Teardrop Trailer Plans : How to Build a Cheap Camper
721,304
1,009
91
About: I have this page to show people that you don't have to be an expert to try to make something, or paint something, or weld something, or design something. Just get in there and try it. Get your hands dirty!...
First off, I originally documented this on my arts and crafts blog, Make It With Jason.  I wanted to build a teardrop trailer that I could take camping around the Pacific Northwest, where I live.  We have amazing scenes of beauty there, like Mt. Hood, and Multnomah Falls, so I decided I also wanted to paint a mural all the way around it.
All in all, I spent about $500 total on this project (including a used $120 Harbor Freight utility trailer) , and this teardrop trailer is about as barebones as you can get. But it works, and it keeps you dry and warm.
Step 1: First Step: Design Your Teardrop Trailer
I love creative camping spaces for compact living – which is quite a claim, considering I am 6’6″ tall. I owned my first camping trailer back in 2003, and I even lived in it for a month when I was airbrushing down in the little tourist beach side town of Seaside, OR.
At some point, I became aware of the teardrop trailer, which is a tiny little trailer that is meant only for sleeping, and offers some accommodation for fairly comfortable food prep and outdoor cooking.
Gathering Ideas
I figured building a teardrop trailer was a project I felt I could pull it off from design to finish by myself, so I started by searching the internet for more info. The reason the teardrop is so popular is that its rounded profile makes it a breeze to pull behind even a car.
I decided to make a traditional style of teardrop – one with a removable galley for easy loading, and two doors.  Here is a photo of my initial design idea, done in Google Sketchup – a free program offered by Google. The truck is my GMC Sonoma – a V6 capable of towing a tiny trailer, but not much else.
The Teardrop Design
First, I drew a quick sketch of what I wanted it to be.  I didn’t want to reinvent the wheel (my first time around), so I went with a traditional route.  In Sketchup, I downloaded a trailer base (because I knew I wanted a roughly 4X8 bed on the trailer.
I also knew I wanted to just put a couple sheets of 3/4″ plywood as a floor and building base for the rest of the trailer.
When I build another one (a larger, “canned ham” type), I will be building it with a 2X4 framed floor and use the plywood as a subfloor, but that isn’t really diminishing the stability of this one, because it is attached to solid steel.
Step 2: Next, Cut Out the Sides
Beginning the Build
Next thing I did was sandwich two sheets of 1/2″ thick plywood and two sheets of 1/4″ plywood (or luan) all together and cut out the teardrop profile outline with a quality jigsaw (mine is a Bosch Jigsaw).  Take your time with this, and keep your cuts nice, clean, and vertical, and it will save you a ton of time cutting the outline.
Read more at Make It With Jason
Step 3:
When tackling a project like building a teardrop or ANY camping trailer, you have to plan a bit ahead.  I tend to be a “forge forward, and learn as you do” kind of guy, but that works a HECKUVA lot better in drawing and painting than it does with expensive projects like this.  Besides that, I didn’t want to spend too much on this project.  You can honestly build one of these for around $500 (or less!) if you are savvy and budget-conscious.
The Teardrop Construction Stage
Anyway, after adding the rails on the bed, I tacked the 1/2″ plywood sides up in order to line things up and get them straight for framing the interior and “skinning” it with the 1/4″ luan.  Plus, it makes you feel like you’re making progress.
I’m not going to show every single step in the build (because I honestly didn’t have the presence of mind to take a photo at every little step), but I can tell you that I added  a framing of 1×2 “furring” sticks on the inside of the 1/2″ ply, and stuck 3/4″ thick hard foam insulation pieces in between the furring strips as insulation, and as a structural alternative to a void behind the 1/4″ luan plywood interior walls. I added the furring strips with screws and then I laid the luan up against the furring strips and insulation and attached with pneumatic staples. NOTE: I suggest you glue ANYTHING you’re attaching to something else.
I attached my sides to each other with lengths of 2×2 wooden spars (which also offered attachment points for the roofing material I used). You should add as many as possible to it, and cram the space in between the spars with more insulation.
Making the Roof
The roof of any camping trailer is very important.  It not only insulates you from the sun’s heat and the cold wind, but it also keeps out water. For my roof, I opted to bend several sheets of 1/8″ luan and laminate them to the wooden spars.  Now, I would recommend you spend a bit more and buy either aluminum or fiberglass for the roof.  Laminating, sanding, and painting luan to make it weatherproof can take more time than if you just went and bought the quality stuff.
NOTE: when bending luan, it is important to bend it along the grain of its thickest ply (usually the one in the middle).   If you bend it against that grain, it will probably snap in half or at least give you an ugly crease.
The Galley and Doors
These two areas are a sore spot with me.  I designed my doors fairly traditional, and, if I could do it all over again, I would have ordered actual door units.  Instead, I used the cut out pieces from my original teardrop outline profile, and screwed them together to make a roughly 3/4″ thick door.  I attached them to the trailer with stainless steel piano hinges, and used basic screen door type handles from Home Depot to open and lock it. For the windows, I used a piece of glass with silicone caulking to adhere it.  It makes for a fairly tough door, but I don’t like the rounded top, and I would rather the window could open.
