Steampunk Bluetooth Headset
28,713
99
26
Last halloween I dressed up in an old fashioned manor with my cell phone in a pocket keychain. The chain was too short for the phone to reach my ear. This left me with the option of un-hook the phone every time I had to use it, make a unreasonable long chain or; mod a bluetooth headset to match the outfit :)
Materials:
  • BT-headset
  • Screws'n'nuts
  • Two plates of metal (or plastic)
  • glue-gun / super-glue
  • Electrical tape
  • Wire
  • Drill
  • Magnets
Disclaimer: These materials are not tested nor designed for longer skin contact so beware of any rash or itching!
Step 1: Layout of the Headset
I acquired a cheap headset on Ebay, opened it and located the necessary buttons.
Luckily the answer/call button was located roughly at the center of the piece. (saved me the hassle of relocate it and solder..)
Step 2: The Casing
A while back i found these metal tags at a thrift store. As you can see they're like an instant steampunk addition!
I decided on three screws to hold the piece together, one in the front and two at the back.
Step 3: Making Holes for the Speaker
Since I'm a bit lazy I roughly dotted out the holes freehand and drilled.
Step 4: Fitting the Headset in the Casing
First of all I had to insulate the circuit board with tape to prevent short circuit.
Then I fitted the circuit board so that the answer button would match the hole in the metal tag and applied a reasonable amount of glue.
Step 5: Put It All Together
I used the nuts to fixate the plates.
When I had tightened the nuts I cut the top of the remaining screwes off.
Step 6: Hook It Up to the Ear
As I mentioned before I am quite lazy so I wanted a fast and flexible solution for the attachment of the earpiece.
I had some tiny, flat and strong magnets laying around so I came up with a nice way of hang the head set on the ear.
The magnets were simply glued on with superglue.
Then I continued with the wire.
This part takes some fiddling to get a nice fit on the ear.
I started with rolling the end to get maximum surface contact between the wire and the magnets.
Then I rolled the other end to make it look good.
This design is quite nice since it allows you to rotate the headset in place and wear it on left and right ear.
Step 7: Last Touch
I smeared gold paint on the sides to get an old look to it.
And that's it!
Hope you enjoyed it!
Dr. Absconditus
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    26 Discussions
    diy_bloke
    3 years ago
    looks great. I probably would have opted for brass bolts and nuts but thats just a matter of taste.
    Well done
    hardlec
    8 years ago on Introduction
    I have a donor blue-tooth: My dog got hold of it and chewed up the case. I am not very savvy about the guts of electronics, but maybe I can use this "junk" to my advantage.
    How well does this work?
    How long have you worn it?
    j3tripp
    10 years ago on Step 7
    Dude that is M-azing. I have to put my shoes on and go buy the stuff to make this right now. Thanks a lot for this awesome instructable. :)
    Abscondituslemonie
    @lemonie Yeah, some sort of steel wire used for decorations / flower arrangements I think.. It had a nice non shiny finish.
    ZootchAbsconditus
    Did you even need to replace the earpiece? It looks fairly uncomfortable and is covered for the most part with your ear, you could just as easily resolder the original plastic piece...
    jauncourtPKM
    That can easily be remedied by coating the wire with a couple coats of clear spray acrylic. Me, I'd wrap the wire with some heavy thread (like buttonhole thread).
    Ward_Nox
    I have an LG decoy it comes w a bluetooth but i REALLY nead the ear strap this gives me an awesome idea how to make a (lacking a better word) holster think i may make it out of leather if i can work it though
    sensoryhouse
    When did Steampunk go from meaning "modified to run on steam" to "modified to look like a prop from Back To The Future III"
    staticsensoryhouse
    Then again steampunk has always been a fashion thing, not so much about actual steam power.
    In all fairness, Back to The Future III was pretty awesome and also I would have pegged it more to be a prop from The Wild Wild West , With Will Smith. It's not a bad idea although personally I will stick with my retro handset
    killbox
    you should hunt around for some square brass nuts,
    ironsmiter
    Pretty darn cool mod.
    BUT! It's steampunk. you need MORE BRASS!
    and that is easily accomplished. Swap out those machine screws for some nice shiny brass computer standoff screws.
    Also, a nice coating of shellac or clear nailpolish on the side that contacts your face... would help protect the exterior parts from human-skin induced corrosion.
    jauncourtironsmiter
    or even thin leather glued in place with contact cement.
    Absconditusironsmiter
    Hi! Thanks for the tips! Really cool idea with the standoff screws!! I promise to make the next mod/thingy more "brassy"! :)
    Erinoth
    Another option on the ear wire is to cover it with cloth from an old shoe string
