Tapping Holes Using a Drill Press
7,471
99
8
When you are threading a hole, it's very important to keep the tap aligned with the hole. This is especially critical for the first couple turns of the tap. A drill press can help keep the tap aligned much more accurately than you can do freehand.
There are two functions that the drill press can serve to help you tap a hole. The first thing is to keep the tap aligned with the hole that you're tapping. The other function is to keep light pressure on the tap so that it will cut cleanly as soon as you start turning it into the hole.
Caution: Just to be clear, you should not use the drill press to turn the tap. That type of automation requires special equipment (e.g. a Tapmatic).
Step 1: ​What You Will Need:
  • Drill Press
  • Drill Press Clamp
  • Tapping Handle
  • Tap
  • Oil (or other tapping fluid)
  • Centering Point
  • Heavy Weight
  • Twine
Step 2: Setting Up the Drill Press
  • Install the centering point in the chuck
  • Adjust the table height so that the centering point is just even with the table top when the quill is completely extended
  • Tie the twine to one of the feed levers and make a couple turns counter-clockwise around the hub.
  • Hang enough weight onto the twine so that it will just start to lower the quill as if falls.
    My drill press requires about 20 pounds on the end of the twine to just start pulling the quill down. You will need to play around with the length of the twine so that the weight has enough room to fall freely.
Step 3: Aligning Your Work
  • Place your work piece on the table
  • Lower the centering point into the hole that you wish to tap
  • Clamp your work to the table
Step 4: Tapping the Hole
  • Apply a couple of drops of oil or cutting fluid to the hole
  • Locate the end of the tap in the hole
  • Locate the centering point in the indentation at the back of the tapping handle
  • Gently turn the tap into the hole until you meet a little resistance. This resistance is caused by a buildup of chips in front of the cutting teeth
  • Back the tap up about 1/2 turn to break the chips
  • Continue turning the tap in about one full turn at a time and then backing it out 1/2 turn
  • If the hole goes all the way through your work then continue advancing the tap until it spins freely in the hole
  • If you're tapping a blind hole you will need to know when the end of the tap reaches the bottom of the hole. You may be able to do this by feel but there is a risk of breaking the tap off if you get this wrong. Another way is to mark the hole depth on the tap with a piece of tape.
  • When you're done threading the hole, back the tap out. Be careful not to let it tip to the side as it comes out of the hole. This will prevent any damage to you're beautiful new threads.
    • Build a Tool Contest
    • Trash to Treasure
      Trash to Treasure
    • Weaving Challenge
      Weaving Challenge
    8 Discussions
    Saltidae
    3 years ago
    Thank you, that will save me a few misaligned threads. Too many of my starts seem to go askew. I've used a similar method with a taig lathe, but this will be quicker and simpler for those jobs that don't fit into the lathe.
    DaveD17
    3 years ago
    Very nicely described, and nice photos to go with it. Thanks for the useful tip.
    crazyg
    3 years ago
    I'd recommend stating that you don't turn the drill on.
    many years ago.. before I had my own tap set I asked my neighbours dad to help me tap a thread into an 8 ball so I could use it as a gear shifter. It was all normal making the pilot hole then I was watching in disbelief , like a surreal dream, as they put the tap in there drill press , fired it up as starting plunging away. After confirming there was no thread in that hole , I suggested maybe turning the tap by hand , in a submissive I don't know way, as to not offend my elder. Luckily I had managed to pinch 2 pool balls from the pub.
    ogrossmancrazyg
    Reply 3 years ago
    Point taken, I'll add that to the intro. Thanks
    wrsexton
    3 years ago
    Done this for years, but you can always learn new things. I've always needed 3 hands to work this method, because I never thought to apply a weight to the press handle!!
    BeachsideHankwrsexton
    Reply 3 years ago
    On some drill presses the quill return spring is easily adjusted to let the quill free- fall for just such an operation, they are usually knurled to allow easy gripping, if the housing is smooth though it's probably more trouble than it's worth to release the quill tension.
