Tabletop Fireplace
23,122
312
13
About: Build.Share.Destroy.Repeat. Follow me and try a few of my projects for yourself!
There's nothing quite like enjoying a meal by the fire. Now you can have that experience almost anywhere with a portable tabletop fireplace. This concrete container holds single-use gas canisters that give off a gentle flame, the container is propped up with cast iron legs which give it an industrial feel.
This project is a capstone project as a companion to my free Introduction To Concrete Class. This striking centerpiece is sure to be a conversation starter at your next dinner party.
Ready to cement your knowledge of concrete? Let's make!
Step 1: Source Materials
To make a concrete mold with a void we'll need a large container to create the mold with and a smaller container of some kind to displace concrete to make the void. For this tabletop fireplace I chose a large rectangular plastic storage container and found a smaller container that fit inside.
In the plumbing aisle of a hardware store there are all kinds of fittings in all different sizes. To go with the industrial look of concrete I chose ¾" cast iron fittings to make the legs and feet for this fireplace.
Each leg needs one mounting flange, one 45° elbow, one end cap, and two threaded nipples - all of the same size (I used ¾" fittings).
Step 2: Trim to Fit (If Needed)
The cast iron flanges I chose were slightly too large for the bottom of the large plastic container I was using for the concrete mold, so there were modified slightly.
Using an angle grinder, trim the lip of the flange slightly to fit two flanges side by side in the bottom of the container used as the concrete mold.
The flange was marked and then securely clamped down to a sturdy work surface, then trimmed using the grinding disk on the angle grinder.
Two of the flanges were trimmed to allow all 4 to fit snugly in the bottom of the large mold. Since I will be using the threaded portion of the flange it's important not to grind into threading and ruin the ability to connect the nipples later.
Check the flange sizing by placing them inside the mold to ensure a good fit.
Step 3: Reinforcement
Reinforcement might not be needed for this casting since it's small and will be quite thick, however adding the reinforcement guarantees they casting will stay strong no matter the load or span between the legs.
Any sturdy steel wire will work as reinforcement. I used animal wire fencing I got from my hardware store, which they sell by the foot. Using regular angle cutters I snipped off a shape roughly the size of the bottom of the casting mold, then refined the dimensions to fit exactly after.
As discussed in the Mixing + Pouring Lesson of the Concrete Class, steel reinforcement is a great compliment to the compression strength of concrete, but the steel needs to be completely entombed in concrete to prevent it from rusting and failing. It's important to make sure your reinforcement sits completely inside your mold with at least a ½" buffer around it for concrete.
Once the reinforcement is sized we can remove it from the mold and set it aside, we'll come back and insert it partway through our first pour.
Step 4: Flanges
Before the first pour the cast iron flanges need to be placed in the bottom of the mold. To ensure they stay still while pouring the concrete, and to prevent concrete from seeping under the flange and gumming up the threaded interior, a bead of hot glue was squirted on the top edge of threaded part of the flange, the flange was then placed glue side down into the mold.
Once all four flanges have been glued to the bottom of the mold the insides can be protected from concrete entering from the top. Paper wadding was used to fill the space inside the threaded interior, then the flange tops were sealed with heavy tape.
Repeat for all 4 flanges. The heavy tape will stop concrete from entering the threaded interior and the paper provides ballast so the tape doesn't cave in.
Once the flanges are glued and taped, sealing the threaded interior of the flange, we can start preparing the concrete mix for the first pour.
Step 5: First Pour
Mix a batch of concrete large enough to fill about half the mold. Carefully pour the concrete mix into the mold, ensuring to cover the flanges completely. Take small breaks to poke and tamp the concrete under and around the tight spaces at each flange.
Once all flanges are covered continue pouring until about ½" of concrete covers the top of each flange.
If you are using a clear container for your mold you can scoot one end of the container off the workbench to inspect the underside and ensure that the flanges haven't become unglued, and concrete is staying out of the threaded interior.
Step 6: Add Reinforcement
After the flanges are covered the reinforcement can be added. Carefully place the cut to fit reinforcement into the center of the mold on top of the poured concrete and gently press to seat it. Do not push the reinforcement down into the cement so it touches the flanges.
Next, carefully scoop more concrete on top of the reinforcement and completely cover with another ½" of cement.
Step 7: Vibrate
At this point it's a good idea to gently vibrate your concrete to release any air bubbles that have been trapped.
A good resource for getting concrete without any bubbles is covered in the Mixing and Pouring Lesson in the Concrete Class.
Step 8: Negative Space
Use a second plastic container to make the void in this concrete casting that will hold the fire elements for this fireplace. I used a smooth sided plastic trough that was about 1" smaller on all sides than my large mold.
Release agent was sprayed on the outside of the smaller container and then the container was placed in the middle of the larger mold and centered.
Water was poured into the container to act as ballast and prevent the smaller mold from floating out of the concrete from being too buoyant. The smaller container was partway filled with water, then concrete was added around the container to the waterline, repeat alternating adding water and then concrete to the waterline until the concrete has filled the large container.
Vibrate the concrete again to degas, then cover with plastic wrap and leave to cure for 48 hours.
