StorageBot - Voice Controlled Robotic Parts Finder
55,029
423
97
Video
Introduction
I created the StorageBot to help solve a problem experienced by most Makers. After many years of accumulating thousands of parts stored in storage bins, I began to go crazy looking for parts scattered between so many of these bins. The hardest parts to find were always those rare miscellaneous parts that were thrown somewhere into a "junk" bin. StorageBot solves the location problem by listening to my voice commands, processing the location of parts from a master database and then delivering the matching bins in a manner that only a robot can do!
StorageBot does have a bigger picture when it comes to purpose. I explain in my video that it's not about building a StorageBot that's important, but rather it's the skills we can learn from such projects that help to enrich our knowledge and inspire us to build the next great thing or start the next cool business.
In this Instructable you'll gain insights into the electronics, mechanics and software systems used to create useful projects by utilizing commonly available components such as the Arduino and stepper motors.
I've included a bazillion pictures and files. Source code for the Aduino program, source code for the Visual Basic voice recognition software, DXF files for the ABS parts, schematics for the electronics, 3D files drawn in the free Autodesk 123D program, parts list, etc... It's all here!
If you find this project inspirational and helpful then don't forget to vote for it in the ShopBot contest. I would use a ShopBot to create the ABS parts, aluminum parts and vaccuum form molds for my next generation home robots.
Enjoy!
Step 1: Secret Exposed & Project Outline
The video above gives you a glimpse into the frame and mechanisms required to physically push out each bin based on the voice commands.
I'll describe the system by breaking it into the basic components. Here's an outline:
- Building the pine frame
- Building the x-axis
- Building the z-axis
- Building the y-axis
- Buldling the electronics
- Voice recognition software
Step 2: Autodesk 123D & Pine Frame
The StorageBot frame is constructed out of pine wood. All of the materials can be purchased at Home Depot. The plastic storage bins can be purchased from Harbor Freight. See the attached bill of materials for quantity and pricing.
When buying pine wood from Home Depot make sure you spend time selecting the best pieces of straight wood. I found the wood at the top of the stack is typically the most crooked pieces. Some of this lumber may be returned items and obviously people would return the worst of the pieces. Here's a trick to help determine the straight pieces. Place the piece of wood on the flat concrete floor and use the floor as a straight edge. Stay away from wood that is twisted along the length. Long pieces of wood that bow slightly in the middle can be ok if a later process such as screwing into the final framing straightens them out.
I modeled the pine frame using the free 3D CAD program from Autodesk called 123D. You can download the program here:
http://www.123dapp.com
The cool thing about this program is that you model the components of your systems and then connect them together using something called constraints. In 123D constraints are under the Design Intent \ Assemble Icon. With constraints I can tell 123D to take 2 separate pieces of pine wood and align the edges to each other. Another useful feature of 123D is the Browser history along the left side of the screen. With this browser I can easily turn components on and off by just clicking an "eye" icon for each component. I used this feature in order to generate the step by step images for the frame construction.
The 123D model of the pine frame is attached below as a zip file. Have fun playing with 123D and be sure to watch the tutorial videos on YouTube.
Step 3: Building the X-axis
X is the axis that moves between the left and right side of the StorageBot. This axis also has to support the weight of the other axes, Z and Y.
Like many Makers I sometimes struggle coming up with the best design approach. My first attempt at prototyping the X axis was unsuccessful due to binding issues.  When building any rail system mounted to a wooden frame one has to compensate for wide build tolerances. For example: the wood isn't always straight, there may be warpage with temperature and humidity, cut lengths are slightly different, etc. The final solution I came up with was inspired by a rail system that was already used in my house. It so happens I have pocket doors and the rail system used on those doors can also be adapted to the StorageBot.
Pocket door hardware is an inexpensive and simple system for producing linear motion while hanging a lot of weight such as a door (or equivalent on the StorageBot). See the attached pictures on how I adapted this simple system. This is a great example of how being observant to the world around you can provide insights into solving problems.
Step 4: Building the Z-axis
When I designed the x-axis I was also thinking about how the z-axis would integrate into the design. It was obvious that the "door frame" being hung from my pocket door rail system would serve as the frame for the z-axis. The z-axis in this case refers to the vertical movement between the bottom and top levels of the StorageBot.
I already determined the z-axis would be belt driven and there would be a drive pulley and an idler pulley creating the ends of the belt system. When the belt moved it would have to move a carriage up and down in the vertical direction.
