Tatted Barefoot Sandals
145,825
534
51
About: I'm a tattooed needle tatter, a stay at home mom and a homeschooler. I sell my work on etsy. I hope to offer a few patterns more here as I get the time. You can also follow me on twitter as TotusMel and read...
If you've mastered the tatted flower instructable and the Fluerette necklace, you have all the skills you need to make these barefoot sandals.
These sandals use the same pattern as The Queen's Feet Barefoot sandals available in my etsy shop.
You will need basic needle tatting experience easily learned in my other instructables including the double stitch(ds), picots(p), rings(r), chains(ch) and joining as well as Josephine chains and basic crochet.
This design uses size 10 crochet cotton,  a size 5 tatting needle and a size 7 or 8 crochet hook.
The laws of Copyright Protection permit this tutorial to be used for personal use only. Reselling for profit is prohibited.
Supplies:
Step 1: The Center Clover
Make two center rings, one for each sandal:
The pattern is 4 rings of 5ds, p, 3ds, 9p sep by 3ds, p, 5ds close join each ring together by the 1st and 11th picot.
To join the first and fourth rings together for the center motif, first I make the last ring up to the final join, then I pull those stitches off the needle being careful to not pull the thread all the way through. Then I use a crochet hook to make the join and work the last stitches. Pull those stitches through, finish and close the ring. See the photos for details.
Step 2: The Corner Motifs
Next you will make six corner motifs, three for each sandal. These will be attached while tatting the body of the design and are used to add the crochet ties and the toe loop.
The pattern for each is:
R 6ds p, 3 ds 4 picots sep by 3ds, 3ds cl do not reverse
R 3ds join to last p of previous ring, 3ds 7 p sep by 3ds, 3ds cl do not reverse
R 3ds join to last p of previous ring, 3ds 3 p sep by 3ds, 3 ds p, 6ds close, tie and cut
Step 3: The Toe Loop
Make two toe loops, each attached to a corner motif.
Ring 3ds, 6 p sep by 3ds, 3ds close, joining to previous ring by center two picots, close rw
Josephine Ring of 160 stitches or as many as needed to make large enough loop, tie and cut.
See video for tips on Josephine knots.
Step 4: The Main Body
Make two main motifs attaching corner motifs as you work, see pictures for the attachment points for each corner motif before starting as they are not listed in the pattern.
The pattern for both is:
R 3ds p 3ds p 3ds join to the 3rd free picot before the join of the center ring, 8ds cl do not reverse, *R 8ds join to 3rd free picot of next center ring, 3ds p 3 ds p 3ds cl rw
Ch 6ds p 3ds p 3ds cl rw
R 3ds p 3ds join to 2nd p of last ring, 3ds join to next p of center ring, 3ds p 3ds p 3ds cl rw
Ch 3ds 6 p sep by 3 ds, 3 ds cl rw
R 3ds p 3ds p 3ds, skip next picot and join to the next picot of the center ring, 3ds p 3ds p 3ds cl rw
Ch 3ds p 3ds p 6ds cl rw
R 3ds p 3ds, skip one picot of last ring, join to next picot, 3ds join to next picot of center ring, 8ds cl do not reverse
Repeat from * around.
Step 5: The Straps
I crochet my straps after a tatted ring attached to the corner motifs ending in another tatted ring. If you prefer you may skip this step and instead simply tie a ribbon to each corner motif to tie on your sandals.
The instructions for crocheted straps are:
R 3ds 6 picots sep by 3ds, 3ds close joining to the corner ring at the center 2 picots, tie, do not cut, but hide the needle thread in the ring.
Begin crochet chain with the working thread of approx. 160 stitches at the close of the ring. Make chain shorter or longer for size or look. At the end of chain make R 3ds 6 p sep by 3ds, 3ds close, tie and cut.
Note that the final ring is worked by cutting the thread a couple of feet from the end and tatting with the tail at the end of the crochet. Then thread the needle and pull the thread through without putting your needle through the thread ring. It will pull into a ring by itself.
  • Fandom Contest
    Fandom Contest
  • Arduino Contest 2019
  • IoT Challenge
    IoT Challenge
51 Discussions
Solo37
Question 6 weeks ago on Step 5
Hi , hope all is well...which brand of thread you used?
1 answer
TotusMelSolo37
Reply 6 weeks ago
Hey! For black and white thread I usually use DMC Cébélia and for most other colors I use Lizbeth
jessicat44
Question 9 months ago on Step 1
I have a couple of questions on this step: are you doing this off the ball or a single length of yarn/string? If it's a single string how long is it? Are you doing the rings individually or all on one string?
Thank you for your help,
Jessica
Bluewings
2 years ago
I've just finished one sandal, so stoked as I'm a total beginner… I've just realised I still have another one to do, hopefully I'll get quicker, I've already been at it for two days haha.
Thanks so much for this gorgeous pattern, all of your projects are wonderful!!
2016 14:25.jpg
ForrestL4
3 years ago
Hello! I was wondering if you could tell me where to add in the other peices? Im having trouble even with pictures :/
PaulineI
3 years ago
i wish there were a youtube tutorial makes it soooooo much easier to follow and succeed in making its such a beautiful patter but im new to tatting and im not that good at foloowing written patterns
MelissaS36
3 years ago on Step 4
I've tried this one 1000000000 times....... still can't get it all right.
Beautiful design! It looks pretty involved. I think I'll stick to beaded barefoot sandals.
CarolOsterhoudt
4 years ago
So I should go completely around the clover?
You appear to be joining the ring to one of the small motifs not the center motif. See the step 4 photos to see where the join should be.
Melviria
5 years ago on Introduction
finally got around to making these. I originally started shuttle tatting years ago self taught from one of my mother's books but now currently enjoying learning and using needle tatting. I absolutely love TotusMel's designs Thank you for the awesome patterns and tutorials!!<3
cvillarreal1
5 years ago
So very confused on the main body part. I can't tell from the pictures where to join the other parts. Ugh
'rogers
6 years ago on Introduction
Hi I was wanting to make these but as I'm new to needle tatting I was wanting to know how long a tail do I have to leave please.
TotusMel'rogers
Reply 6 years ago on Introduction
I'm afraid I never actually measure except with my arm and just go on instinct. Each section of these is going to need different lengths. This step maybe twice a hands length, but the main piece maybe twice forearm length. I know it's not precise.
Adding thread if you don't start with enough is easy though, just tie a knot after a ring and hide ends. re-thread your needle and run it through the tatting under the knot and you're ready to start again.
bminer
I specifically taught myself to tat to make these. I'm using black sparkly thread. Everyone needs sparkly feet!
