Tablesaw Outfeed Table
14,177
166
25
About: I have been a woodworker for over 40 years, working in a cabinet shop to making custom interiors for executive jets. I have a full shop in my garage and have been making wood pens for the past 3 years. I am ...
These plans are for a Grizzly G0715P series Tablesaw Outfeed Table.
Step 1: Drawing Up the Plans
I used popular for the frame ( items 1-3 and 5) and maple for the table brace and roller blocks (items 4, 6 and 7)
I used a 2 x 4 trimmed to 2 degrees to allow the hinges to go over center.
The frame has dado's as shown.
The 1/4-20 Threaded inserts can be purchased anywhere.. Amazon sells them in packs of 25
To mount the 2x4 I replaced the number 10 and 8 screws with longer ones to go through the 2x4 and rear angle.
Step 2: Attaching Frame to Hinges
Once the Frame is cut and dado's run it is time to mount it to the saw per the first photo in this section
I used heavy duty hinges to assure the frame would be solid and could handle a load.
I purchased 7 rolling pins from Amazon for $5.90 ea.. They are now just over $6 dollars.
I removed the handles from the rolling pins as I wanted to use the 3/16 rod to attach to my 14 maple blocks. Note that there is a slot in the block for height adjustment on the frame.
I mounted one of the inner rollers to check fit and also help with height adjustment
Step 3: Attaching the Table Brace
I attached a 2" x 15" x 3/4" piece of popular to the bottom of the saw allowing through holes to be just above the dust pan inside the saw base. Where this is mounted is not critical.
I mounted a dog ear with a 1/4-20 threaded insert to this bracket as shown in the photo. I made a similar dog ear for the frame and again added a 1/4-20 insert.
The table brace is a bit of trial an error as the top and bottom need to be close to the same length. On the dog ear ends I bored a 1/2" hole through and put a 1/2 x 1/4 nylon bushing in both ends of the bottom brace and one end of the top brace. See photo examples of the threaded insert and nylon bushing installed.
The brace is designed to go over center thus when the table is in the closed position the middle of the brace is up and as you lift the table up it goes over center to hold the table level. I added an adjustment brace with a knob to allow me to adjust the table as needed.
Step 4: Closing Table Sequence
To fold the Table down in the closed position, you lift the table bringing the brace halves in line with one another then pressing with your foot to move it over center.. See photo sequence
Step 5: Opening Table Sequence
To open the table, just grab the lower section of the table and pull away from the saw lifting up and out until the brace is inline then goes over center and drops down. See photo sequence and video
Step 6: Finishing the Table
Now that it is all working, time to paint the table and mount the rollers. The Grizzly Polar Bear Series white is the same as the Jet white. I primed and painted the table frame white. I put a clear oil on the rollers and 14 mounting brackets
The 14 roller mounting brackets are all adjustable to raise and lower the rollers.
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    25 Discussions
    Tesseract 4D2
    Question 9 months ago
    Do you think this would work with PU roller blade wheels instead of rolling pins?
    1 answer
    BruceputmanTesseract 4D2
    Answer 9 months ago
    Yes, But. For pieces going through the saw blade the run with the rollers. The piece that is on the left of the blade I tend to slide left after the cut. The rollers I used allow me to slide on them where rubber wheels might not. Otherwise good idea and you would have bearings
    allangee
    2 years ago
    You have to make sure the rollers are exactly perpindicular to the saw blade, otherwise your work piece will try to pull to one side. That's why the roller balls are preferred.
    Bruceputmanallangee
    Reply 2 years ago
    Based on using this table and knowing that even though I marked and drilled everything on a drill press, they are not "exact" and have had no issues. The metal rollers on the other hand leave marks, especially on softer wood which is why I choose to use wood rollers..
    I have had experience with both as we had the rollers in the cabinet shop I worked in.
    In the end we all have preferences.
    Josehf MurchisonBruceputman
    Reply 2 years ago
    I hate that when that happens, how can you vote for a project if they feature it before it is accepted in a contest?
    And what are your chances of getting back to it before the contest is over especially if it is posted on the last day of the contest.
    ironarmadillo
    2 years ago
    I don't have a need for an outfeed table but this design looks like it can be easily adapted to a side table for handling sheets of plywood that need to be cut cross-ways.
    Bruceputmanironarmadillo
    Reply 2 years ago
    Just hinge on the side with rollers facing the same direction as the saw blade and your set
    stepinfech
    2 years ago
    .Stepinfech
    Great
    Job. I have a Rigid 10" unit & was looking for ways to do this. I have a
    selection of metal rollers & was going to use square tubing but your frame is a killer!! Just made my life a lot simpler
    Thommyboy
    2 years ago
    AWESOME job gotta love the rolling pins great idea and the table brace looks awesome. Keep up the great work.
    ironarmadillo
    2 years ago
    I just checked: Walmart has the exact same rolling pin for $4.74.
