Temperature Control for Kitchen Appliances
66,306
186
17
About: Here is a site from when I Lived aboard and cruised in a wooden boat: www.slowtimes.com Current blog of randomness: growdown.blogspot.com I am trying to concentrate my dwindling hobby time only on boats as...
In this Instructable, I will step through controlling the temperature of most kitchen appliances. As an example, I will use an old Westbend Poppery popcorn maker (aka. coffee roaster), but these same techniques will be applicable to most hot plates, coffee makers, and waffle irons.
This instructable puts you at risk of electrocuting or burning yourself. I will do my best to point out potential pitfalls, but you must use common sense. If you are comfortable with household AC electricity, this poses similar dangers plus potential burnination.
This probably isn't a good first Arduino project, but it might work as a second once you are comfortable with the general principles. You will need either a soldering iron or a breadboard. The total cost can be as little as $30, but probably will run between $60 and $90 after shipping.
Step 1: Parts
There are just a few parts to add, but for each has options.
1. Arduino or any other *duino.
There are a number of choices for Arduino these days. I will use a standard USB version, but any should work.
1a. USB Cable
1b. (optional) power supply for Arduino if you want this to run untethered from your computer. What? You don't want to have a computer permanently attached to your kitchen appliance?
You can buy a lone Arduino or a nice starter kit from adafruit.
2. Temperature Sensor
There are many options for sensing temperature with your arduino. I'll describe two different techniques, both providing a voltage that correlates to temperature. This voltage is easily read by the analog inputs of the Arduino.
Quick answer
For this tutorial, I'm going with the pricier but a slightly easier solution of a thermocouple and amplifier. This is because there is no soldering required as most thermocouple come with leads already attached. In practice, I've used the LM34 option the most (see below), as it's cheaper and a more accurate.
To follow along exactly, order:
1x AD595CQDatasheet
1x T-29
See below for more Temperature sensing options.
3. Solid State Relay
This part will allow the Arduino's 5v DC output to control the AC power that used in the heaters of your appliance. The world of solid state relays (SSRs) can be pretty overwhelming, and there are many places to go astray. The good news is that digikey just started carrying a line of affordable SSRs. These particular SSRs have a few key features we need. As you can read on their datasheet they take 5V DC input, provide 50 to 250 Volts AC output, have built in heat sinks, screw terminals, and provide an LED light that shows when they are switched on (super helpful). These are also very affordable for SSRs at $12 - $16.
The only question you need to ask is about the wattage of our appliance, and your household voltage. In the US, most heaters and appliances are 1500 watts and under, and use 110 volts. From Ohm's Law we know that
Watts / Volts = Amperes thus
1500 watts / 110 volts = 13.6 Amps
A 1500 watt appliance using USA household 110 volt AC power, uses about 13.6 amps.
what you need to make sure is that the current used by your appliance is under the rated current of your SSR. From the above calculation, a 15 Amp SSR will suffice.
This 15 Amp Optek SSR will do nicely and can be ordered with your temperature sensing parts. If you are in Europe, or anywhere with 220 ac power, you require only half the current as in the US, so 10 or 15 amps will cover all but the beefiest heaters.
Here are a couple more amperage options in case you need.
10 Amp
25 Amp
40 Amp
4. Wires and possibly some crimp connectors and breadboard
Except for the wires connecting the relay to the appliance, standard 20 or 22 AWG hookup wire is fine. For the higher voltage, you might be able to just use wires from inside the appliance, from an extension cord, or household wire from the hardware store. Probably you don't want to use the tiny map wire on any substantial heating element. Look at what's in the appliance already, and don't go smaller than that. Also, feel the wire (where its insulated!) with our hand and if its getting warm, think about getting a lower gauge wire with more girth.
Depending on the types connectors used inside your appliance, some crimp-on connectors can be very helpful, such as eyes or spades. Also, there are simple crimp tubes that splice two wires together. You want to get the right size crimp piece for the wire gauge you have so it makes good contact to the wire when you squeeze it. While soldering heavy wire is possibly, depending on your soldering iron, it can be between frustrating and impossibly. Crimp ends are often total sweetness.
