Stream Games to Your Raspberry Pi 2
97,738
119
57
About: Every week two geeky people in Rochester MN spend every ounce of their freetime creating educational videos, podcasts, articles, and music. They publish it all on the internet, free to anyone in the whole un...
Moonlight is an open source implementation of NVIDIA's GameStream protocol. Moonlight allows you to stream your full collection of Steam games (and other applications) from your GeForce Experience compatible PC to any supported device and play them. These instructions will help you build your own embedded Moonlight device using the cutting edge unofficial port of Moonlight 2.0 for the Raspberry Pi 2.
Needed:
  • Raspberry Pi 2
  • Ethernet Cable
  • HDMI Cable
  • USB Charger
  • Projector/monitor/tv
  • PC
  • SD Card
Step 1: Setting Up the PC
  1. Verify that your PC is capable of GameStream here: http://www.geforce.com/geforce-experience/system-r...
  2. Download and install GeForce Experience here: http://www.geforce.com/geforce-experience
  3. From button in upper right, create an Nvidia account
  4. Use GeForce Experience to update your drivers
  5. Reboot your PC (yes really)
  6. Run GeForce Experience
  7. In Preferences > GameStream tab select 'On my network'
  8. Leave GeForce Experience running.
Step 2: Prepare a Fresh SD Card for Your Raspberry Pi 2
  1. Download and install SD Formatter 4.0 from https://www.sdcard.org/downloads/formatter_4/index...
  2. Insert SD card into reader on PC
  3. Format >4GB SD card with SD Formatter 4.0
  4. Download and extract NOOBS from https://www.raspberrypi.org/downloads/
  5. Copy NOOBS onto SD Card
  6. Remove SD card from PC
Step 3: Installing Raspbian
  1. Insert SD card into Raspberry Pi 2
  2. Connect keyboard, mouse, monitor, and network to Raspberry Pi 2
  3. Connect Power to Rapsberry Pi 2
  4. Raspberry Pi boots into NOOBS
  5. Select Raspbian
  6. Click Install, Click Yes to Confirm
  7. Wait for installation to complete
  8. Click OK
  9. Wait for Raspberry Pi 2 to reboot into raspi-config
  10. Change User Password
  11. In advanced options now would be the time to:
    • Set hostname to Moonlight
    • Enable SSH daemon
    • Enable any other personal tweaks you may need
  12. Select Finish and Select Yes to reboot
  13. Wait for Raspberry Pi 2 to reboot
Step 4: Collecting Resources
Update (replaces original Step 4 and Step 5)
This part is always changing, so be sure to check the comments section for the latest tips and tricks!
Prebuilt binary packages for Raspbian Wheezy are available, add this line to /etc/apt/sources.list
deb  http://archive.itimmer.nl/raspbian/moonlight  wheezy main
Install package using the following commands
sudo apt-get update
sudo apt-get install moonlight-embedded
Skip to Step 6 (if this worked for you), and be really happy about it because you just avoided hours of cross compiling progress bar fun time.
Original (before a repo was up)
Login to your Raspberry Pi 2
sudo apt-get update
Wait for apt-get to update
wget  http://www.cmake.org/files/v3.3/cmake-3.3.0-rc2.t...>tar zxf cmake-3.3.0-rc2.tar.gz
cd cmake-3.3.0-rc2/
sudo ./bootstrap
Wait (going to take a while)
 sudo make
Wait (also takes a long time)
sudo make install
cd ..
sudo apt-get install libopus-dev libexpat1-dev libssl-dev libasound2-dev libudev-dev libavahi-client-dev libcurl4-openssl-dev libjs-jquery
wget  http://archive.raspbian.org/raspbian/pool/main/li...>wget  http://archive.raspbian.org/raspbian/pool/main/li...>wget  http://archive.raspbian.org/raspbian/pool/main/li...>sudo dpkg -i libevdev*
Step 5: Installing Moonlight Embedded 2.0
 wget https://github.com/irtimmer/moonlight-embedded/releases/download/v2.0/moonlight-embedded-2.0.tar.xz
 tar xf moonlight-embedded-2.0.tar.xz
 cd moonlight-embedded-2.0/
 mkdir build
 cd build/
 sudo cmake ../
 sudo make
 sudo make install
 cd ~
Step 6: Setting Up Moonlight
  moonlight pair 192.168.1.1 (replace this address with the ip address of your PC)
GeForce Experience will pop up a dialog box and Moonlight will print:
  • Please enter the following PIN on the target PC: (4 digit PIN)
  • Type the 4 digit PIN into the dialog box and click Connect
  • Paired
  moonlight list
Moonlight will list all of the games and applications that GeForce Experience is able to stream (you can scan for new games via GeForce Experience Preferences>Games Check now button or manually add applications via GeForce Experience Preferences>GameStream Games: + button)
 moonlight help
Moonlight will print out a short guide as to all of the options you should be aware of. For me, this works perfectly:
 moonlight stream -1080 -30fps -app Steam
Moonlight should start showing you a live stream of your game, and pass any keyboard / mouse / controller events over to the game.