The challenge was coming up with a low cost way to guide the z-axis carriage along the vertical direction. There was already a vertical frame made out of wood so I wanted to use that as a guide. Using wood as a linear guide can be tricky due to sticking from friction. I finally came up with a solution based on some past tinkering with a bin full of spacers. Once again, curiosity paid off.
In the attached pictures you'll see how I used two different sized spacers, one made out of aluminum and one made out of nylon to form a low cost roller guide. Who ever knew playing with a bin full of spacers and noticing how some fit within others would pay off!
Step 5: Building the Y-axis
With the design for the X and Z axis finished I had only one more mechanical hurdle, the Y axis! This axis would be the one responsible for pushing out the storage bins (like a finger). Basically the X and Z axis would position some type of  "finger" in front of the storage bin that needed to be pushed out. The storage bins are fairly easy to push so I didn't need a big motor. The biggest challenge was the need for about a 3" finger throw and the appropriate compact mechanism.
The solution I came up with for the Y-axis was a rack and pinion system. The rack is essentially a toothed rectangular bar that is driven my a toothed circular "pinion" gear connected to a hobby servo motor. By picking the length of the rack and the number of teeth on the circular pinion gear I could now control the throw distance of the "finger". A rack and pinion system is another common way to convert circular motion to linear motion. In fact, it is used widely in the ShopBot system. See the attached pictures for the rack and pinion design. I'm fairly happy with the compactness and adjustability of this design when using different brand servos and different size pinion gears.
Step 6: Building the Electronics
When designing the electronics I wanted to use as many off-the-shelf parts as possible to ease construction. See the bill of materials for part numbers and suppliers. Once you buy and mount the components the wiring is basically all point to point wiring. There's very minimal soldering. You will need to solder two 10k resistors connected to pins 2 and 3 of the Arduino compatible board. You will also need to solder to extend wires from the stepper and servo motors.
The code running on the Arduino basically translates serial commands from the PC computer. These commands are then used to perform the following:
- moving the x-axis stepper motor
- moving the z-axis stepper motor
- moving the y-axis servo motor
- reading the x and z axis limit switch
- controlling the LED strip
Controlling stepper motors are very easy. Each stepper is driven by a driver board. By sending a step and direction signal from the Arduino to the driver board the motor can be made to move forward or reverse by one or more steps.
The servo motor for the y-axis is also very easy to drive. The servo actually contains a motor driver board internally. A certain type of digital waveform is sent to the servo to make it move anywhere between the extreme clockwise and counter clockwise positions. Scope captures of this servo waveform are in the attached pictures.
Step 7: Voice Recognition Software
The voice recognition software runs on any old computer or laptop running MS Windows. It uses the Microsoft Speech SDK and a custom Visual Basic 6.0 application based on the SDK sample programs. You can download the speech SDK here:
http://www.microsoft.com/download/en/details.aspx?id=10121
After installing the SDK be sure to train the speech engine by going to the speech setting under the Windows control panel for more accurate voice recognition. I found the speech recognition doesn't always work that great. I believe the stuff I've seen on the iPhone and Android devices where you can speak more naturally are much better. Nevertheless, the MS SDK is good enough to start experimenting with voice recognition technologies.
There are 2 main functions of the application software. One is to handle speech such as voice recognition and text to speech output. The second function is to take the voice commands and search for the associated parts and bin locations within a master database. This master database was originally generated in Microsoft Access.
Source code for the program is attached as a zip file. You will need Visual Basic 6.0 to modify and run the application.
Step 8: Conclusion
I wanted to end by showing examples of how the systems used in the StorageBot are commonly found in many successful products today (ie: ShopBot, MakerBot, garage door openers, CNC conversion kits, etc).
I hope the many ideas presented in this instructable inspires you to create the next great products!
ShopBot Challenge
Grand Prize in the
ShopBot Challenge
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    97 Discussions
    Youtalken2me
    2 years ago
    This is a fantastic instructable. I want to build this with my son to get him excited in working with his hands and brain instead of being glued to his games. I've gone over your instructable with a fine tooth come and you have given us everything we need to build this, except what you have done in Access. Do you still have the Access file you used and could we get a copy of it. I realize you did this over 5 years ago, but I think my son would learn a lot about what he can do and hopefully get him interested in learning what he can do if he takes the time to learn how to program and design. I wish I could have made this when I had my home shop. It would have put my outlined tool to shame. Thanks again
    dttworldYoutalken2me
    Reply 2 years ago
    Hi,
    The Access file is called storagebot.mdb and is located in the storagebot.zip file found in step 7.