If you are using the AD595, you'll need a breadboard to hook it up.
More Temperature Sensing Options - (you can safely ignore this if you choose)
Option a) LM34 or LM35
This is a single 3 wire part with from National. The LM34 correlates best to Fahrenheit, the LM35 to Celsius. Since we are attaching this to an Arduino, it doesn't really matter as you can do the conversion in software. The LM35 is more expensive for some reason. For either of these, you have yet another choice (there are actually more choices, but probably not worth considering) of the package, metal or plastic. This part will require soldering 3 insulated wires that can handle whatever temperatures they might be exposed to. Not that this sensor cant be submerged, and shouldn't be in direct contact with your food as some thermocouples allow. I've stuck it in boiling water, and it throws off the sensor pretty good. If you were to dip the whole thing or the exposed wires in epoxy or similar, it could possibly get wet. As with any option, if its going to be actually touching something you eat, make sure it's not poisoning you (ie. lots of wire still has lead in it).
The parts ending in AH are the metal version, a TO-46 little metal can package. These cost more and provide a larger temperature range.
LM34AH - $13.86 from Digikey
-50F ~ 300F
LM35AH $16.90 from Digikey
-55C ~ 150C
The parts ending in CAZ are in the plastic TO-92 package. They are cheaper (even can be sampled for free!), but they have a smaller temperature range. They are fine as long the temperature range is okay for your use case, for example the perfect temperature for brewing coffee, or any kind of water bath up to and including boiling point.
LM34CAZ $7.14 from Digikey
-40 to +230F
LM35CAZ $5.50 from Digikey
-40 to +110C
I will use the LM34AH in this example as I have one already. Other than
option b) Thermocouple
Thermocouples are a common way to measure temperature. They come in many shapes and types. We will use type K because they are common and have a monster range of 200 C to +1350C.
You can buy your thermocouple from Sparkfun ($13.95) or a nice bolt-on variety from Omega (~$8.00) if that works for your application. Thermocouples are nice because they come prewired in a variety of lengths. If you are buying the amplifier (below) from digikey, they have a couple of K -types in stock, including this T-29 bead type.
The trick with these thermocouples is that you need a thermocouple amplifier to translate their output into a voltage that is linearly correlated to temperature. This makes it very easy to interface to the Arduino. Enter the AD595. The AD595AQ has a +-3 degree accuracy and is available at Sparkfun ($17.95). The AD494CQ has +- 1 degree accuracy and is available from Digikey. Digikey also has both versions in ROHS (lead free package) versions for 10 - 20 bucks more each if you would like. These are 14 pin DIP (will fit in a breadboard) packages. Even though they are 14 pins, you can breadboard one without a lot of effort.
There are many many more types of thermocouples, as well as numerous other techniques for sensing temperature you could use with the strategy presented here.
Step 2: Sensing Temperature
Now you want to hook up your breadboard and AD595 as shown in the picture. The attached schematic is from the datasheet for the AD595.
All the Sensors presented here translate temperature into voltage. In particular, 10 mV per degree, so 0 Volt = 0 degrees, and 2.5 V = 250 degrees (except for the LM34, degrees are in Celsius). We connect the output of the sensor to one the Arduino's analog inputs. We'll do this now, and write a temperature sensing program (aka: thermometer) that will send the current temperature back to your computer.
The code below goes with the wiring in the image to make a simple thermometer.
If you've never messed with an Arduino before, here is a great tutorial to get you started.
