Super Easy Led Lamp
21,183
104
46
About: Hi, I'm stephen, I'm a certified welder, working on my machinists cert, and working part time at a hardware store. Mixing in all of that with my hobbies of blacksmithing and knifemaking, only makes for more...
A Led lamp that you can make in just a few simple steps.
Step 1: Supplies
9 volt battery snap
9 volt battery
3 colored LEDs (I used blue)
1 glass jar
paper
tape (clear is best)
Step 2: Step 1
Solder the leds together in series (the positive lead connected to a negative on a different LED and so on). Next solder the ends of the LEDs to the ends of the battery snap (make sure you put negative with negative etc.)(the red wire is positive). Then just tape the leds to the battery (point the LEDs different ways so they spread the light better) it should then look like this.
Step 3: Step 2
line the inside of the jar with paper to help diffuse the light (you can also attack the LEDs with sandpaper) (supposedly that works) it should then look something like this.
Step 4: Step 4
snap the Leds to the battery sit the whole bundle in the middle of the jar, sit back and bask in the awesome glowing light.
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    46 Discussions
    holymoses
    3 years ago on Introduction
    "You must be putting way too many volts through your LEDs if your getting hot leds."
    The question is:
    "What does hot mean?!"
    Hot enough to start a fire!
    3.7V can already heat up a LED, but I guess this is what you call "warm"!
    triumphman
    6 years ago on Introduction
    Adding the proper resistor will lengthen the life of the LED. Just FYI
    If your getting enough heat from your LEDs to do anything at all, then you have bigger problems than that. You must be putting way too many volts through your LEDs if your getting hot leds.
    wwdd00
    8 years ago on Step 4
    Something else that may work instead of lining it with paper or scratching the LED's is using frosting spray paint. On a similar project (Sun Jars... http://snipsly.com/2010/07/15/my-take-on-the-sun-jar/).
    techchick
    8 years ago on Introduction
    i'm looking to do something similar. would anyone happen to know how to also connect a type of switch to the battery to turn the light off and on?
    IT would be best to get a toggle switch from radioshack or somewhere.
    Clip one of the leads from the battery in the middle, run one end into a lead on the switch, solder it there, and do the same with the other end. When your at radishack ask one of the guys there, they can usually help.
    mikiaoatombomb1945
    Glue white tissue paper to the outside of the jar...that will diffuse the light too without changing the colour too much.
    I did that to a solar powered version of this that i made...works nicely for my nephew's night light.
    Or maybe you could use a piece of transparency or cut up a clear pop bottle ? I don't think your mom would mind if you sanded an empty cut up pop bottle ; ) Plus I guess you could make it removable that way as well : )