    Good luck!
    dttworld
    2 years ago
    Nice. Best of luck with your Kickstarter!
    lucaslin
    2 years ago
    This project looks cool! I found a desktop type smart electronic parts storage and management device on kickstarter - chipseasy. It is super clean and neat for lab or studio use. It has voice input and keyboard input as well and independent software monitoring your components inventory. Take a look at the link as follow:
    https://www.kickstarter.com/projects/3dfacture/chi...
    mr monoply33
    7 years ago on Introduction
    Personal preference, I'd rather look up parts by an index accessed by keystrokes, at least until speech recognition gets a little better.
    Until then, I think we have the ground work for the Enterprise's repair bay.
    dttworldmr monoply33
    I'm gonna convert this to touch screen. It will be like the self checkout interface at the grocery store when looking up the produce type. You could also use the keyboard with the same interface. Home Depot also has something similar when the cashier needs to look up bolts and screws that don't have labels.
    dart70cadttworld
    Reply 3 years ago
    I would prefer this as well. I would like to have a little program on an old tablet or laptop that I keep in the shop. Type in what I'm looking for and have the result come up on a map with general location plus specific written cooridinates of that container. Eg. Large toolbox highlighted, drawer A6 written output would be enough for me.
    On my property I have a large workshop split in two halves, a garden shed and a home with multiple rooms.
    If the map is too tough to integrate, written location is just as good. Eg, lower floor, laundry room cupboard, A shelf A3.
    This could probably be handled by a simple spreadsheet but I have no experience with creating those. Opinion?
    Malkaris
    3 years ago
    That is awesome!
    I feel like it needs a QR/barcode and scanner on the arm. Then the machine can auto-index, even if you return the bins to the wrong spot.
    For the XY, I wonder if one of those pulley systems would be faster. They use them on white-board drawing bots.
    Again, awesome!
    Yonatan24
    3 years ago
    Wow, I need one of these!
    I would have made it with different sized boxes, For bigger components and different amounts...
    dttworld
    Reply 4 years ago on Introduction
    Sure. Software is a bit outdated. Maybe someone will update it to use the latest tablets and voice recognition engines.
    gfc62
    5 years ago on Introduction
    Danh,
    This is fantastic; a great idea and implementation. I'm surprised I didn't see it back when you first published it. Also surprised I never ran into you at the FabLab at CCBC back then.
    Any new enhancements to your StorageBot? I liked your idea to convert to a touch-screen interface.
    I always thought it would be cool to build a robotic parts sorter that would use machine vision to go through a pile of random hardware and do a series of sorts such as fastener type, diameter, length, material, etc. That would be a great partner to your StorageBot.
    Gordon
    jimmerforpoy
    5 years ago on Step 6
    Hi sorry I'm kind of new to Arduino and I'm just wondering what the extender wires are that work with Arduino wires/where did you get them?
    jhunmar100
    Sir Where did you buy the parts Like gears, pitch, belts and more?
    theenginerd
    6 years ago on Step 6
    what type of arduino did you use? it dosen't seem to be mentioned above is it an arduino uno? or something bigger? Great project I am starting my own version now
    Doug Costlow
    Have you recieved the ShopBot yet? It would be great to see some pictures of your setup once its up and running. Your going to have a pretty good shop going with the ShopBot, storageBot and cnc mill!
    dttworldDoug Costlow
    Hi. Here's a pic of the ShopBot in my garage. The machine is completely installed and all the motors and spindle appear to run properly. There's a 3/4" thick MDF "spoil board" that forms the bed of the CNC and it needs to be leveled by removing a surface layer. This process generates a lot of dust so I am currently installing a dust collection system. After that, next step will be to cut some ABS and aluminum sheets for my home robot. Looks like you're keeping busy with a lot of your own projects. Good luck with your home renovations. This is also on my list of many things I need to complete but thank goodness for Home Depot!
    Doug Costlowdttworld
    That looks great! I'm just a little jealous. I know about the dust issue, I have been cutting wood with my router and it goes everywhere. I need to add a dust boot and shopvac. Hope to see some great instructables that utilize the shopbot from you. I'm pretty sure this is the most expensive prize they have given away yet, well until the 3d printer next month.
    I've got 2 more instructables in the works and should have them up by the end of the month, then it will be only house projects for the summer.
