How to Make Strike Anywhere Matches
342,234
497
145
You will need: Safety matches (with matchbox), sanding paper, a small container, something to stir with, a pair of pliers, a tube or a D-cell battery, and water.
You will also need something to lay the matches on, like a the edge of a table or this CD case that I used.
Step 1: Sanding of Phosphorus
Sand off the phosphorus on the sides of the matchbox (striking surfaces) and put the powder in the container.
Step 2: Put on the Phosphorus
Put a few drops if water in the container and stir well. Take the matches, one by one, and dip them in the mixture. Then lay them on the edge of the table/CD case.
Step 3: Cover the Phosphorus
When they're dry, take some new matches and squeeze off the heads with the pliers, then pulverize the powder with the pipe or battery by pressing it down and rolling it over the powder and then put it in the container (if you're using the same container, be sure to wash out the leftover phosphorus). Add a few drops of water and stir well. Then dip the matches in the new mix so that you cover the phosphorus already on them and let them to dry again for a while.
Step 4: Test
Step 5: Warning
Please be sure to wash your hands after making these matches, phosphorus is toxic.
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    145 Discussions
    JamesY23
    3 years ago
    Okay, you know you can buy strike anywhere matches, don't you? You do not have to go through this. Buy a bunch of them and store them in dry boxes, containers. I've been reading many of your posts and I can't help but wonder why you make so many simple things seem so complicated.
    THEMONEYJamesY23
    Reply 2 years ago
    Buy some of those "strike anywhere" matches you speak of and try to strike them on a rock or the seat of your pants.
    OH2BIOJamesY23
    Reply 2 years ago
    Well. These are not available in Finland either. I think that these amay be banned in EU, but not sure. I'd like to buy those but it's not possible to ship them from the States to Finland. At least it is very expensive because of strict safety regulations.
    artenlorOH2BIO
    Reply 2 years ago
    That's sad because strike any where matches are one of the ingredients in the orginal Molotov Cocktails that were developed in Finland, you should complain based on a historical and patriotic interest.
    OH2BIOartenlor
    Reply 2 years ago
    As far as I know, Finnish Molotov Cocktail had 12cm long, 60 second Storm Matches (Bengali Stick), not strike anywhere matches. Those would have been really dangerous. There were two sticks. The other was a spare one if you didn't have to throw the bottle on the first time. These Bengali Flares were stiked using matchbox striking surface.
    DiabolicusRJamesY23
    Reply 2 years ago
    Somehow, I think survival after civilization's fall will be quite simple for you, hmmm?
    DIYWEAPONSJamesY23
    Reply 3 years ago
    I hope you realise james that many countries do not produce strike anywhere matches.
    davidthefrog
    2 years ago
    hi! to be clear what the article is about is turning 'safety matches' into friction matches, its not the Victorian recipe for 'strike anywhere matches' , so they wont strike on your silver or gold vesta cases ('match safe' if you're reading this in American.
    BenjaminS113davidthefrog
    Reply 2 years ago
    Well it's not the Victorian recipe (victorian matches were extremely toxic), but.....maybe these might? I know they will strike on the seat of your pants. That said, they are way more dangerous, as they are extremely volatile. http://www.brainfoo.com/match-projects/strike-anywhere-matches-extreme/
    Cole Rorich
    3 years ago
    could you could use metholated spirits instead of water to reduce the drying time?
    3nertiaCole Rorich
    Reply 2 years ago
    Not sure the phosphorous would dissolve in alcohol
    f1dd13r
    2 years ago
    fantastic I am going to try this. I was just looking at the cost of buying some on ebay and it was ridiculous..£3 for a few little matches
    davidthefrogf1dd13r
    Reply 2 years ago
    buy swan matches at your local Morrisons for £1 per 4 box pack.
    agis68
    3 years ago
    interesting issue...thanx for spread it. Anyway you can take phosphorus also from a dozen of things we use...(fertilizer containing Ph, Bones take any bone and just polverized it (not very old thow), If you have any old TV smash the screen and collect the Ph etc). If don't like after drying the head of some matches drop down use with water glue mixed with water....and get the best result....Also making the matches cover them with aluminium foil (all of them). The reason is simple....these matches are really sensitive in heat and shakings.....enjoy
    lmaccaskillgaieb
    Reply 3 years ago on Introduction
    Did you attempt to read the directions?
    Step 1: Sanding of phosphorus
    RobleyMlmaccaskill
    Reply 3 years ago
    I had to look closer also. The instructions say that, but it appears on the picture that you use the matchbox as the sanding tool to remove phosphorus from the block in the picture.
