The $0.05 Stationary Bottle Opener
42,947
354
51
About: Desktop Support Technician by day ... Occasional hired gun rock drummer by night ... DIY home improvement enthusiast on weekends - maker of whatever I can imagine in between it all. I'm also a professional l...
If you're anything like me (handsome and funny), you misplace your tape measures constantly.  I have a small space and 4 tape measures .. still happens.  You also misplace your bottle openers and you don't carry one because your key ring is already crying for mercy.
You, my fine feathered friend, need a bottle opener you can't lose ... and you want it for free!!  Or a few cents if you don't already have a washer and a screw.
Supplies:
Step 1: The Parts and the Bits
Find yourself a washer and a screw.  I already had them.  You might have to steal them ... or buy them ... you should probably buy them.
Also, find yourself two drill bits.  Mine were 1 1/4" and 1 1/2" Forstner bits and I love them.  If you don't have a set, save up your allowance and get some.  You will thank me.  Maybe ask Santa if you know him.
Step 2: Drill the Larger Hole
Drill the larger hole in your desired location.  This was a mock up so it's a scrap 2"x4".  I went as deep as the bit, which was 1/2".
Step 3: Mark the Second Hole
Position the washer, making sure you leave enough room for the bottle cap, and mark for your second hole.
Step 4: Drill the Second Hole
With the smaller bit, drill the second hole, but only as deep as necessary for the washer to be flush with the surface.
Step 5: Install Washer
Pop the washer into the small, shallow hole and screw that bad boy down.
Step 6: Open That Bottle
You're done!  I installed mine in the front leg of my miter saw station as you can see in the first picture.  I'll never misplace that thing!
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    51 Discussions
    Loganandrew
    3 years ago
    Great idea thanks. I used a hockey puck instead of a piece of wood as a Father's Day present
    libertyss1
    5 years ago
    Great idea! I'm making one of these bad boys!
    mfayyaz
    5 years ago
    really easy
    godbacon
    5 years ago on Introduction
    Love it!
    suggested enhancement: routed cap luge covered in plexi or acrylic, with receptacle.
    lime3Dgodbacon
    Reply 5 years ago on Introduction
    Instead of a receptacle, you could fasten a magnet recovered from an old speaker.
    gnach
    What, you don't carry a Swiss Army knife? I thought everyone did. Clean design. I'd like to get a bigger peek at the sliding bench/work top, tho.
    gnachgnach
    I was too hasty. Instead of 2x4, use 3/4 saw butts but bore thru. Stain and varnish, or not, an give to the buds for C'mas!
    -BALES-gnach
    I don't like working with things in my pockets as I find it annoying for some reason. I have a Leatherman, but I set it down just like the tape measures. I like the 3/4" scrap idea for quick shop gifts.
    The stand in the picture is my miter saw station, which was a free Woodsmith Shop design.
    gnach-BALES-
    Sorry, I was trying to be clever. I'm the only guy I know that carries, but it is my favorite tool. Thanks for the miter saw tip.
    -BALES-gnach
    Here's a look into my shop. Some of the stuff is from designs I've found on youtube and many are my own. I'll be happy to answer any questions or point you to the source if applicable. Sorry that it's an FB page, but my personal site crashed years ago and I never took the time to rebuild.
    https://www.facebook.com/media/set/?set=a.377976242336320.1073741830.185206291613317&type=1
    godbacon-BALES-
    Drums! huh.
    Nice shop. I need to get mine set up. I have a stack of quarter sawn seasoning in the front yard. What is the stave jig do the curve or the bevel? I always wanted to make a barrel.
    -BALES-godbacon
    Correct on the jig. The miter saw was leaving gaps in glue joints, so this is one method of truing up the edge. Other methods would be some sort of table saw sled or even a modified shooting board and hand plane.
    gnach-BALES-
    Wow, most that's impressive. All in single car garage. You're a master of organization. I really liked the drum slitting sled, well executed. Thanks for the peek.
    godbaconrocklocker
    Not that a glue-up requires power tools. The shop-vac is pretty safe on a few beers.
    tjk1939rocklocker
    Don't you just love it? There's always someone out there looking out for your well being.
