Stand Up Paddle Board
5,888
105
9
Made from Scratch
Step 1: Lamination
Ribs cut out to shape on Bandsaw then holes drilled to lighten and provide a place to clamp.
I used Hemlock for my strips. They are about 1 1/2" wide and 1/4" thick
Glues each piece using a water proof glue
Step 2: Sanding
After strips are in place sanded top and bottom
I hand planed the rails to shape them and then sanded
After sanding I made the front part and the back which I glues and then shaped
Step 3: Finish Touches
I used plasti dip around the rails to straighten them
I also drilled to holes in the tail to let air out when not in use. (Very Important)
I bought a fin box online and installed it
I made my own handle box and placed it in using supports and epoxy
Last step is to fiber glass the whole board
    • Tape Contest
      Tape Contest
    • Build a Tool Contest
    • Remix Contest
      Remix Contest
    9 Discussions
    Ollie_Clarke_GCSE
    2 years ago
    This board looks amazing and I'm thinking about doing this project for my DT IGCSE but what wood did you use for the ribs inside the board?
    HandyMan16Ollie_Clarke_GCSE
    Reply 2 years ago
    I actually used thin plywood and glued a couple together for the spine and for the ribs I use 1/4 inch plywood
    MatthewS1
    4 years ago on Introduction
    This looks GREAT!
    You wouldn't happen to have the plans for the ribs? I usually laser cut pieces like that and would love to build the exact one you have made.
    HandyMan16MatthewS1
    Reply 4 years ago on Introduction
    Sorry I wish I did. I actually borrowed them from an old mentor teacher I had and made them in his shop. Im kinda mad at myself that i didnt trace some templates so I would have them. Wish I could help. Sorry
    MatthewS1HandyMan16
    Thanks for your reply!
    I'll be printing out a tiled shape and using that as a template - should work well.
    Thanks again.
    seamster
    This is a great looking board!
    If I were interested in duplicating this project, what other info would they need to know? I'm curious about the rib pattern, the layout distances, fiber glassing, etc. Any additional info would be really appreciated!
    HandyMan16seamster
    Hey. So since this was my first board I learned a lot and would make a view changes. For the rib pattern i had a friend who built one and gave his tracers for each part. So sadly i dont have them. You can probably find some online. If you have asses to a plainer i would suggest gluing up a bunch of strips then plain them and then glue and press them onto your board. This will save a lot of time. For the ribs I suggest using 1/4 by 1/4 inch strips all the way around. For fiber glassing it is not cheap. Expoxy alone will cost you over $200. I would recommend using a roller to glue down fiber glass. If you have any other questions feel free to ask.
    seamsterHandyMan16
    Cool. It looks like a great project, and something I'm interested in tackling someday down the road.
