Super Nintendo PC ARTiGO
12,917
32
21
It's amazing what I find in my attic. In a box collecting dust lies my old Super Nintendo. I spent way to many hours on that little machine, I couldn't just throw it away. But all the cartridges were destroyed and the SNES wouldn't turn on, it was dead. I had to bring it back to life. All I needed were some small PC components and an operating system running a Super Nintendo emulator. VIA is known for tiny PCs parts, and the ARTiGO, an all-in-one system is the perfect solution for jump starting my SNES.
Supplies:
Step 1: Inside the ARTiGO
The ARTiGO is tiny! It fits in the palm of my hand, yet it has all the feature of a regular desktop. Go to VIA.com For the full specs. I quickly threw the ARTiGO together ( there's nothing to it) for a test run. It's no hard core gaming rig but its going to do just fine with emulators and watching some xvid movies. The Artigo is so cool looking and small I almost want to leave it that way, but my SNES need a new engine.
Step 2: Gut the SNES
I opened and dismantle the inside of the SNES. Once I was down to the shell, I figured out where I was going to place everything. I removed anything sticking up using a Dremel. Sliced open the right side for the DVD ROM using a hobby knife. And poked a few holes using a soldering iron for the switches, LEDs and power plug.
Step 3: A Quick Test
After dismantling the ARTiGO, I reassembled it inside the SNES body for a quick test fit and using a different power supply from MINI-BOX
Step 4: Fitting Everything Inside
Here's the fun part, fitting everything inside the SNES.
Because of the limitations of the ARTiGO's wire lengths, my plans for placement were confined to the back of the SNES. A bit of rethinking was in order. I decided to use the SNES as a dummy shell, for nostalgia. It's too bad I want to use the big start switch on the top for power and replace the front joystick ports with USB ports. Maybe I'll rewire it later on.
Here the re configured instructions.
The DVD ROM is held in place using double sided tape.
I replaced the DC converter board that came with the ARTiGO with one from MINI-BOX and added the power supply switch to the back of the case.
On the left back side of the case I install the USB ports and the audio connectors.
Place the Mobo and hard drive inside the case and screw it in, connect all the mini connectors.
Step 5: Close Up the SNES
With everything secured in place, it's time to close it up and install and operating system. I'm not going to bore you with the details of "how to install the OS" My choice of OS is the latest edition of UBUNTU and the SNES emulator is, ZSNES! I've used ZSNES on my XP laptop and its awesome! At this point I've got UBUNTU loaded and ZSNES running, I'm still fiddling with the configurations, but I've got my Super Nintendo back!
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    21 Discussions
    ahead1Krazir14
    Reply 8 years ago on Step 2
    you will need to buy a 4mm gamebit screwdriver google is your friend for this use the 4mm gamebit to open the snes
    Jcmaster
    8 years ago on Step 5
    Its kind of a dirty job, i mean the idea is really cool and it loks nice, but when you see the images closer you can see the dirty cuts into the plastic case & the yellowish color of it, it would be better if you paint the snes of grey so it looks like new, besides of that its a great project if i can get one of those artigo pc ill make mine too
    zack247twocvbloke
    that different than the ones in Canada too, i had one and it looked nothing like that
    joemonkey
    9 years ago on Introduction
    i love the instructable, and the directions were clear. great overall.
    the mini-pc idea was a great one!
    just saying, but your Snes looks terrible!
    if you see how the plastic is two-toned, its because of a fault of nintendo's, where an incorrect ballance of flame retardant in the mix caused oxidization which was sped up by sunlight exposure. there is no way to reverse it.
    BadPrenup
    I'm working on one of these now, good Instructable, though a 'How to Install OS' section would have been nice, as well as info on what kind of CD Drive you used and where you got it. Overall nice job.
    BadPrenupBadPrenup
    sorry to double post but you could have also explained how to open the SNES as you need a special tool unless you want to tear it apart and glue it shut =-)
    AnthonyVBadPrenup
    you can buy the "special tool" but i used needle nose pliers, it took some time but i got it. heres a tip, your going to be hacking the heck out of the in side of the snes, if i were to do it again i'd drill out the screws is faster.
    AnthonyVBadPrenup
    its a laptop cd rom drive. you can get one from newegg. and depending on what you get you may need an sata adapter. good luck it was fun!
    Scammah
    10 years ago on Introduction
    I admire the finished product however I do have a question. Isn't this an expensive build? I looked up the ARTiGO and it shows that it's around 300 bucks. Kinda expensive SNES
    ARTiGO
    AnthonyVScammah
    If it was only a SNES then I'd I agree, but It can do much more, there is a full computer under the hood its not very powerful but its a perfect portable e-machine, divx/xvid player plus the SNES isn't the only emulator around. Almost every old console or arcade system is emulated and this puppy can run em all. In my opinion is not a bad deal when u add it all up.
    Technokitty
    I'm grabbing my Dremel tool and heading for the attic right now to see what I can stuff this little Artigo into!
    dsv101
    10 years ago on Step 1
    how big is the built in hardrive
