Table Saw - From Circular Saw
26,073
86
11
This is my first instructable so bear with me while i attempt to explain my creation
NOTE: This is a very dangerous instrument and i am not responsible for any way you decide to use it. or any injuries that may take place. On average, 1 finger is amputated by a Table Saw every 9 minutes, i too have had my run in wit h this saw, but my reflexes kicked in and it only left a scratch, Just warning you.
Materials you will need:
- 3 or 4 2x4x12 (12 Foot two by fours)
- 1 electric circular saw like the one in image #2
- 1 Piece of Plywood, at least 2' x 6'
- 1 Red-Capped Toggle Switch with either 2 or 4 connectors on the back
- An Old Extension Cord or ZPMRelay" and 2-Wire Cord
- 3 to 4 carriage Bolts with washers and nuts
- About 20 2x4 Nails or Screws
- About 32 Plywood Nails
- 2 - 3 Wire Splices
Tools you will need:
- Drill
- Various Metal and Wood Drill Bits
- Hammer or Nail Gun
- Splicer
- Wire Strippers
- Wire Cutters
- Wrench to Match the nuts for the carriage bolts
- Socket Set
- Screwdriver
- Tape Measure
- Chalk Line
- Saw, preferable electric.
- Compass Saw, Keyhole Saw, or Saber Saw
- Hot Glue Gun (Recommended, but not needed)
Step 1: Step 1: Cutting the Boards
Step 1:
- Gather at least 3 2x4s and cut 1 in half, 1 in 3rds, and 2 4-foot pieces out of the other.
- Cut ONLY ONE 4 foot piece in half.
- Next use your tape measure and go along the longest side of your plywood, measure 6 feet, then mark it, do the same to the parallel side.
- Then run the chalkline between the two points that are parallel,
- Then, on the short side you started at on the first one, measure out 2 feet, then make a mark.
- Then, on the line you previously made with the chalk line, measure 2 feet parallel to the other 2 feet and make a mark.
- Snap the chalk line between the two marks.
- Then run the Circular saw, that ironically will be attached to it later on, and cut along them chalk lines. You could attempt to use a handsaw if you have nothing else to do.
The plywood should be a perfect rectangle now and ready to be 'carved' in the next step.
Step 2: Step 2- Forming the Top of the Table
Now lets just focus on that piece of plywood you just .
Measure 1/2 of its width, make a mark, measure 1/2 of its length, make a mark, Wherever they intersect, make another mark. (Image 1)
Make a plunge cut directly on the mark in the middle parallel to the 2 foot sides, carefully move it up about 1/4 a centimeter and then back to the center, then down about 1/4 a centimeter, this should give it room to circulate when it is spinning in the 'crack'. (Image 2)
There should now be a long rectangle in that location, measure out 1/4" from each Corner to the 2 foot sides (after here, refered to as sides) and make a mark, then drill it with a 1/2 drill bit, to fit the saber saw into. Then use the saber saw to connect the drilled holes, use precision so it won't be crooked, you want it to be as strait as humanely possible. (Image 3 and 4)
Then measure 1'6" (1 Foot, 6 Inches) from the left side, then up 2 inches, drill a hole with a 1/2 drill bit. (Image 5)
Now, using that hole as a sawpoint, cut out a square, the size of the switch with the saber saw. BE SURE THERE IS AT LEAST AN INCHand 3/4 OF WOOD BELOW IT so it doesn't break off and so u can fit it on the base. Then Fit the Switch in there using Hot Glue or brackets if needed.
Step 3: Step 3 - Build the Table Base
lets get back to the 2x4s...
- Take all of the 6 footers and one of the 2 footers and nail them togather in the corners to form a rectangle. I'll let you decide how to do it, perhaps make a miter cut on the ends. (Image 1)
- Take the legs, and nail them to the inside. (Image 2)
- next nail the piece of plywood to the top
Step 4: Step 4: Configuring the Circular Saw
Now we are going to need to bypass the switch to get ours to work.
IMPORTANT: DO NOT DISASSEMBLE THE MOTOR HOUSING OR GUIDES.
Take the handle off, take off the switch, connect the wires together (depending on the model), this only works if there is 2 wires for the switch, if not, send me an email @ mod_0087adam@hotmail.com with a picture of the switch and i will try to interpret the correct wiring patterns. Then u can reassemble the handle. and test it out by plugging it in, but take the blade off first so it don't kick back. once u confirmed that it works, cut the plug off the cord and wire one of them to the switch .
Now u need the old extension cord, cut the female end off of it then strip the wire, then the wires inside of it, hook one end into the switch, then splice the other remaining 2 wires togather.
then drill 4 holes around the parameter of the base, as in image 1 then align the blade in the middle from under the 'table' and drill holes in the same location you can turn it upside down if it helps,. Then send the carriage bolts through the top of the table into the hole amd then put a washer on it and bolt it half way, then put the rest of the bolts in the same way and tighten them down to an estimate torque of 100 Newton Meters then plug it in and see if it works, if so, then you just made your own table saw, if not, sent me an email, which is listed above with a description of your problem and a picture of the underside of the table.
Thank you for taking time to review and/or attempt my tutorial, sorry if things didnt' work.i will help as much as i can.
Step 5: Photos
    • Paper Contest
      Paper Contest
    • Epilog X Contest
      Epilog X Contest
    • Pie Contest
      Pie Contest
    11 Discussions
    iamtoats
    9 years ago on Introduction
    I would have put the power switch on the side, so it doesn't get in the way when dealing with large lumber.... But thats just me....
    0087adamiamtoats
    Yes i should have done that, wood kicked up and snapped the switch off the other day and i had to unplug it and make repairs.
    SIRJAMES09
    7 years ago on Step 5
    not bad...
    It was an interesting read, & easy for me to follow...
    HOWEVER,
    I would have made the table bigger....like big enough to support a 4x8 sheet of plywood...table does not have to be 4x8, but maybe 4x4, or 4 x 6...
    Then again, I do A LOT of cutting with plywood sheets.
    I bought a table saw a few yrs ago & extended the table top to 8 feet long by 8 feet wide...at the time I did that, I was remodeling a barn into a house, so I needed all the support I could get. looked weird as all get out, but it worked nicely for me.
    0087adammag6210
    I have a camera, but i didn't make the instructable until after i made it.
     Ficou muito bom, de uma olhada neste vídeo que eu achei no youtube:
    http://www.youtube.com/watch?v=bKh-vSQYae4&NR=1
    neffk0087adam
    Thanks for the photos. I found your instructable after I wrote mine on a similar project. I wish I'd seen yours before I started. Nice work.
    0087adamneffk
    Thanks for taking the time to visit and leave your comments. i read every comment and leave a response, so if u have any more questions, please take the time to ask and i will be glad to help.
