Super Long Ethernet Cable
48,772
20
40
About: Right now I am searching for satisfaction in my life, a purpose bigger than me and true happiness. My hope/prayer is that my Lord and savior would use my life in this. 2011/2012 -- UPDATE BELOW 11/01/2013 -...
Do you have a really long cat.5 cable laying around with no ends well if you do I can show you an easy way to use that long cable for a really long high speed ethernet cable.
Step 1: Get the Stuff!!
you will need the following
One standard lenghth cat. 5 ethernet cable
The stock cat. 5 cable of your desired length
Pin nose pliers
Electrical tape
knife of some sort.
Step 2: Cut the Standard One in Half Cleanly
Just fold the short cable in half and cut it with clips or a knife.
Then cut off about an inch of the insulation off both cut ends.
Step 3: Clean Off the Ends
Expose each individual wire on every end of all your wire ends.
Just enough to twist each together
Do the same to your stock wire
Step 4: Now for the Splicing
You have to match the colors on each wire and twist them individually. ( if you want you could solder each wire but that would take a lot of work)
There is a chart of the colors at the bottom of this site.
There is a couple wires that are hard to tell what they are.
http://en.wikipedia.org/wiki/Ethernet_cable
When you twist one together use electrical tape to shut it off or you could fry something maybe....
Step 5: After Doing Each Side
now rap the whole but off your twisties together with a good amount of tightly wound electrical tape
Step 6: Test It
Test it on something that isn`t as important so it doesn`t mess something up.
I am not responsible for any shorts that probably has to do with matching the colors wrong...
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    40 Discussions
    coveylane
    2 years ago
    Jeez.. you try to help someone and all you get is complaints.... even about building inspectors. If you are used to doing things yourself and a building inspector goes to your house, he'll probably shut you down long before he gets to your ethernet cable.
    coveylane
    2 years ago
    Thank you.
    Your instructions worked great for me... no problems.
    prototype_mechanic
    3 years ago
    i'm righting articles abaut csbles/technologies....
    those wires are used in gigabit connection. ethernet 2pairs, gigabit 4pairs. also thise pairs csn be used as second link, trunk, poe...
    on photo my cable 130m long in gigabit mode
    Klaudiuszm
    7 years ago on Introduction
    I like the idea but it seems a bit excessive. Why not just strip away some of the insulation and crimp the cable? It seems the more professional and it would probably be stronger. Although, for those who need a long cable and do not have crimping tools, I suppose that this is a possibility.
    sokamiwohali
    Refering to a comment you said a few comments down, just because its DIY doesnt mean that doing it the RIGHT way to prevent potential probs. down the road is not DIY. if YOU crimp the connections...YOUR Doing It Your self.
    The problem you run into with CATV cable at great distances is that after so many feet, the signal becomes weak. when this happens, you might as well have signed up for dial-up internet. you see After so many feet when the signal starts to drop off, you need an amplifier that makes the signal carry on longer. The same thing goes for Coaxial Cable. except the signal dropoff is more sever with COAX.
    lperkins
    7 years ago on Step 6
    Ok. Two things here:
    First, don't plug this into any network that you don't personally control without permission. That kind of splice is extremely susceptible to interference, potentially causing packet corruption, which can screw up not only your connection, but possibly those of other people on the network. Modern equipment is better at filtering out bad packets than the older stuff, but it can still cause unpredictable issues that are hard to track down. If you use one of these in your dorm room don't be surprised if you suddenly find that your network connection has been shut off. Also don't be surprised if your network throughput goes to heck since interference will mangle your packets and they may have to be resent several times.
    Second, the length limit for wired ethernet connections is 100m. (64 byte-times multiplied by the speed of electricity through copper.) This includes any cable that may be in the wall between you and the network switch. Attaching a long cable that puts the total length over this distance will cause what are called "late collisions" which can potentially bring down large segments of the network and are very difficult to track down.
    Your best bet is usually to go down to the nearest Home Depot equivalent where they sell bulk communications cable and get whatever length you need along with a crimper and a box of plugs. You can probably earn enough making custom-length cords for your friends to pay for the tools.
    Your second-best bet is to get one of the splice connectors that let you plug a cable into each end and just hook your two cables together. The connectors usually cost less than a dollar.
