TREAD BELT
106,112
747
37
Nice belts made out of used bicycle tires. These belts are stylish and very simple to make.
by: www.opendesignclub.com (thats me!)
Step 1: SEARCH FOR TIRES
Search for used tires with a nice tread
Step 2: BUY SOME BELT BUCKLES
Buy some belt buckles you like
Step 3: BUY SOME CHICAGO SCREWS
Buy some Chicago Screws or rivels to fix the buckles
Step 4: CUT OUT THE TREAD
Cut out the tread in the width of your belt buckle
Step 5: MAKE SOME HOLES
Make the holes you need to fix the buckle.
Step 6: FIX THE BUCKLE
Fix the buckle and fit the belt to your size
Step 7: !!! DONE !!!
Ready to use
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    37 Discussions
    akrob
    4 years ago on Introduction
    How do you cut the tires cleanly? Utility knife = stretches the rubber and makes crooked lines. Tin snips = jagged edges and crooked lines. Is there an industrial rotary cutter?
    shizumadrive
    5 years ago
    i too want to thank you for the Chicago screw info. I searched for screw rivets or just rivets before
    andrea biffi
    5 years ago on Introduction
    wow, they're awesome, I saw some of them today in a market stand and I suddenly felt the need to built one! LOL
    johnv474
    7 years ago on Step 5
    Use more than one buckle. Start your own trend. Ever seen a belt with three buckles?
    GenAapjohnv474
    Reply 6 years ago on Step 5
    I've never seen a belt with two buckles... how would 3 buckles work.
    SIRJAMES09
    7 years ago on Step 7
    I never thought of this!
    What a cool idea!!!!!! TY for sharing!!
    de5099
    8 years ago on Step 5
    what if i need longer than what the tire provides.... like for a bigger man... how would i connect the tires together!?
    kenbob
    8 years ago on Introduction
    Great instructable!
    Love these,
    The hybrid tire i chose is a bit rounded, but overall - i like the results.
    I salvaged buckle and little strap below buckle from a belt that had died.
    And, now I know those little bolts are called Chicago bolts!
    Jax Rhapsody
    8 years ago on Step 4
    I started this project, but I used a mountain bike tire- some sort of old Kenda tire. The tire is worn but the outer(side wall I guess) lugs protrude into the required cutting area. It's not alot but would it be better to cut through them or around them. They aren't very worn cause either because they aren't part of the contact pacth when riddin on solid grounds.
    askvictor
    10 years ago on Introduction
    A list of tools etc would be nice; how did you cut the holes for the belt? Another ideas is to use a link of chain to hold the belt together around the buckle instead of the chicago screw. Y'know, just for that extra bit of bike-nerdiness.
    To make nice neat holes like this, you will need a hole punch.
    This is a type of leatherworking tool that is designed to cut varying sized holes in leather belts or other projects. You can get them in all different sizes.
    They're a bit like a centre punch, but hollow at one end and bladed instead, and you just place the tool where you want the hole and smack it with a hammer.
    Long holes are made with the same tool, you just nibble it along until you have the length needed to wrap around the middle pin in the buckle.
    Hope this helps. :)
    Visitor
    11 years ago on Step 3
    Use chain ring bolts instead. And it is enough to have one link to your website on the introduction. Putting it on every page is blatant link spamming for higher Google rating.
    komodoboyx5Visitor
    Reply 8 years ago on Step 3
    beacause its like hes so totally going to make some ripples in the trillions of other options to make. Besides, better spam it up with something good, and not complete waste. this actually helps.
    DIYDragon
    9 years ago on Introduction
    Sweetness - need to find me a bicycle tire. I do actually have a belt chain that is a bike chain. Would go nice with this haha.
    SG1Oniell
    doesn't it end up smelling like rubber, you know what I mean right? that over-powering smell, also, add tire black to the tread, it ends up shiny and awesome.
    lotusduck
    I'm going to build one with D rings. That way, you don't need to buy actual belt parts, you just need to find two sturdy circles that are larger than your belt. Perhaps I will do an instructable on how many things can be D belt rings. Perhaps.
