DIY Embossed Pendants!
34,635
414
80
About: Hey, I'm Muhaimina! A crazy craft addict! Obsessed with swirls and polka dots... Love green craft and rustic home decors... and Instructables is pretty much my second home!
It feels great to wear handmade jewelries and feels greater when you make your own jewelries :) In this instructable I'll show you how to make embossed (look alike!) gold and silver pendants in 5 easy steps. I'm sure you'll have fun making these pendants.
Lets start!
Supplies:
Step 1: Materials Needed
To make these pendants you'll need:
  1. Card-stock paper,
  2. Pencil,
  3. Scissors,
  4. Glue,
  5. Awl,
  6. Jump ring,
  7. Gold acrylic paint,
  8. Stones.
You might also need pen or pencil and paper to draw some designs for the pendants.
Step 2: Making the Pendant
Take a piece of card-stock paper and draw 5-6 circles of the same radius.
Cut out the circles with the help of scissors.
Glue the circles together to create a thick pattern.
The pendant needs to be black. In case you use card-stock paper other than black you'll have to paint it in black.
After the paint dries, use an awl or anything pointy to make a hole on the pendant for attaching a jump ring.
Step 3: Preparing White Glue Cone
Take a piece of thick polythene paper and cut it into a square shape. Start rolling the paper from one corner to form a cone shape and use a small piece of scotch tape to tape the sides. Make sure that the hole on the cone isn't too big, otherwise you won't be able to make detailed designs. Fill half of the cone with white glue.
Alternative: You can also use white glue tubes. To get thin design I used clear tape to make a small cone on the tube as you can see in the last picture of this step.
Step 4: Designing the Pendant
Before starting to design the pendant you can draw some designs on a piece of paper. If you're not familiar or used to making designs using cone, then you should practice a little. Be sure that you're ready to get started!
Carefully and slowly press the bottom of the cone and design the pendant as you want. Too much details might smudge the whole design, so be careful.
Once you're done designing, allow the white glue to dry. This might take some hours.
Step 5: Final Touch
After the white glue dries you'll need to apply a coat of gold acrylic paint on the pendant.
Dip your finger into the gold acrylic paint and apply it over the designed pendant. After the paint dries attach a jump ring to complete the pendant.
Wasn't that fun and easy? You can make pendants of different shapes and also use silver or metalic acrylic paint
Enjoy :)
Jewelry Contest
Second Prize in the
Jewelry Contest
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    80 Discussions
    siddhi38
    4 years ago on Introduction
    This is fantastic...I wanted to make the Aztec pendant,the one shown in The Pirates of Caribbean.You are really helpful...
    Nekolove02
    5 years ago on Step 5
    Do you have to use that specific paper for the cone? and where do you get the jump rings?
    Muhaiminah FaizNekolove02
    Reply 5 years ago on Step 5
    Thick polythene paper will do. you can make jump rings from wire by using the looping plier, here's a tutorial- https://www.instructables.com/id/Paperclip-Jump-Rings-No-way/
    or you can simply buy them from craft stores or online stores.
    valkgurl
    5 years ago on Introduction
    Using contrasting paste or even liquid SHOE POLISH will help to give you the "aged" look on these---use a SMALL amount on either the high or low spots--you will want to try each!---and buff off.
    You can also use sheer color markers---not Sharpies unless they come in a less coverage version than I have---to color these---prob work better on the silver ones. And SEAL THEM! Use hair spray or clear Krylon or else you will have paint and etc all over your clothing!
    Great idea! I can also see adding things to these with "rivets" easily made from office paper fasteners---and other items. Hmmmmm-----
    Thank you for the suggestions! I'm glad you took your time to see my ible :) I'm going to keep them in mind next time :) Thanks again!