// Define which analog input pin we have connected to the temperature sensor
#define TEMP_SENSOR_PIN 0
// if you tie the Arduino's vRef to the 3.3 volt supply, change this to 3.3
#define ANALOG_VOTLAGE_REFERENCE 5
void setup() {
Serial.begin(115200);
void loop() {
// prints the currrent temperature with 1 place after the decimal point
printFloat(getTemperature(), 1);
// print a carriage return
Serial.println();
// rest 100 milliseconds
delay(100);
float CtoF(float c) {
// optionally convert from Celsius to Farenheit if you are into that sorta thing
return c * 9.0 / 5.0 + 32.0;
float analogInToDegreesC(int inputValue) {
// divide by 1023, the maximum possible input value, that scales the input between 0 - 1
// then multiply by the reference voltage, which scales 0-1 to 0-vREF (default is 5V)
// lastly, multiply by 100 to scale it to 10s of millivolts or degrees
return inputValue / 1023.0 * ANALOG_VOTLAGE_REFERENCE * 100.0;
float getTemperature() {
// read the analog input, convert to degrees C, and covert to F
return CtoF(analogInToDegreesC(analogRead(TEMP_SENSOR_PIN)));
// ---- This last function, printFloat isn't necessary to understand unless you want to
// ---- feel free to ignore it for now, and treat it as a built-in utility,
// ---- it prints out floating point point values
// printFloat prints out the float 'value' rounded to 'places' places after the decimal point
void printFloat(float value, int places) {
// this is used to cast digits
int digit;
float tens = 0.1;
int tenscount = 0;
int i;
float tempfloat = value;
// make sure we round properly. this could use pow from <math.h>, but doesn't seem worth the import
// if this rounding step isn't here, the value 54.321 prints as 54.3209
// calculate rounding term d: 0.5/pow(10,places)
float d = 0.5;
if (value < 0)
d *= -1.0;
// divide by ten for each decimal place
for (i = 0; i < places; i++)
d/= 10.0;
// this small addition, combined with truncation will round our values properly
tempfloat += d;
// first get value tens to be the large power of ten less than value
// tenscount isn't necessary but it would be useful if you wanted to know after this how many chars the number will take
if (value < 0)
tempfloat *= -1.0;
while ((tens * 10.0) <= tempfloat) {
tens *= 10.0;
tenscount += 1;
// write out the negative if needed
if (value < 0)
Serial.print('-');
if (tenscount == 0)
Serial.print(0, DEC);
for (i=0; i< tenscount; i++) {
digit = (int) (tempfloat/tens);
Serial.print(digit, DEC);
tempfloat = tempfloat - ((float)digit * tens);
tens /= 10.0;
// if no places after decimal, stop now and return
if (places <= 0)
return;
// otherwise, write the point and continue on
Serial.print('.');
// now write out each decimal place by shifting digits one by one into the ones place and writing the truncated value
for (i = 0; i < places; i++) {
tempfloat *= 10.0;
digit = (int) tempfloat;
Serial.print(digit,DEC);
// once written, subtract off that digit
tempfloat = tempfloat - (float) digit;
Step 3: Intercept the Heater Control
Here is where things get a little more creative. The goal is to find the pair of wires that feed your heater. This is also where it helps to have an older or simpler appliance.
- If there is no temperature control at all, such as with this popcorn maker or most hair dryers, all you have to do it insert the SSR into one side of the heater power.
- If your appliance already has a thermostat in it, such as in a hot plate or coffee maker, you want to bypass that thermostat. It has two connections and you will want to move to those over to your SSR as it will acting as the new heater switch instead of the thermostat.
- If you have an adjustable thermostat, such as a hot plate with a dial or an older waffle iron, you can effectively bypass that thermostat by turning it to its maximum setting, and leaving it in the circuit. In this case, you get the added benefit that the thermostat will act as a safety to your electronic control. If it gets to the maximum temperature of the machine, the original thermostat will switch off power to the heater.
- If the setup is very simple, such as hot plate or toaster, you could possibly not hack the appliance at all, but instead, an extension cord, and plug the appliance into a hacked extension cord with the SSR in line. This cord would be switching power to appliance according to the temperature. For this to work, you definitely need an appliance without out any smarts, so its not reseting or similar when you power off the entire thing. In the case of the popcorn maker, its almost that simple, but we have to go inside it and switch only heat, leaving the fan power intact.
