Steampunk Gauntlet
About: I'm just a poor high school student who loves video games, pasta, and sleeping in.
As part of my skill building agenda, I have been trying different techniques to make props. This weekend I made a single gauntlet based on a design/prop made by TwoHornsUnited. This build took about 6 hours and cost about 5 dollars.
Step 1: Materials
  • 2mm, 3mm, and 5mm craft foam
  • 2 part epoxy
  • Hot glue
  • Velcro
  • Newspaper for patterning
  • Primer paint
  • Metallic and acrylic paint.
  • A heat gun (optional)
  • Exacto knife or a scissors.
  • Glue gun
  • Hole puncher
Step 2: Patterns and Cutting Foam
I started by making a pattern for the gauntlet. I measured around my arm then drew out the basic shape onto some newspaper. I cut the shape out of 5mm craft foam, then cut the four scales that go down the center of the gauntlet out of 5mm craft foam as well.
Step 3: Scaley Scales
I sanded the edges of the scales to a rounder shape with a dremel (sanding bit). then I traced out the scales onto 2mm craft foam (this is just so I have an idea for how large the plates would be). The scales each have a plate onto of them, so I drew those on the 2mm foam as well. I cut the plates out, then hot glued them onto the scales,
Step 4: More Scale Stuff
I glued the scales together, then glued them onto the gauntlet. I decided that I wanted my gauntlet to be steampunk which meant: rivety things. To make the first of the rivets (lets call these rivets tacks). I took an old pencil, and dug the eraser out of it. I heated up the foam carefully then pressed the eraser part into the foam. This gave the appearance of tacks.
It's important to be careful heating foam. If you look in the last picture I burned part of the foam pretty badly. If you use hot glue, excessive heat gunning can cause the glue to melt and your beautiful project can also fall apart.
Step 5: More Details
I cut out a strip of 3mm craft foam in a trapezoidal shape, and glued it to my gauntlet (I made tacks in each corner). I also cut out a weird shape (3mm craft foam), and glued that over part of the trapezoidal foam.
For the other side of the gauntlet, I cut a rectangle out of the 5mm craft foam. I lightly scored a triangle into the foam with an exacto knife, then went over the scoring with my heat gun. This creates a more defined design on the foam. Punished Props has a great tutorial you can check out on how to do this.
I actually screwed up making the triangle so to cover up my mistake I took a 3mm strip of craft foam and covered it (see pic 5).
Step 6: More Rivets
You can't make a steampunk gauntlet without rivets. I used a hole punch to make a bunch of foam circles to make large rivets, and two part epoxy to make the small rivets. I used a tooth pick to dab the epoxy where I wanted the rivets to go. I used hot glue to add the foam circles to the gauntlet.
To seal the foam I lightly went over the whole project with my heat gun until the foam looked shiny.
Step 7: Painting!!
I started out with a coat of primer.
I only had silver metallic paint, and gold. If you would like to see how I made all the colors I used check out pic 2, if you would like to see where I painted each color look at pic 4.
To weather the gauntlet, I would lay down a wash of black paint, then rub off a bit of it with napkin. This left it looking quite dirty.
Step 8: Strap
To make the strap I took a piece of 3mm foam, and glued one side to the gauntlet, and glued velcro to the other side (with hot glue), Then I glued velcro to the inside gauntlet.
Step 9: Woop There It Is!
And it's done. What a beauty.
If you have any questions feel free to comment below or message me. I know some parts of this were slightly confusing.
    • Weaving Challenge
      Weaving Challenge
    • Paper Contest
      Paper Contest
    • Tape Contest
      Tape Contest
    10 Discussions
    CalebGreer
    1 year ago
    Awesome work!
    Do you have a knife/blade and primer you recommend when working with EVA foam?
    rainingfictionCalebGreer
    Reply 1 year ago
    I use an exacto blade to cut all of my eva foam (make sure to get a bunch of them, foam dulls them really fast https://www.amazon.com/gp/product/B0006GBSXG/ref=o... ).
    As far as primer goes, for projects that I'm not particularly invested in, I say the biggest thing when working with foam that has made painting easier would be sealing the foam with a heat gun. Then I go over the foam with a wash of acrylic (like I did in my NCR ranger costume), then I just paint normally over that. This works great and is inexpensive.
    If I have more time I like to use a filler primer spray paint (you can get these at Menards); this helps fill in imperfections and seal the foam. Sometimes I'll go over the project twice if I feel that is needed.
    I know some makers like to use a product call Plastidip to seal the foam, I personally have not tried this, but they swear it works.
    I have also used wood glue and mod podge to prime things as. In all I would say buy a filler primer at your local hardware store, this is the simplest method.
    My goodness am I long winded. Hope this helps :)
    CalebGreerrainingfiction
    Reply 1 year ago
    Thanks! So a heat gun really is that useful? That's next up on the wishlist I guess :)
    Thanks
    znordy
    1 year ago
    Are you planning a costume or is this it?
    rainingfictionznordy
    Reply 1 year ago
    I wasn't planning on it. This was just a skill building exercise for me. However it may fit in with some of the other steampunk things I'm working on.
    ljohnson72
    1 year ago
    So I have a personal hack for when I make mine idk if you'd be interested but it works awesome for me. I use a shin guard as my base for extra support so I don't have to worry about velcro coming undone during alot of movement. Just a something I thought I would share with you. Absolutely beautiful work.