    If you find you _must_ splice a cable in this manner, keep the amount you untwist it as short as possible (about a centimetre if you're dexterous) and solder the wires together, preferably without twisting them around each other. Then polish the solder joints to assure that there are no sharp points which will emit and pick up interference. Then coat each joint individually with fingernail polish and wrap it in electrical tape. Then borrow a cable tester and see how good a job you did. If it meets Cat3 standards, then it will handle 10MB/s. Cat5 will handle 100MB/s. Higher than that should be capable of gigabit. Set the speed of your network card accordingly.
    ab727
    I did this - because I couldn't find a new cable during the holiday season. And I am facing some problems so I searched for ethernet and landed on this page. Please, if you could help me out.
    I twisted all the wires. The connection kept getting off. I discovered that a small twist of the green wires and the connection would come on again. After many twists and turns the wire broke. When I stripped the wire (green) and tried to make a connection by twisting, it failed to work. I was peeling the wires with a razor blade and I thought why not touch the wires to the blade and it being a metal would complete the connection. And it did. The strange part starts now. The connection comes off many times and all I need to do is touch the 2 ends of the green wire to the blade and the connection comes back on. After it is on the green wires need not be connected. So the green wires stay disconnected but whenever the connection turns off I have to retouch the green wires to the blade.to get the connection. Whenever I switch off/on my lights or fan the connection comes off but all I need to do is to touch the green wires to the blade and the connection is back on. What is happening over here? Any way I can get a more stable connection till I can get a new wire? Please help.
    gamer
    11 years ago on Introduction
    you only need the green, green/w, orange, orange/w for 10/100 base networking. i did this with a telephone wire (4 wires) and i only connected the ones listed, it worked out great. then... i made another one for my mom, and it doesnt work, im gonna have to troubleshoot it. anyways. nice instructable. very detailed, i guess. -gamer ps. i do recomend soldering the wires.
    Tachyongamer
    Not quite true. While no data passes on the other wires in 10-100M/bit connections, Gigabit uses all the connections for data. Also, even in 10 and 100 connections, the other lines are grounded and form an RF shield because they are wrapped around the signal lines with a number of twists per inch that is lower than the wavelength of the carrier signal. It works like a Faraday cage in that regard and helps minimize crosstalk. Other posters are correct in that this setup will likely generate a lot of errors and retransmits. I also agree that given how cheap crimp-less connectors are, this project doesn't make a lot of sense except for maybe in an emergency. Also kids, always remember, say no to 568B for new installs. 568A is A-OK. white-green/green, white-orange/blue, white-blue/orange, white-brown/brown Tachyon
    LancealatorTachyon
    The point of this instructable is to make a very very cheap cable that will work just fine for internet browsing no more no less
    cowenLancealator
    This as a temp cable for one time connection maybe.
    BUTT (yes its a big but)  Never use this for  permanent connection.
    tagno25Tachyon
    I have NEVER seen 568A in the real world other then on crossover cables.  I only see 568B (even on all the premade cables)
    gnumeTachyon
    true and if i remember right even cat5e cable uses all 4 pairs between switches and routers to get 200 mb speed between them
    freerunnin1gamer
    cn u msg me 2 tell me how u did it cos ive got an old ethernet cable and an EXTREMELY long phone wire
    gamerfreerunnin1
    Basically, make sure your phone wire has four (4) and not two (2) wires in it. Then, cut to length, and strip the big outer rubber, and the single little wires. Then do the same for the Ethernet, but only the green, green-white, brown, brown-white.... Choose which connects to which, and your on a roll! Message me to tell me your results, Thanks! -gamer
    gamergamer
    Oh, don't forget to tape everything correctly and safely to make sure there is no shorts.
    Lancealator
    yeah I did this for a desktop computer that was using wireless that was weak and sometimes didnt work so this was a great solution since it actually woked
    cowenLancealator
    Actually worked......
    I have many of those customers.
    I like them the mess makes my bills every month.
    There is a right way to do it with out short cutting.
    I specialize in IT and what you did would not increase the resale value of your house/business.  Doing the job right does.
    An inspector seeing that would red tag you and until it was fixed right would prevent you from resale or occupancy.
    Now you say its low voltage... right and no license is required to do the work but an inspector is not looking at what KINDA wire it is just if it looks professionally done and safe.  Again since I have a business doing this I have to work with the Building and Fire marshal and many times they have no idea what computer cable is so I have a time to explain with a CODE book that they are wrong and why.
    Krade
    Longer the cable, the worse your connection.