SAFETY
If you don't have a little cover for your SSR (and perhaps even if you do), be sure to wrap the AC terminals in electrical tape to avoid accidently electrocuting yourself or sensitive electronics. I once had a usb cable whose other end was attached to my arduino touch a live SSR. Blamo, instant death to the Arduino and everything part it was connected to (it was an expensive millisecond).
This is a good time to remind you that besides electric shock, there are many possibly routes towards causing a serious fire (like burn your house down fire) with these modifications. Be sure to always always always stay with your appliance when it is running, and watch it. Be mindful of bad burning smells, smoke, and anything out of the ordinary. Do not under any circumstances leave it unattended, even after its been working flawlessly for months.
Step 4: The Magic of Feedback
With an SSR controlling the heater of your appliance, one control wire goes to ground, and the other to a digital output on the Arduino. Now the Arduino can switch the heater power. By switching the heater power according to the input from the thermocouple, you invoke the magic of feedback! Feedback is powerful and can be mysterious, sometimes seemingly with a mind of its own.
The attached movie will show you the feedback in action. Watch as the LED light on the SSR blinks on and off. You can also heat the fan speed responding to the electrical load as the heater turns on.
// With the AD 595, this process is just a matter of doing some math on an
// analog input
// Thanks to Karl Gruenewald for the conversion formula
// All code released under
// Creative Commons Attribution-Noncommercial-Share Alike 3.0
// This current version is based on sensing temperature with
// an AD595 and thermocouple through an A/D pin. Any other
// sensor could be used by replacing this one function.
// feel free to use degrees C as well, it will just give a different
// PID tuning than those from F.
#define SSD_PIN 2
float currentTemperature;
float highTargetTemperature = 100;
float lowTargetTemperature = 95;
void setup() {
pinMode(SSD_PIN, OUTPUT);
void loop() {
currentTemperature = getTemperature();
printFloat(currentTemperature, 1);
Serial.println();
if (currentTemperature < lowTargetTemperature) {
digitalWrite(SSD_PIN, HIGH);
if (currentTemperature > highTargetTemperature) {
digitalWrite(SSD_PIN, LOW);
delay(100);
// END Temperature Sensor
int digit;
float tens = 0.1;
int tenscount = 0;
int i;
float d = 0.5;
if (value < 0)
d *= -1.0;
d/= 10.0;
tempfloat += d;
if (value < 0)
tempfloat *= -1.0;
tens *= 10.0;
tenscount += 1;
if (value < 0)
Serial.print('-');
if (tenscount == 0)
tens /= 10.0;
if (places <= 0)
return;
Serial.print('.');
tempfloat *= 10.0;
Step 5: Advanced Techniques
In this first installment, we've covered the electronics and the most basic temperature control algorithm, the equivalent of a thermostat. Now that the hardware is setup, it will be time to concentrate on software. In the next installments, I will be covering the following techniques, but you might want to start playing with it now.
- Signal smoothing. If you keep a running average of your recorded temperature, you can stabilize your temperature sensor and remove a lot of noise from the signal.
- Adjustable temperature set point. Enter your temperature set point from a laptop.
- PID. This temperature algorithm made famous amongst coffee people by espresso hackers is now at your finger tips. I will cover the installation of this algorithm to your Arduino as well as tuning it for your application. If you cant wait, there is PID code for your Arduino here.
- Fancier code on your host computer. Right now, the Arduino host software just prints the incoming temperature data to the screen. Once we start messing around with PID, we want graphing and an easy way to tune the algorithm. Luckily, Arduino's parent application, Processing, allows us to write a great cross-platform host application to provide a fancy graphing front end to this system. If you cant wait for the instructable, head here for some code.
- Temperature Profiles. Once you have ultimate control of your temperature, one way to take it further is to write code to automatically adjust the target temperature over time. In the world of coffee roasting, this has proven to have a significant impact on coffee flavor. What happens to bread if you toast it with high heat and then ramp it down over 5 minutes? I don't know, but it's conceivable that the temperature over time profile could have a significant impact on the quality and texture of your food. fun!