The galley is a basic counter with some cupboards below.  It is all designed to be removed, so someone loading the trailer with camping gear or changing the mattress can access the main compartment with relative ease.  The galley hatch on the back is meant for propping it up and serving as a roof for whomever is cooking or preparing food in the galley. Frankly, this was a pain in the neck, and I think that a galley on a teardrop just takes away from more space inside the camper.  I would not make another one again.  Camping is meant to be done outside, and I think the teardrop serves more as a storage and sleeping cabin than a mobile cooking kitchen. That can be done outside, at a campsite.
Step 4:
The Finished Teardrop Trailer
So, my teardrop is more or less fully built, primed, and painted with white paint (sanded in between three coats), and I can’t shake the thought of airbrushing some images on it, to make it stand out a bit.
When I initially began contemplating making a teardrop trailer, I imagined taking it camping in the various campgrounds and parks here in the Pacific Northwest, and my mind began picturing it with scenes of those famous landmarks and places that define this beautiful area of the country.  So, I finally decided to paint some murals on it.
One, I decided, needed to show a Cascade-type mountain peak, like Mount Hood, and another would feature Multnomah Falls, an icon of Oregon natural beauty.  The final mural showcases our rugged, amazing coasts, and the lighthouses that dot its landscape (not pictured)
Mount Hood Teardrop Trailer Mural
First, I decided to try and incorporate the window into this mural by making it the window of a cabin looking over a meadow under the shadow or Mount Hood, Oregon’s tallest mountain peak (and dormant volcano). I started by gathering images of my own photographs and others that fit what I was going for.  The cabin I created from an image I found on Google, and the shot of Mt. Hood was from one I took several years ago.
Hope this helps!  Visit http://MakeItWithJason.com for more tips and to see some more examples of my painting, drawing and design work.
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
91 Discussions
scooters2
7 months ago
very nice, like the outside mural. Did you have plans? I just kind of winged it. I like looking at all the other designs and going oh I should have done that. Have fun camping.
treymartin82
1 year ago
I sent a message that I hope went through to you. I will send it to you on your blog page also just in case.
RonaldT11
2 years ago
I agree with you 100%
AskMsGoldBond.
3 years ago on Step 4
nice.. Im from Portland Oregon living in NY. Now Im getting divorced.. looking forward to going back to Portland. Your design may work for me too. I have a small generator for my electrical needs. Im excited to hurry up, and get started. Least I might be here for another winter. UGH..!!
caethelwulf
3 years ago on Introduction
Hey Octar,
I am stealing yer plans...this will make an Awesome Hunting Trailer for me...Also here in the Great pacific Northwest. Thanks.
moto-klasika
4 years ago on Introduction
Jason,
Excellent plans and realisation of simple and cheap tear-drop camping trailer!
Just two notes:
- Your are quite right about simple kitchen for cooking outside! A few decades ago, we have light camping tent-trailer and cooked always outside. But, not only we - all people wiht big ADRIA camping trailers, fully equiped - never used thier kithcen inside - but have simple equipement to cook outside...
- About the weigt: our tent-trailer was heavy around 320 kg ~ 700 pounds, and we menaged to pull it by small FAIT 600 D and TRABANT 601,and my brother with Citröen Dyane (all cars had engines of 600 - 770 cc and 25 - 32 HP) ... problems were across Bosnian mountians, but never really serious. On level ground - no problem with speeds up to 80 km/ hour ~ 50 mph (that was legal limit anyway)... So, with any modern automobile, there shoudln't be problems with such and bigger weights?
Regards,
Zoran
P.S.: Planed to transformed it into tear-drop trailer, but instead of that made motto-camper, which was stolen when finished!
Louise W5152
4 years ago on Step 4
I believe I'll try it. Thx for the basics & "If I had it to do over again..." comments.
I like corrugated tin. Think I'll try that for the roof. Perhaps using the redwood corrugated trim for the edges, and seal all with silicone.
What about a simple opening window on the side panel? (Forget the door window - no impact shocks from shutting it.
I grew up in Scappoose!
Just Make It, Louise! A small window should be a good option. I'd totally buy the windows and door if I were to build one again.
Used to drive through Scappoose several times a month to do work at the paper mill in St. Helens, OR.
TomS14
Wow! That's really impressive work. Have you done projects as big as this one before? I've been trying to find or make a horse trailer, but it's tough to find the right supplies. I've drawn up a few sketches, but nothings really great yet. http://www.mustangtrailers.com
robert.g.stewart.3
Looks good but I would not have placed the hinge of the drivers side door to the rear. If for any reason it comes open while driving it would slam with tremendous force against the side of your trailer. Look at factory ones they have RH and LH doors that always open from the rear forward. Just thought I would mention for others attempting this.
gloryhound100
Any idea what total weight was with trailer included?
neil.kay.79
nice work mate! lovely simple idea, definately worth a go. cheers man!
traisjames
Do you have the google sketch up available for download anywhere?