Have fun!
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    57 Discussions
    sebc7
    2 years ago
    do i have to install steam on rapsbian ?
    sebc7sebc7
    Reply 2 years ago
    Moonlight doesnt find "steam"
    when i type "moonlight stream -1080 -30fps -app Steam"
    "cant find app Steam"
    GFE is set up with correct games path
    what should i do ?
    JakeV15
    2 years ago
    no way am i going to buy a 100-700$ graphics card to replace the good one i already have... i already have a Intel Quad Core i7 for gaming, i don't want to buy one that might even be worse just so i can stream to my TV. if i wanted to spend money just to play on a slightly bigger screen i would buy the steam link. if someone could help find a way to do this without using the GeForce Experience maybe even using the steam link software that would be great.
    cmhaseJakeV15
    Reply 2 years ago
    LOL. If you're referring to your CPU, then that's not what this is talking about. If you are talking about the integrated graphics in your CPU, then you are wrong. Integrated graphics are almost never as good as a Pcie card. A 750Ti (A very capable card) Can usually be found on Ebay or Craigslist for under a hundred.
    KristjanK9JakeV15
    Reply 2 years ago
    The Intel "GPU" you are talking about is a CPU
    EthanH48
    3 years ago
    If you are getting an error when running <sudo apt-get install moonlight-embedded> try going back into the sources.list file and instead of having <wheezy main> ad the end of the new line you added to the file, put <jessie main> Then it should install.
    zexorEthanH48
    Reply 2 years ago
    THANK YOU EthanH48. I'm new to linux, and would have never been able to figure that out. I just got it working right now with your simple advice. I really can't thank you enough ;)
    zexor
    3 years ago
    Awesome write up, i've used this several times to install on a couple different machines. but as of now it seems the link is broken and i can't install moonlight-embedded. Any chance you may be updating this soon, or if not can you point me in a noob friendly tutroal?
    AndyMardell
    3 years ago
    Thankyou! This worked perfectly for me (repo way).
    SuperSanta
    3 years ago
    Hi i got every thing to work except for one thing. every time i try to start Steam for streaming it tells me that it cant find the app.
    TymkrsBartoszJ
    Reply 3 years ago
    There is no reason now that there is a pre-compiled version up. I created this guide long before that was an option. It is still useful to know how to cross compile cmake for the Raspberry Pi though, so I'll leave this as in.
    thethereit
    3 years ago
    Followed the steps and got everything to compile but ran into an issue with the pair
    "moonlight: error while loading shared libraries: libgamestream.so.0: cannot open shared object file: No such file or directory"
    Any sugestions?
    KevinH113thethereit
    Reply 3 years ago
    Run "sudo ldconfig" and then run the pair command
    WhiteRenard
    3 years ago
    If you are getting a "404 Not Found" error on Step 4, when trying to wget the libevdev files, try these instead (they were updated and you need to change file names):
    wget http://archive.raspbian.org/raspbian/pool/main/libe/libevdev/libevdev-dev_1.4.4%2bdfsg-1_armhf.deb
    wget http://archive.raspbian.org/raspbian/pool/main/libe/libevdev/libevdev-tools_1.4.4%2bdfsg-1_armhf.deb
    wget http://archive.raspbian.org/raspbian/pool/main/libe/libevdev/libevdev2_1.4.4%2bdfsg-1_armhf.deb
    HarisP3WhiteRenard
    Reply 3 years ago
    These links wont work for me. Any other links to download and compile libevdev-dev?
    HarisP3WhiteRenard
    Reply 3 years ago
    Thanks man! New link here (as in 11/22/2015)
    wget http://archive.raspbian.org/raspbian/pool/main/libe/libevdev/libevdev-dev_1.4.5%2bdfsg-1_armhf.deb
    wget http://archive.raspbian.org/raspbian/pool/main/libe/libevdev/libevdev-tools_1.4.5%2bdfsg-1_armhf.deb
    wget http://archive.raspbian.org/raspbian/pool/main/libe/libevdev/libevdev2_1.4.5%2bdfsg-1_armhf.deb
    Anyone knows the **full** commands for downloading/compiling the latest beta from git (debian jessie)?? I mean commands from beggining till end..
    WhiteRenardHarisP3
    Reply 3 years ago
    I'm not sure what commands you mean, but I followed this tutorial and everything worked out in the end. When I was trying it though, apparently Moonlight had not been updated to Jessie which caused some problems, I downgraded to Wheezy and everything worked fine.
    Maybe everything has been updated to Jessie now but I'm not sure.
    HarisP3WhiteRenard
    Reply 3 years ago
    What i mean is if anyone knows the full ssh commands (from scratch till end) to compile and install the
    up to date latest beta moonlight-embedded (cmake, dependancies, git
    clone etc)