- More parts. Add in an LCD display, or buttons to adjust your set point. Tack on an ethernet shield and get your temperature plots on a web page.
First Prize in the
Hungry Scientist Contest
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    17 Discussions
    DonCesare
    3 years ago
    Excellent 'ible. Congratulations it is very well done and very informative. I have a question though, could an attiny85 be used instead of an UNO? Since there are not so many pins used, maybe I could simplify the project.
    Thank you before hand for your answer and advises. Looking forward to build your model and hear from you.
    revivemktg
    4 years ago on Introduction
    Hi @Timothy,
    Great instructable! I'm just getting familiar with other versions of Arduino board, is there any reason the Nano would not work for this scenario?
    RollieMae
    5 years ago on Step 5
    Hello, hmm. Do you have the schematic diagram for these? This is awesome, I also wanna make this :))
    hawkwood
    5 years ago on Introduction
    that is great. But the AD595CQ is so expensive for me. Maybe thermistor sensor is a much cheaper choice.
    globrite
    A nice and safe alternative is to use a Wattstopper power unit which is UL approved, has zero voltage switching and as a bonus has DC output at about 150 mA to power your controller. One such unit (B-120 EP) is available from Amazon for about $15. - Enjoy.
    abefetterman
    8 years ago on Introduction
    Thanks a lot for the great instructable! I like how many temperature probes you cover, and the arduino code is very useful. Do you have any suggestions for waterproofing the thermocouple/sensor? Also, have you been satisfied by PID control, or have you changed the algorithm?
    eecharlie
    9 years ago on Introduction
    I'm an electrical engineer a bit out of the loop on different ways to control AC loads with logic signals.
    What are the differences and relative merits between SSRs and triacs? I have noticed that triacs are a hassle to control with inductive loads and PWM synchronized with the AC power. But it seems like the optoisolation of an SSR might be a little overkill - though I haven't checked cost differences.
    Great instructable! You might link to the code elsewhere and post it in a fixed-width font if possible. I should have referenced this instructable in mine,
     www.instructables.com/id/Mr-Compost-How-to-make-an-in-kitchen-compost-tur/
    omnibot
    10 years ago on Introduction
    Very instructive and cool use of arduino but .. how is this different from adding a thermostatic switch to the device?
    kikiclintomnibot
    this is different because you can track the temperature, as well as prevent overshooting if you calibrate it enough. Get it to add less heat as you get closer to the target temperature instead of getting to the temperature, and then shutting off, and then turning back on once it gets below. It can prevent swings and oscillations.
    timothyomnibot
    That's a good point. I don't think this example is any different from a thermostatic switch, a switch controlled by a thermostat, right? I feel this is more of a jumping off point for more advanced temperature control such as using PID, or other fanciness such as described in step 5.
    kikiclint
    dang, I did this project without an arduino last year for a class, and converted it to arduino, and was in the middle of writing up an instructable. Good job. Something I would add is that thermistors are a very cheap way of getting a reliable temperature. I may still post mine since it will help to calibrate for a thermistor.
    Fantastic instructable, I have tried something similar but packed in after many failures.
    nejo0017
    Hi and thanks for this instructable! Because the AD595 is damn expensive I'll try to find another solution for the signal processing. I got a Typ-K thermocouple and will use your instructable to get it work. Regards
    timothynejo0017
    Thanks for the tip, I didn't know about that part. Also, for anyone looking to trim costs, if you can handle the shorter temperature range, I definitely recommend sampling the LM34. free!
    andrimarnejo0017
    The MAX6675 is a cheaper alternative and also has the added bonus of having a digital interface. The only downside is that it can only be sampled in SMD.
    Mongpoovian
    Wow! How the heck did I miss this instructable? I've been looking for a cheap, reliable way to do this, thanks!
    troyml
    This is a great instructable, and something I can and will definitely be using.
