T65 Top40 Phone
2,290
16
About: Grotius College Heerlen
In this Instructables we will show you how to use an old PTT type T65 phone to make a jukebox out of it. You'll be able to pick a year between 2000 and 2016 and you will be able to pick a song from that year's Top40 using the dial disc.
For this Instructables you'll need:
  • a Raspberry Pi Zero
  • an old PTT phone
  • an Adafruit Speaker Bonnet
  • some cables
Special thanks to our teacher who came up with the original idea and helped us with this project.
Step 1: Open Up the Phone
The first thing you'll need to do is to open up the phone using a screwdriver. Remove the bell from the inside so that you'll have more space for the Raspberry Pi Zero.
You'll see 4 cables under the dial disc (see the picture)
  • Loosen the yellow cable and connect it to Rd on the phone.
  • Add an extra cable to connect Bl to Rd on the phone.
You'll connect the other cables at step 3.
Step 2: Add a Speaker Bonnet
We will be using a Raspberry Pi Zero, so you won't have a headphone jack, You have to add a speaker bonnet. We will use the Adafruit Speaker Bonnet.
Solder the Speaker Bonnet onto your Raspberry Pi Zero. To see a step for step manual, see their website at the end of this Instructables.
Step 3: Connect the Wires to the Raspberry Pi
After finishing the Speaker bonnet, you are able to connect the remaining cables:
  • Loosen the red cable and solder it to a female cable so that you'll be able to connect it to GPIO25 on the Raspberry Pi Zero.
  • Loosen the blue cable and solder it to a female cable. Connect it to Ground on the Raspberry Pi Zero.
Step 4: Pick Your Songs
Sadly, we didn't find a way to stream music using the Raspberry Pi, so we downloaded the music using a faster way.
We wanted to use the 40 most popular songs of different years. We used the website top40.nl for this. This website has a column called Special Lists which contains the 100 most popular songs a year.
We viewed the website's html-code using F12 and copied the line including the songs. This line contains more than the URL's of the songs, so we used regex101.com to be able to only pick the URL's of the songs. We wrote http:(.*?).m4a in the Regular Expression box to find all the songs starting with http: and ending with .m4a.
We used the program uGet to download all the URL's. After this we named them according their popularity from the top40 site (eg. 01, 02, 10, 40). Sadly, Pygame doesn't play .m4a files, so we used iTunes to easily convert them to .mp3.
Step 5: Run the Script
We wrote a script which picked the right song from the chosen year. We had a map for every year filled with the 40 most popular songs. Feel free to use our script and change it to your preference.
Step 6: Links
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    3 Discussions
    DavidW742
    Tip 1 year ago
    I suspect you are counting pulses to determine the dial input so I just thought I'd add that it's possible to read the pulses as serial data if you set the baud rate to 110 on Rx. The character received is "@'. There are no gains to be made in this application but I happen to have an old keyboard and teletype both running at 110 baud so all three devices can be wired into a serial loop with input from anyone at one time. There is a video at web.ncf.ca/fx829 showing a Pi controlling the Town's HO train set.
    Swansong
    1 year ago
    That's a neat setup :)
