Teach Your Guinea Pig to Run in a Circle
46,275
23
53
About: I have 2 guinea pigs: fudge and lenny
Teach your guinea pig to run in a circle on command! Teaching your guinea pig tricks builds a special bond between you and your pig! This is my first instructable, so I hope you like it! :)
https://www.instructables.com/static/img/pixel.gif
Supplies:
Step 1: Make Sure That You Are Trusted
To do this trick, your guinea pig must trust and eat out of your hand. This can be frustrating. It helps to have a treat that your guinea pig enjoys and can eat somewhat quickly. Don't give your guinea pig too much of the treat, or it will get full. To start this trick, your guinea pig must follow your hand with the treat in it.(not in a circle, but in any direction.) When your guinea pig can follow your hand for great distances, you are ready for step 2.
https://www.instructables.com/files/deriv/F09/CSJT/FIZVWYVZ/F09CSJTFIZVWYVZ.MEDIUM.jpg
Step 2: Starting the Circle
Start doing circular patterns with the treat. Make sure you pick one direction (clockwise or counter clockwise) and stick with it. Make sure to reward your pig with small piece of the treat for every circle. After a while your guinea pig will expect a circle and will begin doing them more efficiently. As soon as this happens move on to step 3.
Step 3: The "key Words"
Assign a key word or phrase to this trick. Every time you want your guinea pig to do a circle, say the exact same word or phrase. I always say "do a circle", which he guinea pig interprets as "dooasercal" and will not understand if I rephrase it any other way. Saying "please! - I'll give you a juicy carrot" will not help; remember guinea pigs don't speak English! Also, if you pick a key phrase that is too long or confusing, or if you say too much other stuff, your guinea pig might get confused and do circles for everything even when you don't want them to. You can assign any key word(s) that you want, such as "circle", "turn", or "do a circle". Just make sure to remember the key words, otherwise your guinea pig will get very confused if you try to teach them new key words. It helps if every now and then you give your guinea pig a treat without making it do a circle. A good time to do this is when they're in their cage - not in the middle of a lesson.
https://www.instructables.com/files/deriv/FV1/AY96/FJ0RH8J8/FV1AY96FJ0RH8J8.MEDIUM.jpg
Step 4: The End of the Lesson
This is the hardest part. It will probably take over 100 level 3 circles to get here. Eventually your guinea pig will expect a circle and be able to do them quickly.. When this happens you don't need to make your guinea pig follow your hand for a full circle, just put the treat either to the right or the left of their face (depending on the direction of the circle), say the magic words, and your guinea pig will begin to learn how to do circles without following the treat. Make sure to reward them for every circle. It is important that you never change the direction of the circle. When teaching your guinea pig to do a circle do not award a treat for a circle in the opposite direction you taught it (even though it is tempting at times) because this is rewarding them for not completing the trick correctly. After the circle is mastered, make sure to practice it often enough so that your guinea pig doesn't forget the trick.
Remember to be patient and have fun while teaching your guinea pig tricks! :)
*You can also teach this trick to your dog!
https://www.instructables.com/files/deriv/F2H/3O6V/FJ0RH8NZ/F2H3O6VFJ0RH8NZ.MEDIUM.jpg
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    53 Discussions
    Well, whenever I say "doohasciercle" She expects to See the carrot beside her and turns toward it. No circles on her own yet :-( Btw her name is Pinea.
    awwww pinea is dead cute. lol doohasciercle lol. how much are guinea pigs and do they smell and how much are like little guinea pig houses or cages what ever
    Guinea pigs are about $40 and cages are about $70, but you can get them for less. And yes, they reek. and yes its a amall cage similar to a rabbit or hamster.
    $40?! wow
    here in aussie, i have bought two
    an agouti-rex amanda
    and a black and white one called clover (both, unfortunately dead)
    i am buying a new one soon
    amanda cost $15 (Christmas season)
    and clover was $9
    they don't stink too bad, but in saying that mine lived in a chicken run or two level cage outside :)
    Yes, guinea pigs are around $40, but you can make cages twice the size of store bought ones, for around half the price. This site has instructions and more on how to make awesome cages-
    http://exoticpets.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=exoticpets&cdn=homegarden&tm=27&f=01&su=p284.9.336.ip_p504.1.336.ip_&tt=3&bt=1&bts=1&zu=http%3A//www.cavycages.com/cubes.htm
    I've kept my 2 pigs in the 2x4 cage for a long time, and they love it!
    Yeah, homemade cages tend to be better. My freind made his new rabbit a bug condo with 2 floors, a sitting room, rec room and bedroom :-)
    aww. She's so cute! And at least she's caught on to the basics. :) If it helps at all, you could hold the carrot behind her, so when she turns a little, she'll see the carrot, then keep turning, then you can move the carrot to where her head would originally be, so she turns the full circle, if that makes sense. :)
