Storage Case From Road Signs
4,706
101
24
About: I got an old sewing machine when I was just a kid, and I've been hooked on making stuff ever since. My name is Sam and I'm a community manager here at Instructables.
This is a heavy duty storage case I made from recycled aluminum road signs.
Several years ago I acquired a pile of "retired" signs from a city road department. They were removed and replaced due to damage or other reasons, and were destined for a recycling center.
You'd be surprised what you can get if you just ask! An alternate source for similar aluminum scrap is noted in the next step.
This Instructable covers how I made this neat little storage case to hold a cheap RC radio. Thanks for checking it out.
Step 1: Gather Materials
I've made a lot of stuff out of the pile of old signs I got, and these are the leftovers. There's enough to make a few more little things whenever inspiration strikes though.
There are a couple of Habitat for Humanity ReStores near where I live, and occasionally they have old aluminum doors. I recently bought a broken aluminum door for just a few bucks (parts of it in 2nd photo). It requires more work to break down into usable pieces, but the material is great and very useful for all kinds of projects.
So if you can't track down any retired (or "decommissioned") road signs, old metal doors are a great alternate source for used plate aluminum.
Along with aluminum sign scraps, I purchased two 6-foot long pieces of 1/8" thick, 3/4" aluminum angle, a bunch of pop rivets, and an old briefcase that I cannibalized just for the neat handle.
Step 2: Start Cutting
I quite enjoy working with sheet aluminum. You can cut it with a jigsaw with a metal cutting blade, or on a table saw or circular saw equipped with carbide-toothed blades.
It's soft and fairly easy to work with, but the shavings do tend to get all over the place. Fully sealed safety goggles are a must.
The dimensions for this case are roughly 10" by 11" by 6". It has two parts: the bottom is 4 inches deep, and the lid section is 2 inches deep.
Step 3: Pieces Cut
I determined all the sizes needed and cut them out. The flat pieces were all cut out using a table saw. Smaller cross cuts were done using a sled on the table saw.
The aluminum angle pieces were cut to length using a portable metal band saw mounted in a stand with a table (this, if you're curious).
Step 4: Cut Angles
The aluminum angle pieces all needed 45 degree cuts made on both faces of the piece ends. These were marked with a framing square, and then cut using a metal bandsaw.
Step 5: Assemble With Tape!
The boxes were initially assembled with double-sided clear tape.
This held things in place while I drilled holes and added rivets. It turned out to be a great technique that worked extremely well!
Step 6: Add Rivets
Holes were drilled through the angle pieces and sheet pieces in one shot, with the help of a backing block held firmly behind the drilling locations.
A bit of tap magic cutting fluid was used to help holes get drilled quickly. (See puddle on table. Just dip the drill bit before drilling each hole.)
Rivets were added using a pop riveter. The rivets I used were 3/16" wide with a grip range of 1/4".
Step 7: Add Hinges
I had some old hinges I used for this.
They were first epoxied in place with a bit of 5-minute 2-part epoxy. Once they were locked into position, I drilled the holes and added rivets. This is a great trick to simplify getting hinges and other hardware exactly where you need it.
Step 8: Old Briefcase
So this is kind of funny . . I found this old briefcase at a thrift store for 3 dollars, but it was locked shut. All I wanted it for was the neat leather handle though, so I bought it.
I cut through the locks and opened the briefcase up to find a Mr. Goodbar mini candy bar.
It was nasty.
Step 9: Add Handle
The handle was removed from the briefcase and added to my new aluminum case.
This particular handle had pairs of tabs that get bent over to lock the handle in place. I drilled holes tabs and epoxied the handle in place. When the epoxy was cured, I bent the tabs over on the inside of the case and pounded them down firmly with a hammer.
Step 10: Add Clasps
I added a pair of spring-loaded clasps using the same epoxy-then-drill-then-rivet method described for the hinges. These were take off of some old table at some point. I hold on to every bit of hardware I come across - it's great to hold on to stuff if you'll actually use it someday . . otherwise you're just a hoarder!
Step 11: Reinforce Handle Area
I added a piece of scrap under the handle to reinforce that area, and also to provide a lip to center and support the lid of the case when closed.
