Steampunk Rubiks Cube
20,470
60
14
About: Welcome to my profile. My name is Matthias and I am BrittLiv's boyfriend. She also uses this account to post some quick instructabes that she deems too simple for her main account.
In this instructable I am going to show you how to modify a Rubiks Cube to give it an aged look. You can of course use any type of Rubiks Cube to do this mod, but I decided to go with a gear cube.
I am obsessed with Rubik Cubes and since the original wooden one is ridiculously expensive, I decided to modify one to look kind of similar. Have fun making your own.
Step 1: Getting Started
Stuff you need:
  • gear cube (e.g. here)
  • golden spray paint
  • plastic primer
  • black acrylic paint, paint brush
  • clear coat
  • masking tape
  • thin veneer or vinyl stickers with a wood structure
  • silicone grease
  • screw driver
  • optional: drill, sanding paper
Depending on the cube you get the middle pieces might be glued in place. Carefully drill a hole into two opposite sides and unscrew the screws. Now you can take the cube apart and unscrew all the other screws as well.
Step 2: Preparing the Pieces for Painting
Prime all the pieces or slightly sand them. Remember to only paint the pieces that are visible from the outside.
Also tape the middle of the cross to prevent paint from getting into the mechanism.
Step 3: Paint the Pieces
Carefully spray paint the pieces. Remember to only paint the pieces that are visible. Use thin layers to make sure they still move later. To give them an aged look I dry brushed them with black paint. You can also use products like Rub 'n Buff. Simply dip your paint brush into the paint and wipe off most of it. Then carefully paint the pieces starting from the corners.
Once you are happy with your pieces use clear coat to make them more durable.
Step 4: Reassemble the Cube
Before reassembling the pieces use some silicone lube to make sure they move properly.
Start by assembling the middle. Use the pieces that allow you to access the screws as top and bottom. Once you have assembled the top or bottom tighten the screw.
Step 5: Adding the Stickers
I laser cut the veneer, because it was way faster to do so, but you can also carefully use a knife. An even easier way is to use vinyl that looks like wood.
I uploaded the file I used for laser sutting should you have access to one.
Congratulation, you are done.
Before and After Contest 2017
First Prize in the
    • Trash to Treasure
      Trash to Treasure
    • Woodworking Contest
      Woodworking Contest
    • Fat Challenge
      Fat Challenge
    14 Discussions
    asettico
    1 year ago
    Hello,
    really nice project!
    It seems that the attached file RubikSticker.ai is corrupted.
    Could you releoad it or add it in another format, for example PS?
    Quietech
    1 year ago
    And my morning starts with visions of Hellraiser. Cool mod!
    rstott2
    1 year ago
    Cool but not a Rubiks cube. Puzzle cube sure. Gear cube from Mefferts.
    Swansong
    1 year ago
    This looks really neat! I love the design :)
    mrsmerwin
    1 year ago
    I like your version way better than the original.
