String Fountain
75,778
558
61
About: I am organic computer running poetic software. Interested in overlaps and antipodes. Fascinated by how metaphors shape our thoughts and objects. I've been wondering when you'd show up and send me a note.
The challenge, how does one present 50's synchronized swimming, or water works like the Bellagio fountain in Las Vegas, without water. Pushing string with a motor is not a new idea. Adding servo motors and a microcontroller to create automated and interactive installation is what I was looking to do during my residency at Autodesk's new facility on Pier 9.
This Instructable goes through the assembly of one of my 1/4 scale string fountains. The second image above is 6 string fountains arraigned in a circle moving string though the air.
Enjoy.
Step 1: The Parts
Here they are all laid out. Always be knolling, or so they say.
I've attached a .zip file with all the STL files. I printed all the parts except for the base on an Objet Conex 500. The base plate was laser cut out of 1/8" acrylic.
McMaster Carr parts.
16pcs - 94150A305 - M2 Stainless Steel Nuts
4pcs - 90116A009 - M2 X 5mm Philips Head Machine Screw
6pcs - 90116A010 - M2 X 6mm Philips Head Machine Screw
10pcs - 90116A015 - M2 X 8mm Philips Head Machine Screw
3pcs - 90116A113 - M2.5 X 10mm Philips Head Machine Screw
4pcs - 90116A114 - M2.5 X 12mm Philips Head Machine Screw
3pcs - 90116A1531 - M3 X 8mm Philips Head Machine Screw
1pc - 90263A1165 - Shoulder Screw, 3mm Diameter X 8mm Long Shoulder, M2 Thread
1pc - 1265K311 - Metric Miniature Type 316 Ss Drive Shaft, 3 Mm Od, 200 Mm Length
3pcs - 7804K1249 - 3M X 6M X 2.5M Stainless Steel Bearing
3pcs - 7804K1269 - 3M X 8M X 4M Stainless Steel Bearing
36pcs - 96415K693 - 316 Stainless Steel Precision Ball, 3/32" Diameter
Tower Hobbies
1pc - LXXJW4 - Great Planes Rimfire 250 Outrunner Brushless Motor
1pc - LXKSY2 - Great Planes Silver Series 8A Brushless ESC 5V/1A BEC
1pc - HMXE7625 - Heli-Max Pro Linkage Set MX400
2pc - LXLGJ5 - Hitec HS-65MG Mighty Metal Gear Feather Micro Servo
Step 2: Attaching the Secondary Servo to the Servo Assembly
Gather the part for this step.
Slip the nut into the nut slot.
Thread the servo wire through the back of the servo bracket.
Tilt the servo so the wire exit is inside the servo bracket.
Gently tilt the top of the servo into the servo bracket.
Slip a nut into the nut pocket.
Secure the servo to the servo bracket using the screws.
Step 3: Attaching the Primary Servo Horn to the Primary Servo
Gather the parts for this step.
Push the nuts into the nut slots.
Rotate the servo to find the center of travel.
Secure the servo horn to the servo with the screw.
Step 4: Attaching the Primary Servo to the Servo Assembly
Thread the servo wire though the back of the servo assembly.
Slip the servo into the servo pocket.
Press the nuts into the two nut pockets.
Secure the servo to the servo assembly with the screws.
Step 5: Building and Assembling the Secondary Servo Horn
Collect the parts required for this step. Note the servo ball and the black screw are part of the servo linkage kit.
Push the nut into the nut pocket on the servo horn.
Slip the screw into the servo ball and tighten onto the servo horn.
Adjust the servo so that you're attaching the servo horn in the middle of it's travel.
Secure the servo horn to the secondary servo as shown in the last image.
Step 6: Building and Attaching the Rear Bearing Assembly
I decided to use a second bearing on the primary servo. It stiffened up the design quite a bit.
Push the nuts into the nut pockets.
Press the shaft into the rear support.
Press the bearing onto the shaft until it is flush with the shaft.
Now press this assembly into the back of the servo assembly as shown in the last image.
Step 7: Assembling the Base and Attaching the Servo Assembly
Mount the feet on the base. The base is symmetrical so you can mount the feet on either side.
Mount the servo assembly to the base.
Step 8: Building the Rotor
This is the assembly that 'pushes' the string. I used an outrunner motor so I could hide it in this assembly as opposed to having it stick out the side of the String Fountain.
Press the motor rotor into the back plate. Note the location of the holes in reference to the motor rotor. Do your best to line them up.
