Ten Ring Project
6,565
47
4
Ten rings project
This project is super fun to make and play, you can spend hours learning how to solve it in minuets! Well without any further delay let’s start building.
Step 1: Thing You'll Need
You’re going to need
Tools
1. Hammer
2. Pliers
3. Knife
4. Drill
5. Wood Clamp
6. Drill bit [the same thickness of your coper wire]
7. Sandpaper grit 80 and 220
8. Marker
9. Ruler
Materials
1. Piece of wood 2 inches x 9 inches
2. Two feet of aluminum wire folded in the middle
3. Five feet of coper wire
Step 2:
2nd Step
Measure your wood every one inch and mark it with a marker, as shown in the first picture. And then clamp it to the table were your working at.
Step 3:
3rd Step
Then drill holes were you marked with your drill.
Step 4:
4th Step
Now get the wood you are working with and sand it first with 80 grit and then 220.
Step 5:
5th Step
Get the coper wire and peel one side of it, then pull out the wire from the wire coating as shown.
Step 6:
6th Step
Set your wood aside for a minuet or two, because we’re going to make the wire part now.
Cut with the pliers ten pieces of coper wire
3 inches long, and bend them in the format of rings.
Step 7:
7th Step
Hold the rings with the pliers as shown
while hammering it to get a better circle. If you
have some wire from the rings two ends that ends
up one on top of the other cut it so that it stays
end with end as shown in second picture.
Step 8:
8th Step
Ok, time to look at all we made till now:
Ten holes in a wood 9 in x 2 in
Ten coper rings
If you have that you’re all right. Let’s keep going now. Cut ten pieces of wire 3 ½ inches.
Step 9:
9th Step
Make “fish hooks” in the end of the ten wires you just cut [remember DON’T CLOSE the wire’s hooks leave them slightly open]. Hammer the hooks to make them flat, as shown in the third picture.
Step 10:
10th Step
Put the rings inside of the hooks
and clamp the hooks shut.
Step 11:
11th Step
Now bring back your wood because we’re going to put everything together.
Get the wire and start to put them in as shown in the pictures one by one, till you put all ten of them in. The last one is going to hang over but that’s normal.
Step 12:
12th Step
Turn every thing on its side as shown, and clamp the pliers on the top part of the wires. With your hand pull the other side down so that the wires don’t come off.
Step 13:
13th Step
Clamp the wood to your working table. It should
look like the first picture.
Cut off the end of the wires as shown,
letting only about 3 centimeters on the bottom for
the wire not to come out.
Step 14:
14th Step
Purpose of the puzzle
.remove the aluminum wire from the coper wires. if you need help solving it you can watch this video.
Puzzles Challenge
Runner Up in the
Puzzles Challenge
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    4 Discussions
    Luppoe
    2 years ago
    I made one of these about 40 yrs ago, but used plastic curtain rings and cotter pins to hold the rings instead of the cooper used here. Used an old wire coat hanger in place of the aluminum wire. Had many hours of fun with it.
