Steel Washer Ring
14,557
105
7
About: I'm.. Me. :P My names Nick/Nicholas (my friends call me Nikolai). I'm a metalhead, a prop maker/artist/gamer, and studying to be an Graphic Designer. I'm always trying to find ways to make new things with ...
Heyo people's! Been a while since I've done an ible, thought it'd be nice to put one up for a change of pace!
>alright.. Lets get to the ible!
Supplies:
Step 1: Find the Parts/Tools
Alright for this you're gonna need 7 things 1)a steel or stainless steel washer. 2)a dremal or drill. 3)files and sand paper. 4)ring mandrel or even a round crow bar. 5)patience.. It takes about 2-4 hours if you work nonstop, have everything you need, and are experienced with stuff like this. 6)a hammer, if you don't have this you're not getting far :P. 7) most important thing is music.. If you don't have it.. And you're in a quite room.. You will most likely go bonkers.. Trust me 0.0
Step 2: Starting You Ring!
Ok so this instructable is pretty much the same as the last one I made, but the metal is a bit harder to work with..
>you're going to want to start by getting your center hole big enough to fit over the mandral/crow bar.
>after that you are going to want to bang at it pretty strong on a hard surface (concrete, steel plate, etc...) at about a 45 degree angle, until it begins to flatten out.
>Once it gets about flat, you're going to take it off the mandral and flip it around to where the wide side is pointing to the narrower side part of the mandral.
>begin taking mighty fine wacks at it (considering it is steel) until it flattens out. After this you're ready for the next step!! :D
Step 3: Shape That Bugger!
Shaping is definitely the most aggravating and time consuming step..
>depending on how you want your ring (wavy, zig-zaggy, normal maybe..:P) will determine how long it will take you. For mine I went a more normal wedding ring style. Classy, yet not over the top.
>use you're dremal and files to get it shaped and all looking pretty, then once you have it how you like.. SAND THE BABY DOWN! Get all the sharp edges knocked off, and everything nice a smooth.
Step 4: Get That Baby to Shine
Woot woot! Almost done, all you got left is the minor sanding, and polishing!
>Usually 300, 600, and 1000 with a coat of wax will do the job and get it all nice and shiny (like I did). But if you want that nice mirror you're gonna wunna keep going until you reach 3000 (pain in the ass..but it looks beautiful!).
Step 5: You're Done!
Pat yourself on the back and admire your beautiful ring! you most likely did this in one sitting, there was sweat, possibly blood.. Some nasty words after hitting your finger with the hammer... -_- but it was worth every second, to see the finished product!
Hope this was at least a bit helpful..
Thank you to all my subscribers! You guys are a big help in getting me going, and as inspiration to try something different! Thank you! :)
Please comment, favorite, subscribe (if you're not already) ;)
And check out my other instructables, let me know what you think!
And please vote! :)
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    7 Discussions
    krakh1
    5 years ago on Introduction
    Cool ring but pictures of a mandrel and how you flattened it would be nice. I don't have a clue how you flattened it.
    KemikalzAreFunkrakh1
    Reply 5 years ago on Introduction
    Pictures wouldn't have given much of a "how to" on flattening it out. I believe somewhere in this ible I explained how to do it. There's more than one way to flatten it, you just kinda have to figure out what works best for you.
    KemikalzAreFunWouterZ
    If you're talking about the lack of shine, and the dents on the outside.
    It was made to look more distressed. If I really wanted I could make that thing look flawless, mirror finish, smooth surface. But that's not what I wanted.
    As for the pipe, you could I guess, but you would have to resize it. which resizing involves putting a seam, and soldering it back together. Not the most ideal thing if you're wanting it to look good.
    WouterZKemikalzAreFun
    Don't get me wrong. I like the look. I made one of a titanium piece of scrap pipe which was the right size for me, so I was lucky. I made the sides and inside shine and the outside brushed with a scotch pad. Stretching a ring is hard to do with diy tools (and impossible with titanium)
    Bobey
    hi you commeted on one of my instructables can you please login to the PC version of instructables go to that instructable it is called deleted and can you delete that comment?
    jamob
    5 years ago
    It's really cool how you were able to do this with the regular tools in your house! I find that most of these instructables always require those machines that most people don't have. Thanks for making a ring instruct able for the common mans budget!