Press the front plate onto the motor rotor.
Secure the front and back plate together with the screws.
Step 9: Building the Stator
Feed the motor stator wires through the slot shown in the second image.
Press the motor stator on the spud. Note the exit location of the wires and do your best to line them up.
Press the bearing into their pockets.
Press the nuts into their nut pockets.
Step 10: Assembling the Stator and the Rotor
Slide the rotor assembly into the stator assembly.
Attach the shaft clip onto the shaft.
Step 11: Building and Assembling the Idler Wheel
Press the bearing into the idler wheel.
Press the lock nut into the nut pocket.
Slide the shoulder bolt into the bearing on the idler wheel and secure to the stator housing.
Step 12: Building and Assembling the Slew Bearing
This part of the design proved to be the most difficult to design. I wanted to keep the cross section narrow. Adding additional bearing to the motor assembly meant they would be spinning at the speed of the motor and feeding back into the servo assembly. After a bit of experimenting I ended up with this design for the slew bearing. Here's the proof of concept, 3d Printed Bearing.
Push the nut into the nut pocket.
Slide the screw through the servo linkage ball.
Secure the servo linkage ball to the bearing retainer.
Place the slew frame over the motor assembly.
Roll the bearings in. This is way more fun than you can imagine.
Place the bearing retainer over the bearing.
Secure the bearing retainer with the screws.
Step 13: Connect Drive Assembly to Position Assembly
Feed the wires for the motor controller through the servo assembly, as shown in image 2
Feed the wires through the slew frame, as shown in image 3.
Use the screws to secure the slew frame to the servo assembly but don't them tighten yet.
Adjust the wires so they are equal in length and lay flat between the slew frame and the servo assembly.
Connect the motor wires to the motor controller wires.
Adjust the motor controller wires until you have enough wire to allow the motor assembly to move up and down with out straining the wires.
Take up the slack and then tighten the screws.
Step 14: Secure Motor Controller
Slip the remaining motor controller wires through the servo assembly where the servo wires exit.
Slip the motor controller into the notch provided above the secondary servo.
Step 15: Thread String and Secure Cover
Slip the string between the motor rotor and the idler wheel. Just like flossing your teeth.
Rest the string in the string entrance and the string exit.
Press the bearing into the motor cover.
Place the motor cover over the motor assembly.
Secure the motor cover with the screws.
Step 16: Secure String Guide
Place the string guide in the string guide notch.
Secure the string guide with the screws.
Step 17: Attach Servo Linkage
Snap the servo linkage onto the servo balls.
Step 18: Double Check Your Fasteners
Make sure all your fasteners are tight. After you're happy with the assembly go back through and use blue Locktite on all the fasteners. The String Fountain has been known to vibrate a screw loose from time to time.
Step 19: Connecting a Microcontroller
I'm using Pololu's Maesto series of motion controllers to control my string fountain. You would only need their micro model to control one string fountain. You can also use an Arduino or any other microcontroller that can PWM RC servos.
Step 20: Video
Here's a video of a string fountain, enjoy.
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
61 Discussions
This project is amazing. Lovely to watch, brilliantly created - your mind is a marvel, and I love reading about your process.
mhaeg
4 years ago on Step 2
Can you help with a base measurement I should be following when sending the STL files to the 3d printer?
Salvagionemacrumpton
Reply 4 years ago on Introduction
Yes, but for ~10x the cost. The RC motors with controllers cost ~$90 each. Maxon motor and controller cost ~$1500 each.
helipr0Salvagione
Reply 4 years ago
why not try cheap china made motors and esc's?
macrumptonSalvagione
I wonder if you could propel the string with compressed air, eliminating motor, bearings and wheels, and maybe even the noise (with a remote compressor).
I thought about that. It's nosier and you have a condensation problem, the nozzle cools as the air exits and water condenses on it.
Chamburn
I am looking to make a mini version of the dancing but not as complicated as the bellagio fountain and what I am interested is that the materials you've used, are they the same as they do not appear waterproof?
SalvagioneChamburn
Chamburn, that's a different project. I designed the string fountain to create a fountain like effect without water.
ChamburnSalvagione
Ohh okay, But I really like the way that the servo is used to control movement and hopefully I can use it to control the movement of the pump and lights for the added effects....
Very nice. I like the colours you introduced in the string and the tilting movement. We made something similar some years ago. Have a look at this one , slightly scaled up ;-)
http://www.troika.uk.com/project/persistent-illusion/
