Super Easy, Three-ingredient Cookies.
100,331
77
29
This instructable is to show you how to make some very delicious, and very easy cookies. The recipe is great for college students, because it only requires a few ingrediants.
How can you make cookies with only three ingredients, you ask? One of the ingredients is cake mix. It's also great, because you can easilly create a different flavour of cookie, by just using a different flavour of mix.
Supplies:
Step 1: Ingredients
Go to the store and buy:
1 Box of Cake Mix (I've had good results with the Betty Crocker Variety). You can get any flavour of normal cake mix, but I've found angelfood and Yellow cake to be particularilly delicious.
2 Eggs
1/2 Cup Vegetable Oil
(Optional) One jar of Nutella.
That is, if you don't already have them.
You will also need a mixer or a beater and a large bowl, and a cookie sheet.
Step 2: Mix Everything Together.
First of all, preheat the oven to 350 degrees.
Measure out the oil and crack the eggs into your mixer. Or, if you don't have a mixer, just use a large bowl and some beaters. Then, open the cake mix and pour that into the mixer, too. Mix it all together until it's a uniform, wet, sticky mass.
Lick the beaters while you wait for the oven to finish preheating*. See, nummy.
*Note: don't atcually do this is you're worried about eating raw eggs. If you do get sick, it's not my fault.
Step 3: Bake!
Scoop out the dough in rounded teaspoons, and plop them on an ungreased cookie sheet. Then, when the oven's ready, pop the cookies in.
After 11 minutes, pull it out, and stick a toothpick into one of the cookies. If it comes out dry, the cookies are done. Otherwise, put the cookies in for another minute.
Once they are done, take the cookies off the cookie sheet and put them on a plate or something to cool.
Then, load up more dough on the cookie sheet, and cook that. Repeat, until you have lots of cookies and no dough.
Step 4: You're Done
Optional (but awesome) step: Spread some Nutella on the hot cookies. They'll still be good without it, but trust me: Nutella with these cookies is CRAZY DELICIOUS.
Then.. Enjoy! This recipe makes about 2 dozen cookies, depending on how big you make the scoops. Share some with your friends, to impress them with your baking skills. Then, next time, experiment with a different colour of cake mix.
  • Fandom Contest
    Fandom Contest
  • Arduino Contest 2019
  • IoT Challenge
    IoT Challenge
29 Discussions
lianoir
10 years ago on Introduction
Soooooooo, Go to a store, Buy a box of cake mix / brownie mix / whatever mix, Read the instructions make a cake. What is the added value of this ?
Saintlianoir
Actually, no, if you took the time to read what he wrote, you'll see he just uses cake mix instead of the usual dry ingredients and makes COOKIES. Not cake. Cookies. With cake mix. And eggs.
SherrieBerriesSaint
Reply 2 years ago
I dont see the point of almost arguing over this. This works wonderfully i have been using cake mix to make all kinds of cookies its convenient and cost less than to buy ingredients to make cookies. Plus you can ket your imagination gi wild. Thats why i dont understand almost arguing ovee this great post.
phoenyxashelianoir
Actually, if I remember correctly (don't have a mix in the house at the moment), the difference is in proportions. I like for a cake, you use three eggs and a bit more oil, which gives a runnier batter and the softer "cake" consistency. Fewer wet ingredients, and you have cookie dough.
Of course, as I said, this is off the top of my head. I'll have to force myself to go to the store and get a box to compare... =grin=
jrehnke
If you want some peanut butter cookies on the fly (w/o cake mix) try just 1 cup of peanut butter, 1 cup of sugar and 1 egg. mix together and bake at 350 about 8-10 minutes. let cool a little before removing from pan. yummmmy!
marymacjrehnke
I've made peanut cookies with 1 cup of peanut butter, 1 cup of brown sugar, 1 cup of flour. I wonder how different your idea might be. One way to test it.
A.led.jandro
7 years ago on Step 3
Delicious, I just make them with a marble cake mix, so I have cookies with vanilla and chocolate flavor.Simply great recipe thanks!
parnham
The best cake cookies are devils food peanut butter
use same recipe but with devils food cake mix and 1/2 cup of peanut butter they are delicious and they never go hard
krysteanuh
Made these today using Betty Crocker Dark Chocolate mix! The cookie dough was unbelievably soft; I don't think I've ever had cookie dough so smooth and consistent before! Plus, they taste AWESOME. Soft like cake on the inside, but with a little crunch on the outside! Thanks so much for the recipe (:
I just wanted to address what some of the commentors said, using a cake mix WOULD be much cheaper than buying a roll of cookies. Here in TN anyway, you can get a cake mix for a buck, buck and half. Pre-made cookies are usually over $3.00. And, like someone else noted, they have a tendency to turn hard as soon as they cool ( which I hate, also.) So a recipe that makes fresh baked cookies that is this easy, is fantastic in my book!
chucytbear
9 years ago on Introduction
cool. i bet if added, like m&ms,choco chips,or..... uhhh white choco chunks it would be awesome
Karin Driver
10 years ago on Step 1
I just made the cookies with Duncan Hines Pineapple supreme mix. It made just a hair of 3 dozen cookies. The only thing I did differently was sprinkle some cinnamon and sugar on them. They were delicious!
M. Gyver
I tried this with chocolate cake mix. They were tasty. Oddly, they tasted like brownies. Meaning I used cake mix to make cookies that tasted like brownies. I almost frosted them to complete the circle. I'll probably try again with a different mix. The angel food sounds really good. Thanks for the idea.
KABUKISTARM. Gyver
Cake mixes with little chunks of things in them, like "Cherry Chip" and "Funfetti" usually turn out pretty well, with this recipe. Also, Yellowcake is one of my favourites.
Calista
I just made these, and they look/taste delicious. They're perfect for me because I can't stand cookies that get hard and stiff at ALL which normally leads to me trying to eat them right out of the oven and then giving the 11 left over to my family. They love it, but me, notsomuch. Thank you so much for this!
dung0beetle
awesome! I love the idea. I am not a college student, but I am broke most of the time :P I wonder if it is microwaveable...
KABUKISTARKABUKISTAR
Ok, I tried this recipe cooked in the microwave today, and I wasn't too pleased with the results. Maybe it's because I'm a noob to the whole microwave baking thing. First I tried putting several cookies on a plate, but they puff out so much in the microwave, that it became a huge conglamorate mess when they were done cooking. I ended up having to put each cookie on its own small plate and microwaving two at a time. Waiting for the cookies to cool, scraping them off the plate, and putting two new piles of dough on each cycle ended up being pretty time-consuming. I think it would have been easier to just bake them in the oven. The cookies came out pretty flat and thin this way, as well. Also, they cooked from the inside out, so they didn't get any browning on the outside. If anyone wants to try cooking these in the microwave, I found that it took 45-55 seconds on high to cook two cookies. Of course, check them with a toothpick to make sure they're done, as well. I'd still reccomend using a conventional oven, though, if you have that option.
