Template to Miter Tube
14,483
135
12
About: Doing random stuff, from kid toys to wood oven. Learning everyday, building and fixing.
To help making tube to form straight T or according to the desired angle of T, I have done another online tool to generate paper template. Previously I made this instructable to make angle tube cut.
In the middle of the page, url here under, you will have to enter :
  • diameter of main tube in millimeter
  • diameter of the inserted tube
  • angle in degree of insertion
Then click to generate a pdf file.
http://briconosaure.com/patron-de-decoupe-de-tube-t/
Before printing the pdf be sure that the document will not be scaled by your computer, you would loose the correct dimensions.
Step 1: Cut Template and Apply
The pattern cut after printing is placed around the tube with a tape.
Step 2: Marking
I mark in black the trace on the tube "receiver" by plating the inserted tube.
And let's go for the cutting, I made a test with a metal tube of 42mm and another of 20mm. My handling of the grinder did not make it possible to make something super clean, hence my illustration with cardboard rolls.
Step 3: Cut
As said above we can make T from tubes of different or equal diameters. For small tubes cutting is difficult but the next time I need a T with PVC pipes I think it will help me out.
Hoping this will be helpfull.
Cheers.
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    12 Discussions
    ricehq
    7 months ago
    I tried. The pdf I received generates a error
    "An error exists on this page. Acrobat may not display the page correctly. Please contact the person who created the PDF document to correct the problem."
    MathB3ricehq
    Reply 7 months ago
    Sorry to hear that, I made just a test and firefox did show properly the pdf.
    Perhaps pdf format incompatibility ? The test I just made was diameter 100, inserted diameter 80 and angle 20.
    What were your parameters ?
    If you have decimals, separator is the point , not the coma.
    Thanks for the feedback
    ricehqMathB3
    Reply 7 months ago
    Today I tried and it worked just fine! I am not sure of the numbers that I did use, ButI did not use decimal separators at all. I hate computers!
    seamster
    7 months ago
    This is really useful. Thank you for creating this, next time I'm working with tubing I will give your template generator tool a try. Bookmarked for later! Thanks! : )
    TheNecromancer13
    7 months ago
    The way I always do it is to clamp the metal piece in an angled vise in a drill press, then use a hole saw of the correct diameter to make a perfect cut. Then I don't have to screw around with templates or computers or anything like that.
    MathB3TheNecromancer13
    Reply 7 months ago
    I completly agree with you, this method fits when you cannot clamp or you just have a grinder and no hole saw.
    Have a try, it might help you one day : )
    belseyTheNecromancer13
    Reply 7 months ago
    Your method is probably easier when you are working with metal tubes... but this has many other applications (papercraft comes first to my mind) making it really useful!
    Willys36
    7 months ago on Step 3
    I wrote a routine to generate these templates for my TI 59 programmable calculator probably 30 years ago. Really dating myself!!!!
    MathB3Willys36
    Reply 7 months ago
    For me it was hp 48 gx but I did not have a printer then i wrote a tetris ;)
    HughB19Willys36
    Reply 7 months ago
    Remember the magnetic strips and the thermal printer? That calculator was fantastic. Also the library cartriges... I think I still have the Master Library book with all the equations. Thanks for the memory.
    Willys36HughB19
    Reply 7 months ago
    Yep. In fact I still have my 59 and the printer! It quit reading the mag strips. I was a real power user, wrote a lot of engineering programs for it, published a few technical articles featuring the programs. Then PCs came out and zoomed past me leaving me in the technical dust.
