Stain Masking
30,837
165
13
About: I love working at the intersection between design, material science, function, and delight! I like thinking about fashion, history, and art, and about how we define ourselves through the objects we make and...
Stain is usually applied to an entire surface or, at most, straight edges are masked with blue painters tape. I wanted to experiment with staining crisp, complicated designs!
I knew a good stain mask would be clear and adhere closely to the ridges of the woodgrain. With an opaque stain mask, stain will often wick under your design and you won't know you have a problem until you remove the mask and the stain has set. With vinyl and tape masks, the mask often sits above the tiny ridges in the wood grain. This can be mitigated by burnishing the mask (by rubbing it with a hard object) but will still lead to a fuzzy edge where the stain wicks under the edge of the mask.
I had left my watercolor supplies out and as I was brainstorming I realized masking fluid was the perfect candidate for my experiment and has long been used with watercolors to produce a similar masking effect.
Step 1: Find Inspiration
  1. "Birds on a Wire . . . ( iPadography )" by jimmy brown is licensed under CC BY 2.0
  2. "Birds on the wire - crop right" by Colin is licensed under CC BY-SA 3.0
  3. "Rural electricity" by Kevin Dooley is licensed under CC BY 2.0
Get inspired! Keep an eye out for photos you love- or use your phone's camera to save moments that catch your attention. I wanted to test this staining technique with both organic/curving shapes and orthogonal/rigid shapes so the classic motif of birds on power lines silhouetted against the sky was perfect. I googled lots of images and printed out a few of my favorites.
Step 2: Gather Your Materials
You'll need
Art Masking Fluid (I like Winsor & Newton's tinted version because it's easier to see as you're working)
Wood Stain (I like Miniwax's Wood Finish line and I used Gunstock)
Paper Towels
Newspaper or other sacrificial materials to protect your work area
Optional: Gloves
Paint brushes for masking fluid
Paint brushes for stain
Something to stain!
I used unfinished wooden magazine holders from IKEA but you could use any wood that makes you happy. Smoothly finished wood will make it much easier to remove the masking fluid but I plan on experimenting with rougher wood (perhaps with a clear masking fluid) in the future to produce a rougher look.
Step 3: Draw Your Design
Paint your design with the masking medium! You can very lightly trace your design or use carbon copy paper but I prefer a free-hand look (and reference lines can be difficult to remove completely from wood).
Experiment with the masking medium on a scrap piece of wood. The medium is rather thick and can take some practice in controlling line density. Apply the medium liberally (it will be slightly raised). You might want to rinse your brush every 10 minutes if you have a large design or it will become stiff with clumps of drying medium.
Note: Putting a little dish soap on your brush before dipping it in the masking fluid will making cleaning the bristles much easier.
Step 4: Stain
Allow the masking fluid to dry for several hours.
Lay down a thick layer of newspapers or other sacrificial material that may get stained.
Use a paint brush to brush stain over your design. Work quickly and always keep a "wet edge"- be sure to keep the edge of your stained area from drying next to an unstained area. Apply a generous first coat then add additional stain over any areas that seem paler. Wood is full of imperfections so don't worry about achieving a perfectly uniform shade but try not to leave obvious brush marks or hard lines. You can achieve this by doing your finish brushing in overlapping W shapes approximately aligned with the woodgrain if you notice brush marks.
Step 5: Wipe Off the Excess Stain
Allow the stain to sit for the recommended amount of time then wipe off the extra. I was happy with the color after 5 minutes so I wiped off the excess with paper towels. I put on Nitrile gloves after the first paper towel when I came close to swiping my whole palm across the wet surface.
Note: I like to use a brown paper grocery bag to collect the stain soaked paper towels. It stays open and lets me throw things away one-handed without worrying about getting stain on the edges of a plastic trash bag. I then leave the paper bag next to my stained project while it dries (that way the paper towels dry at the same time). Never throw away wet stain-saturated rags or paper towels as they're highly flammable!
Step 6: Rub Off the Masking Medium + Seal
The masking medium can easily be removed after staining by rubbing with a soft eraser, or gently peeling it off with your fingers.
Lastly, coat your work with mineral oil to give it a nice sheen. Then, enjoy!
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    13 Discussions
    KendraW9
    2 years ago
    I wonder if one could paint the lines and birds in Acrylic paint (maybe teal)? Then apply the masking medium over top of the dried paint before staining the rest of the item? Also, more finished pics, please!
    I think that would be adding steps to a project that you shouldn't need to. Acrylic or oil based paints could simply be painted over the stain once dry. With acrylic paints, you would want to allow the stain to fully dry (couple of days) so that you don't trap any of its solvents under the paint.
    This looks really impressive. I wonder if this masking technique would also work on when dying Easter eggs.
    It actually should work better on eggs shells, since the wood of a tree is designed to be a conduit for transporting water from root to leaf and egg shell is not (long version of saying egg shell is less porous).
    Raitis
    2 years ago
    Would drawing with a wax candle + some heat exposure before staining work, or is this masking medium some real wizardry?
    ArtisanEclecticRaitis
    Reply 2 years ago
    Wax drawing would work, it would just be much harder to control and next to impossible to remove after the fact. The real wizardry of masking medium is that it rubs off with your finger when the job is done.
    Ninzerbean
    2 years ago
    pics of the sides please?
    Rocktakon
    2 years ago
    This looks nice, and I'd be curious to see a bit more photography of the results and hear your assessment of how well you think it went and what (if anything) you'd do differently in hindsight. Thanks for sharing!
    JP'sW
    2 years ago
    Very effective technique!
    duplexemotions
    2 years ago
    Can we get more pictures of the results?
    halledean
    2 years ago
    That's a good idea! And I have those same magazine holders! I'll have to try this out on them.