Step 9: Remove From Mold
After curing the concrete cast can be removed. Depending on the shape of your mold, and if you used release agent, some molds are easier to remove than others.
The large mold was pliable enough to flex and remove the concrete casting from, however the smaller container used for negative space was very rigid and was impossible to remove despite the generous amount of release agent applied. Ultimately the inner container was destroyed in order to be removed.
As you can see in the top right of the picture above there was slight damage to the concrete casting from removing the negative space mold.
Step 10: Remove Paper Wadding
Flipping the casting upside down the flange threads can be examined.
Hot glue is easily removed from the rim of the flange threading, the paper removed, and any concrete flashing that managed to seep under the glue barrier can be cleaned off to expose the threads.
Step 11: Grinding Finish
Once removed from the mold and the flange area has been cleaned up we can turn to finishing work on the concrete surface.
Concrete Finishing can be achieved through grinding and polishing using a variable speed inexpensive variable speed angle grinder and diamond polishing pads to expose the aggregate and create a smooth concrete surface, we'll use those skills now to bring depth to the otherwise dull casting.
As you can see from the arrows on the image above, the small section of polished concrete on the right looks much different than the original casting.
Spend the time to carefully grind and then polish each face for the entire casting, the effort put in here makes the project really pop!
Step 12: Apply Finish
After exposing the aggregate and polishing the concrete to a smooth finish it's time to add some finish to seal the concrete and give it that wet look. For this project I chose the "wet look" sealer, which will give the concrete a darker color and enhance the texture of the aggregate.
Wearing gloves, a liberal amount of sealer was poured onto a cloth and applied all over the casting. Excess was wiped off with a clean lint-free rag.
Step 13: Assemble + Attach Legs
For each leg there are two threaded nipples, a 45° elbow, and an end cap - all fittings are ¾" cast iron pipe. The endcap and threaded nipple were tightly connected, then fit into the elbow as snug as you can by hand.
The second nipple was inserted loosely and then inserted into the flange on the underside of the fireplace, but not tightened.
Step 14: Level Legs
Fit all legs into the flanges and then turn the fireplace right side up. Gently rotate each leg to tighten into the flange until it starts to tighten, then position the leg with the end cap facing outwards. Positioning the remaining legs the same way, making small rotations of each leg to keep the fireplace level.
Step 15:
The fuel for this tabletop fireplace are small 7-ounce Sterno cooking pods. These inexpensive pods give off a real flame, and are interchangeable when the fuel is depleted. These pods last 2 hours and are recyclable.
Place the pods inside the void of the fireplace and use small pebbles (I used sifted aggregate) to fill in the space around each pod,
Make sure to leave the lids on the pods as you fill, otherwise you'll end up with rocks in the fuel.
Step 16: Light at Twilight
All that's left is to wait until twilight and fire up your tabletop fireplace. Over the romantic glow of the fire you can wow your guests on your new knowledge all about concrete, and how this tabletop fireplace was made.
Concrete has a timeless aesthetic, and so do fireplaces. This tabletop fireplace is sure to be something you can enjoy for years to come.
Have you made your own tabletop fireplace, or concrete creation? I want to see it!
Share a picture of your concrete project in the comments below and get a free Pro Membership!
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    13 Discussions
    BeatleBass
    1 year ago
    This is very nice, I would like to take this on, and I think that I'll actually finish it too. There are so many ways to decorate the outside too, if cement isn't your thing.
    I'd replace the flanges, as noted below, to avoid the need for cutting them. Buying the saw places the overall cost out of my range.
    Thanks Mike for posting this for us to enjoy! I am now following you.
    mobeep0
    1 year ago
    my kids will love it. great use for making s'more during winter !
    RushFan
    1 year ago
    Really nice project, and thank you for saying that concrete cures, not dries!!
    dalegribble
    1 year ago
    made a similar fire pit. Just made an instructable for it.
    Mark 42
    1 year ago
    You could save some money by substituting unions for the flanges. The flanges are expensive, from what I've seen.
    3366carlosMark 42
    Reply 1 year ago
    I guess flanges distribute the load much better.
    Ace Gambit
    1 year ago
    This is so cool!
    Jedi_zombie85
    1 year ago
    Very cool project, deffo giving one of these a go when I get chance
    AmirulL1
    1 year ago
    beautiful n nice touch.???
    sageclouddancer
    1 year ago
    you could make it into a hibachi and cook on it
    spark master
    1 year ago
    Before they rurn down all the way cover killing the flames add methanol it will rehydrate (recharge with alcohol) the acetate gel mix. Or stuff with fiberglass add a screen insert and fill with methanol. Reuse a million times, ok ok maybe 25,000 times. This can be found here on instructables (i think) if not then on the web in general. You could even make the jell yourself, but these are so reaonable, why bother!
    Then there are Penny Stoves and Pepsi g stoves all which will work in this. See zenstoves.org and here on instructables.
    Mikee, I like it!!!!!!!! Flames safety, samosa's on the barbie on the balcony!!
    spark master
    1 year ago
    A simple concrete item....hhmmm.... You could add colored pebbles to the top of the mold then when you grind off you get Terrazzo!!!
    sweet!
