Sugru Wax Seal Stamp
25,840
117
17
About: Travelling since 2013. I'm currently in Australia for some reason. --- I’m Calvin Drews, and I love to learn, experiment, invent, create, repair, and generally just do things myself. A sort of modern jack o...
Make sure to check out my blog!
Here is a little 'ible on how to make your own wax seal stamp!
Supplies:
Step 1: What You Need
Pasta machine
Sugru
Pen
Linoleum block print cutter (make your own here, it's the last 3 steps)
Wooden block for a handle
Sealing Wax (make your own here)
stamping ink *optional*
Aluminum foil
Step 2: Sandwich the Sugru
Mix up your Sugru, flatten it into a pancake, and sandwich it between aluminum foil.
Step 3: Pasta Machine
Put the Sugru-foil sandwich through a pasta machine with the gap set to about 3 or 4 mm
Step 4: Peel It
After putting the Sugru through the pasta machine a few times to make sure it's flat and consistent, wait 1 hour (so it can cool to room temp and be less sticky. If you want, you can put it in the fridge but DO NOT FREEZE IT).
After that, you should be able to pull one side of the aluminum foil off the Sugru. You need to expose one side to the air so the Sugru can dry.
Now that one side it exposed to the air, let the Sugru dry for 24 hours.
Step 5: Peel It Again
After the Sugru dries, peel the aluminum foil off the other side. Be very careful not to tear anything!
Step 6: Making the Handle
Glue a block of wood to the Sugru-pancake, and then trim the excess Sugru off.
Step 7: Carving
Draw out your design on the Sugru, remember that it will be reversed when you stamp it. After that, use a linoleum block print cutter to carve out your design.
 If you don't have a linoleum cutter, you can learn how to make one here (the last 3 steps)
Step 8: Final Product and Uses
All done! You can use your new stamp for two different things: You can stamp it into seal wax, or you can use it just like a rubber stamp!
Use it to authenticate letters, documents, or whatever you can imagine!
Runner Up in the
Sugru Contest
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    17 Discussions
    thepeltona chemist
    All right, maybe it isn't, but I would probably use the latin alphabet, or recognizable pictures. OK?
    caitlinsdad
    A personal seal is a tradition in Asian countries(http://en.wikipedia.org/wiki/Seal_(East_Asia). I remember getting a chop with my Chinese name engraved in it when I was a kid and that was the coolest thing to have. I think I'll try to make some other chops with your technique.
    bart_eu
    In my opinion the pattern looks almost as "hands of god". Check it out if you don't belive me: btw it is not my site!
    http://kachina2012.wordpress.com/2010/09/05/rotassator-magic-square-knights-templar-treasure-hands-of-god-theory-of-everything/
    nepheronbart_eu
    haha! You're right! Unfortunately, the similarity is merely coincidental :)
    bluesquirrelnepheron
    I forgot to ask in my above comment; where can one acquire Sugru? this is the first I've heard of the substance.
    bluesquirrel
    Inventive, easy, and a trick I can use in the future for some of my own projects!
    Awesome as always!
    Kaelessin
    ooh nice idea! i've wanted a stamp for a while now but carving soapstone kinda scares me since i'm so cheap! this is perfect!
