Tennis Ball Tripod
49,772
154
37
Recycle a dead tennis ball into a pocket camera tripod.
Get sharp photos using a wall, fence, tree branch, door, car hood, bamboo pole, or a signpost.
Velcro, bungee or hang from a suction cup with the optional mounting holes.
Step 1: Mark and Cut
Cut the ball in half with an kitchen scissors, a craft knife, or even a kitchen knife.
Wear good safety goggles. Blades can slip or snap.
Mark three tripod feet on the edge of the ball with a pen or pencil.
Each flat foot is about 3/4 inch (18mm) wide.
There should be about 2 inches (50mm) between the edges of the feet.
Cut arches between the feet to make the basic tripod shape. Arch size and shape are not important.
Cut a 3/4 inch hole in the top of the ball.
Optional step: cut a side slit in the top hole for more tilt.
Optional step: make bungee cord holes above each foot.
Scroll down below the photo and click the other pictures for this step.
Step 2: Make Washers
Cut two circles from the other half of the tennis ball.
Each should be about 1.5 inches across.
Drill, cut, or punch 1/4 inch holes in their centers.
Scroll down below the photo and click the other picture for this step.
Step 3: Assemble
Buy a 1 inch plastic bolt, 25 cents at Home Depot.
It should be 1/4 inch diameter and have 20 threads per inch. This is close to the standard camera mount size. Since the bolt is soft plastic it will not strip or damage your camera.
Push the bolt through a washer so it sticks out of the felt side.
Then put the bolt through the tripod base from underneath.
And finally press the other washer on the top.
Now you can screw the tripod into the mounting hole on the bottom of your camera.
Scroll down below the photo and click the other pictures for this step:
Step 4: Use for Web Car Fence Window Wall
Use the tennis ball tripod on your desk for a web cam
The rubber feet keep the tripod from slipping on your car roof for quick group shots.
Optional bungee cord holes let you attach it to vertical, diagonal or horizontal poles, posts, fences and trees.
Suction cups let you mount your camera as a bird feeder or surveillance cam.
Or prop and level your camera against a wall, window or door jamb for steadier shots where flash is not allowed.
  • Gardening Contest
    Gardening Contest
  • Fandom Contest
    Fandom Contest
37 Discussions
Toga_Dan
6 years ago on Step 3
Cool idea. This is about as small, lightweight and simple as possible.
Toga_Dan
SBDFFLS
6 years ago on Introduction
For this tri-pod us there a way to make it adaptable for an iPod touch
c ssgt seifer
10 years ago on Step 4
This is nice for people like me who don't want to spend money, and need a small tripod for sporting events.
robotmastern
9 years ago on Step 3
 actualy 1/4-20 is the standard size. so you could use aluminum.
BigMac96
9 years ago on Introduction
Absolutely Amazing! I used a longer bolt and a washer and a nut on both sides so I can adjust the height. 5-Stars!
iectyx3cGamernotnerd
Reply 11 years ago on Introduction
You have one too? This little Largan camera is a great webcam. And with the macro feature it takes good instructables photos. Good for taking MemEx photos when you see something cool you want to remember, isn't it? I have to hold my finger partially over the flash for macro shots to keep them from washing out though :)
The AV cable is awesome. The only thing that would make it perfect is if it were driver-less. Kind of like a USB flash drive. Newer small cameras just plug in without drivers. And now http://www.largan.com is gone :(
iectyx3cchg4
Largan is like Timex -- man I carry that in my pocket w/ no case, runs like forever on reg. batteries. Also cool is that y. can turn off the beep for "spy" photos.
