Super Lightweight Fixie and Single Speed Bike Mudguards
136,452
322
24
This instructable takes a huge chunk of inspiration from a pre existing lightweight rear mudguard that is already commercially available. I have adapted the design slightly and, in addition, created a small guard for the front wheel.
These mudguards are small enough to keep in the bottom of your bag for whenever you may need them AND this whole instructable cost me only £1!!!
Supplies:
Step 1: Find Your Material!
You need to find a suitable plastic material with which to build your mudguard. I considered using the thin plastic sheeting that document folders are constructed from however i decided it could end up being a little flimsy. I found this multi pack of flexible kitchen cutting boards in a super market for £3. The material that they are made from is flexible, strong and light. A single cutting board will be enough to make both front and rear mudguards.
Step 2: Mark Out the Rear Mudguard
I managed to source the outline of another popular lightweight mudguard and used this as a starting point. I lengthened the design slightly. The final stencil will be uploaded in the final step of this instructable. I used a Stanley knife to make the cuts although you can get away with using scissors.
Step 3: Hole Punch and Score
I used a normal hole punch to make the holes and then realised that I should have just used a normal drill bit as the holes need to be quite a bit bigger. These holes will clip onto the underside of your saddle.
I chose to score a line down the middle of the mudguard on the top side. This scored line will allow the plastic to flex upwards much like a conventional mudguard.
Step 4: Mark Out and Cut the Front Mudguard
There should just be enough material left to create the front mudguard. I used a very similar design as the rear guard. As there isn't anywhere useful on the front forks to attach this one to you'll have to use a rubber band to strap it to the underside of the bike frame.
Make two holes and link them with a single slit. The rubber band will loop through these holes and over the frame.
Step 5: Clip the Pieces in Place
The rear mudguard slips underneath the bike saddle and the punched holes slip around the seat support. Use a rubber band to attach the front guard to the frame.
Step 6: Take Them for a Spin
There we have it. A very easy, very quick and VERY cheap mudguard solution for your fixie or single speed bike. Keep them in your bag for emergencies and there will be no more soggy arse syndrome for you.
Print the stencil at A4 size.
Step 7: The Good People From Ass Savers Have Been in Touch!
This instructable is basically an adaptation of the Ass Saver (http://ass-savers.com). The good people at Ass Saver have kindly offered us the original ass saver template and even recommended the perfect plastic to use. They recommend using the plastic that comes from flexible document folders (as pictured). Help yourself to the PDF copy of their brilliant template.
I had to use these myself recently when it started raining whilst I was at work. Luckily a plastic folder was close to hand!
Bikes and Wheels Contest
Runner Up in the
4 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Party Challenge
    Party Challenge
  • Fandom Contest
    Fandom Contest
24 Discussions
keith.maclure1
4 years ago
Just found these clever designs and was thinking i might try printing a design on some light card, then laminating it... Well done folks!
Harvard82
4 years ago
Like the Andre the Giant sticker...
binarybug
4 years ago on Introduction
excellent idea! I built my fixie last Friday and as rain is forecasted for tomorrow I needed a mudguard solution urgently. I didn't have the right material, so I had to improvise a bit with plastic that isn't flexible enough (long live duck tape :)
can't wait to go to a local "dollar shop" and get some suitable plastic to make mudguards!
thanks for posting!
Mr Chutneyasssavers
Reply 5 years ago on Introduction
Ha Ha!
That's fantastic! I was almost certain that you'd be in touch at some point to ask me to take it down! I'll add the template and materials to the step by step guide ASAP. I'm sure all my fellow instructable members will be very grateful.
Many Thanks!
about_time
5 years ago
I just used an empty plastic Celebrations chocolate tub. It did say 'reuse me' on the side.
fincape
5 years ago
Nice one, thanks!
blacky94
The design works great, thanks!
I tried it with the Drälla chopping boards from IKEA (http://www.ikea.com/us/en/catalog/products/50153123/?query=dr%C3%A4lla). It worked great for the first few weeks, but at some point the platic just broke at two points because it was under constant tension. Now I made it out of a plastic file which has a much thinner plastic. Lets see how that works out!
Mr Chutneyblacky94
Thats fantastic!
Always good to hear of people having some success. The plastic file is a great idea, I imagine that it's a better long term solution. The handy thing is that they only take seconds to make with a thinner material so it doesn't really matter even if they do brake! Winter is swiftly on its way so I will be making much more use of mine as well. Well Done!
gonzhi1961
5 years ago on Step 5
This really works!!! Thanks for the idea!
gonzhi1961
It's rainy season now here in the Philippines...this idea is just what i have in mind! good thing it turned out I have some flexible kitchen cutting boards stored in our kitchen cabinet...I will post soon if the mudguards really work well...am excited to start on this project!
velochk
5 years ago
Have you thought of using zip ties instead of rubber bands? Id prob keep mine on all the time cause it rains here too often. Great idea! Thanks!
Mr Chutneyvelochk
Reply 5 years ago
Excellent suggestion, I like to remove mine but zip ties are fantastic for this sort of thing. Cheers!
Advar
Oh, sweet snaparoni, soons I get home after my McDinner, I'ma gonna try this with some of the stiff ol' roof rubber I've got! Thanks :)
GarGon
5 years ago
excelente idea!