This was epoxied in place, with some extra epoxy globbed over the folded-down handle tabs.
Step 12: Lining
For the lining of my case, I used some 2" thick sheets of foam. I'm not sure where it came from originally; it's just more stuff I had lying around.
Since the case halves are 2" and 4" deep respectively, these foam sheets conveniently just needed to be trimmed a little so they'd fit.
The foam was cut to fit the radio using a snap-off-style utility knife, with the blade extended.
Step 13: Add Bumpers
Some clear stick-on bumper pads were added to the "bottoms" of the case - to the bottom when standing upright, and to the other bottom when the case is laid down to open.
Step 14: Done
This was a fun little project and now I've got a rock solid, quirky little case that I'll be proud of for years.
Thanks for reading!
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    24 Discussions
    Cris DIY
    1 year ago
    So cool! Great job! Voted!
    Mark 42
    1 year ago
    Corrugated plastic election signs would make really lightweight panels.
    Not as sturdy, but plentiful.
    michaelmacnz
    1 year ago
    Fab use of alum signs... I have people next to me who install signs for businesses... They bring the old signs back to the workshop then have to dispose of them.. The best ones (for me) are the sandwich ones that are plastic core of 4mm with a .5 mm alum cladding on each side. For the metrically impaired, that's about 3/16 core and 1/64th cladding.. Hehe. The used side is often "interesting" but/and the reverse side is usually brand new !
    michaelmacnz
    1 year ago
    Good ibleMy aluminium supplier has an angle with radiused outside corners... and maybe use countersunk head pop rivets for a flush finish
    makendo
    1 year ago
    Great stuff. Looks sharp. Literally, on the corners - roundover-able on the router?
    seamstermakendo
    Reply 1 year ago
    Hey Scott, thanks! I think a small roundover would be possible, although the stock is only 1/8" to begin with. I did knock down all the sharp edges with 100 grit sand paper (those outside corners and any exposed cut edges).
    ggadget
    1 year ago
    Come to think of it, I've noticed a few signs just laying on the side of some roads. For example, just today there were four stop signs just at the intersection of my street. Everyone seems to ignore them thus they probably aren't important.
    Leathaldose
    1 year ago
    I love it! But it would drive me nuts because nothing matches (colors).
    seamsterLeathaldose
    Reply 1 year ago
    Ha, thank you!
    I love the randomness of the colors and shapes. Personal preference I guess! :)
    Leathaldose
    1 year ago
    Everything would have to be solid colors.
    ajayt7
    1 year ago
    Useful comments from broregret
    ajayt7
    1 year ago
    A fabrication class! Best out of waste! Rivetting can be real handy in fabrication.
    broregret
    1 year ago
    Might i suggest that on your next case you use double flush rivets? Perhaps have the rivets anodized a contrasting color? Another possible modification is replacing the sticky bumpers with sugru-ed corners: no sharp points plus non-mar feet!
    All in all this is a great instructable as it tells you how as well as gets you thinking about creative modifications. Well done!
    MaxineM4
    1 year ago
    this could also be done with old license plates, couldn't it? Very cool. You have my vote.
    Yonatan24MaxineM4
    Reply 1 year ago
    You might've commented because you've already seen it, but if not, Sam already has an Instructable for stuff to make with license plates.
    But that would look really cool!
    creaky
    1 year ago
    Very nice use for the signs and good directions.
    David R
    1 year ago
    Street signs are difficult to recycle. The heavy vinyl lettering and paint finishes are hard to remove. Many municipalities have these pile up until a specialty re- processor can pick them up. Sometimes municipalities are reluctant to sell old signs to the public, same as old uniforms etc because they are concerned someone might use them for a nefarious purpose. I point out that I'm going on record as the owner, and I intend to cut them down so they are no longer signs. I take the signed statement with me, if they bring that concern up, I tell them it concerns me too, put ''tis in your files. They often give me the signs for free at that point. Make friends with the Streets engineer, show them this instructable. Check to see who the resource recycler or environmental educator is, they can facilitate the process.
    JackANDJude
    1 year ago
    Awesome! That case is a keeper, for sure.
    Buso
    1 year ago
    A Perfect Instructable. Thank you.
