
Step 7: Mechanical Assembly: Cement
This step will determine the out texture & final finish of the box as well as give the planter another protective coating.
Apply glue to each face of the box. Then sprinkle some cement over the glue. Use the remaining circular MDF piece which was cut from the Top Plate to smoothen the cement across the surface of each face of the box. Repeat this step for each face of the box as demonstrated in the video.
Once the cement dries, sprinkle with water every 6 hours for 1 day. This will allow the cement to cure, with no cracks and will also prevent water from leaking.
Step 8: Add the Soil & Plants
Once the cement has cured, fill the box with soil.
Remember to heat seal the end of the Outlet pipe before making a hole in it for the dripper. The dripper is used to regulate the water coming out of the pipe so that the water does not flow out of the planter.
Place the Soil Moisture Sensor inside the soil.
Power Sprout through the Power Jack at the Back Plate & make sure fill the water reservoir to the full level.
Test whether everything works and you should be done.
Epilog Challenge 9
Runner Up in the
Epilog Challenge 9
Arduino Contest 2017
Runner Up in the
    • Organization Contest
    • Remix Contest
      Remix Contest
    • Pocket Sized Contest
    23 Discussions
    juniper_smith
    6 months ago
    Is it possible to create this project with a breadboard instead of a PCB? If so, how? I'm having trouble trying to create the project as I'm unsure where to connect what parts to the ardunio and the breadboard. Your help would be great. Thanks :)
    juniper_smithJonathanrjpereira
    Reply 6 months ago
    Thank you so much! You're a lifesaver. I am using this project for my year 12 assessment :)
    Jonathanrjpereirajuniper_smith
    Reply 6 months ago
    All the best with your assessment. Don't to forget to share images of your finished project using the 'I made it' button.
    DAA8
    10 months ago on Step 2
    Hello bro,Do you have any electrical diagram? because I want to do it in a protoboard to implement other things and in the PCB I do not understand it well. Thanks for your answer, my email is danieltkd97@gmail.com
    JonathanrjpereiraDAA8
    Reply 10 months ago
    Refer to Step 1: Electronic Design
    If you have any more doubts feel free to ask them
    DAA8Jonathanrjpereira
    Reply 10 months ago
    Thanks but I have the following questions:
    1.-Pump 1 is the + and pump 2 is the pump - or 1x 2-Pin Screw Terminal?
    2.-If the 5V that feed the circuit can be only from the arduino or will I need another external source?
    3.-I do not understand if the pin 13 of the arduino is connected to an element or not, and if so, what is?
    Reply 10 months ago
    1. Pump 1&2 are the terminals of the Pump which can either be directly soldered to the PCB or you can use a 2 Pin Screw Terminal.
    2. The 7805 is the main 5V power source which powers the Arduino (through Vin pin) and the HC-05. The Arduino's 5V output powers the Moisture Sensor.
    3. In the code, I included an optional LED status indicator for visual feedback to the user/maker. One can connect an external LED or use the Arduino's inbuilt LED(pin 13) or choose to disable the LED.
    Reply 10 months ago
    Thanks but I have another question. The HC05 RX module is connecting to the arduino RX, and TX to the arduino TX?
    Reply 10 months ago
    The HC-05 communicates with the Arduino using Serial Communication. A serial bus consists of just two wires - one for sending data and another for receiving. As such, serial devices should have two serial pins: the receiver, RX, and the transmitter, TX. It’s important to note that those RX and TX labels are with respect to the device itself. So the RX from one device should go to the TX of the other, and vice-versa.
    Hence we must connect the Arduino's Tx to the HC-05's Rx & connect the Arduino's Rx to the HC-05's Tx.
    For more information about Serial Communication, check this tutorial out: https://learn.sparkfun.com/tutorials/serial-communication/all
    DanielR492
    1 year ago
    Where does the LM7805 Voltage Regulator go next to the arduino or off to the top of the circuit by itself? Is the power supply a AC Arduino Uno power supply?
    JonathanrjpereiraDanielR492
    Reply 1 year ago
    I used a 220VAC/9VDC power adapter.
    The output of the adapter is 9V DC which was given to the input of the 7805.
    The pump requires 9V to run whereas the Arduino requires 5V.
    JasonG208
    1 year ago
    Another way to go about this (though not nearly as cool), as told to me by a botanist, is to put a good piece of string from the water source into the soil of the plant, to the roots, then as it needs water it pulls it from the reservoir via the string.
    sp9mrn
    1 year ago
    ok, but where is your Youtube profile ;-)
    What to make next? Portable 3S lipo powerbank witch overdischarge,
    overcharge protection & balancing ;-)
    Jonathanrjpereirasp9mrn
    Reply 1 year ago
    It's in the video above or you can go to
    Portable Power Banks sound like an interesting project.
