TRIPLE CNC MACHINE
47,163
465
47
About: Tecnical Teacher
After a few weeks' break, we are back with a new project. In this video, we will try to make a simple cnc machine with you. “ A SIMPLE HOMEMADE TRIPLE MACHINE “. With this cnc machine you will be able to do 3 different jobs.
-Engraving with Dremel,
-Laser cutting
-Drawing with pen
With the new drawings that we designed as a plug-in, it will be quite simple to use cnc. All you have to do is remove the parts we share in the video description from your 3d printer and provide the necessary materials. Our design is quite simple. No unnecessary material. No unnecessary wires.
our design is quite simple. No unnecessary material. No unnecessary wires. In our video, we tried to show how to do our cnc machine in the finest detail. We went step by step.
Step 1: What We Need ?
Hi everyone,
If you have decided to build a CNC Machine, you are right place. But to build, you will need some equipments and materials. So, ask is coming for you. What we need ?
We have divided the materials we need into 3 groups.
1 - Mechanical Parts
2 - 3D Printable Parts
3 - Electronic Parts
Lets see them...
Step 2: Mechanical Parts
As you can see in pictures, we need some mechanical materials. And you can find detail list in below
=GIJON TIJS=
M8 - 12 CM * 1
M8 - 42 CM * 2
M8 - 44 CM * 3
M10 - 44 CM * 1
=LINEAR SHAFTS=
M8 - 50 CM * 4
M8 - 40 CM * 2
M8 - 10 CM * 2
= NUTS =
M3 , M4, M53 M8, M10
= STEPPING MOTORS =
NEMA 17 * 3
= RULMANS =
LM8UU LINEAR BEARING * 12
608ZZ BEARING * 3
STEPPEE MOTOR COUPLER ENCODER * 2
= SCREW & BOLT=
M6 , M4, M3
= WOODS =
60 CM * 40 CM WOOD
52 CM * 35 CM WOOD
Step 3: 3D Printable Parts
we designed some 3d parts. They were drawn on solidworks. And printed with Prusa i3 3D Printer. We added on last steps STL files for your printer. You can find them there.
Step 4: Electronic Parts
And last materials are about electronic.
- Arduino Uno * 1
- Blue laser module laser engraving and cutting TTL module * 1
- V3 Engraver Shield 3D Printer CNC for arduino CNC Shield * 1
- A4988 motor driver * 3
- BDX53 * 1
- 100 OHM resistor * 1
- Fan
Step 5: 3D ANIMATION TO BUILD
if you want to watch 3D animation you can click below video. Will start directly 3D animation time laps.
Step 6: Let's Start Project
Firstly we will built first floor. We need some materials in pictures. We plug 3d wood parts on wood table. Put shaft and tijs to hole on parts. You can see on pic "how?" or watch our video tutorials
timeline is 04:26
Step 7: Header Holder
We designed a header. This header will hold 3 different head for Dremel, Laser and Pencil. What do you need ? in pics. Quite simple design. How to built ? Check pics or video tutorial
time line is 11:15
Step 8: Assembly Header Holder and First Floor
Step 9: Assembly Nema 17 Motor Stepper to Parts
Step 10: Second Floor Assembling
And now we are building last floor. We are getting second wood and screws.
Time line is 17:13
Step 11: Electronic Materials
As you can see in pics. We need again some equipments. Arduino Uno, CNC Shield, A4988, A switching circuit and a fan. Now go to step...
Step 12: Assemble Electronic Materials
We are using simple a circuit. No more wire, no complex. Will using A4988 motor driver for Nema 17. And added a little circuit for switching for Z axis. You can watch our Part 2 video about Electronic Part.
Step 13: And Let's Try
We have done our project. And now we will try a sample. And RESULTS....
Step 14: FILES...
You will find necessary files for this TRIPLE CNC MACHINE project on this step. You can find all files below links for downloads.
Electronic Circuit - http://bit.ly/2vbjTu0
STL Files for 3D Printers - http://bit.ly/2Gwtz8O
Xloader - http://bit.ly/2IMpCyC
Hex Files for Arduino - http://bit.ly/2UPKyvB
LaserGRBL - http://bit.ly/2VfFakX
Cnc arduino box stl files for 3d printer - http://bit.ly/2VXyULA
THANKS FOR PATIENCE - TO BETTER WORLD
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    47 Discussions
    mladenpozaric
    6 weeks ago
    Great tutorial. I am printing parts. But I am more interested in CNC version. Is there tutorial how to make it (especially electronics) and sofware .
    JuanP263
    Question 13 days ago
    hla amigo gracias por el tutorial, estoy armando este cnc, pero quisiera saber si usted me puede brindar informacion sobre la configuracion de pololu, y que programa se puede usar para trabajar con dremel, y si la estructura soporte al dremel comiendo en Z.... por favor su informacion sera de gran ayuda!!! gracias
    sks98
    6 weeks ago
    I really like your project.
    Pls tell me the link from i can purchase things which are used in this project.
    shettypiyaa
    6 weeks ago
    i really really love this project and want to try it. But i cannot find the code for drawing with pen .can anyone clear me with the same.
    like we control motors and everything by code,right?
    where is it and how to use it.
    please guys help me
    thanks in advance
    Steinzel
    5 months ago
    I love this project! Could you explain a little about what is going on in the switching circuit? Thanks!
    TheTNRSteinzel
    Reply 5 months ago
    Hi Steinzel, Because z axis is giving out just +5V. But we are using a +12 V laser. So we need 12 v for our laser. This switching circuit is giving for laser to 12 V ...
    Mini onion
    Question 5 months ago
    can i get a link to every thing exept the 3d printed parts????
    TheTNRMini onion
    Answer 5 months ago
    Hi Mini onion,
    What do you want ? how a link ?
    Mini onionTheTNR
    Reply 2 months ago
    basically where can i buy the non 3d printed parts
    maxpisani
    2 months ago
    Hello is a great project and really detailed explanation.
    I would like to receive the floor plan of the lower floor.
    Thank you
    HaroIde
    Question 3 months ago
    Dear TNR
    Please point me to the stl file for the pen holder.
    Mny tnx
    Harold
    Meekshi
    Hello, great project. I was wondering if it would be possible to upload the 3D design (solidworks file) of the Triple CNC Machine? Thank you very much.
    shiva1979
    3 months ago
    Hi , What is power supply it required ? and where to connect power to mainboard?
    alisahla205
    3 months ago
    Hello ,thank you for your great project and thank you for your simple explain. Please I need also STL files for the pen holder.Best Regards.
    hrlyrdr79
    3 months ago
    hello I am committed to building this machine I bought all the parts and pieces, printed everything but there is one thing that you forgot in your printing STL files there is no pen or pencil holder available to print have searched everywhere not there please if you would send to me the STL files for the pen holder h r l y r d r79 at yahoo.com thank you by the way love the machine can't wait to get it done and working have a great day
    maddog571998
    I have two questions:
    1)What is the cost of this great CNC?
    2)What GIJON TIJS means?
    It stands for threaded rod or smooth rod?
    scitronboyTheTNR
    Reply 5 months ago
    Is $100 the cost for all new parts? If so, that's an amazing price...
