SunCalc: How Much Sunlight Is My Plant Getting? a Sun Light Calculator for Plants
7,113
109
11
In this instructable we are going to show you how to build a very useful Sunlight Calculator with a basic DIY Tools using Arduino. Find out how much light your plant is actually getting through the day with this nifty device!
Supplies:
Step 1: Parts You Will Need:
  • Parts List:
  • Flora
  • Neopixels/ Led lights
  • UV Sensor
  • Lithium Battery
  • Optional: 3d printing resources
  • 4 band Resistors ( 320 W)
Solid Wires (lengths do not include exposed ends):
  • 2-inch lengths (4)
  • 1 .5-inch length (3)
Tools:
  • Wire strippers
  • Wire cutters
  • Small pliers
  • Scissors
  • Soldering Iron
Step 2: Step 2: ​Connect Wires Between the Pixels, UV Sensor, Battery, Switch and the Flora Board
  • Following the diagram below, securely connect all wires.
  • Do not solder the UV sensor wire on just yet. If you are following Step5 to add on the in the 3d printer pieces.
  • Be sure not plug in more than 8 led's at a time it might cause the Flora Board to break.
  • Be aware that the wiring is done gently, and it is ideal to apply some electrical tape to keep them in place, as if they could interrupt the data flowing through the wires.
Step 3: Step 3: Load the Code Onto the Flora
  • Download this Arduino software, we used the provided link specifically because it included the Arduino Adafruit Library.
  • "Download SunCalc Code" folder attached, and make sure you save it in the "Library" folder.
  • Under tools of the Arduino.ide select the "USB Modem" and "Flora Board" and open the .ino file.
  • Verify the code and after it's Done Compiling you can plug in the Flora board
Step 4: ​Step 4: 3d Printing the Casing
  • Download the latest Fusion 360 Software.
  • Click on Download 3d folder to get the 3D printing files.
  • Open the four .Stl folders on a desktop connect to a 3d printer. ( We used a UP! Mini 3D Printer)
  • Part2 Top Half and Part3 Bottom Half should take about 2 hours to print
  • Part1 Ring and Part4 Stick should take about 15mins to print.
Step 5: ​Step 5: Adding the Battery & Switch
  • Take the red (power) and black (ground) wires from the battery, cut them in half, and use a multimeter to make sure which was ground, and put the switch in the middle.
  • The switch has 3 prongs. Put ground in the middle, and power on the right, nothing on the left (so when the switch is flipped left it should interrupt power and be off).
Step 6: Step 6: Case Assembly
  • Gently place the Flora board and the connected parts on the Part 3 Bottom Half of the case
  • Take the Part 1 Ring and thread the UV wires through it and solder the UV sensor
  • Connect the Battery and place it inside the case along with all the other parts, test the model and once everything is working as planned. It's time for placing the Part 2 Top Half
  • Make sure the led's and switch are visible through Part 2 Top Half, use a few drops of hot glue on the edges of the LED strip to make sure they stay in place
  • Snap the Part 2 Top Half and Part 3 Bottom Half together with drops hot glue in the joints, hold the Part1 ring in place while holding the case shut tightly while the glue settles
  • Hot glue the Part 4 Supporter to the bottom of the case.Your SunCalc is ready!
Circuits Contest 2016
Fourth Prize in the
  • IoT Challenge
    IoT Challenge
  • Classroom Science Contest
11 Discussions
Chitlange Sahas
2 years ago
Congratulations! You are a finalist!
Are you from India?
DonnH1
2 years ago
This is a nifty idea. I recently had several double pane windows replaced because their seals had failed. The replacement modules are built to modeern codes and so block UV and some other parts of the light spectrum.
GayatriG5DonnH1
Reply 2 years ago
Woah! I didn't realise window panes can now block UV.
EmmitSGayatriG5
Reply 2 years ago
glass always did block UV. Now they have acrylic that does it too.
DonnH1GayatriG5
Reply 2 years ago
Yup they can. No more fading of upholstery close to a window if the windows are of recent design. Poor plants don't do well by them either, they don't get all the spectrum they need to thrive.
Yonatan24
2 years ago
Nice! Voted.
It's up to you, but I think a title like "SunCalc - A Sunlight Calculator for Plants" would be even better than "SunCalc: How much sunlight is my plant getting? A Sun light Calculator for plants"! :)
GayatriG5Yonatan24
Reply 2 years ago
I agree, but somehow I cannot update by post anymore ( it that a instructables thing?)
GayatriG5tcman2006
Reply 2 years ago
https://www.youtube.com/watch?v=TXIT_Whr6BQ ( its on there)
Swansong
2 years ago
This would be really helpful for more finicky plants to be sure where to put them. :)
