The $10 Hexagon Tarp
44,298
213
7
I have always loved to go camping and recently started getting into backpacking, specifically with a hammock.  I scoured the internet in search of reasonably priced gear and was pleasantly surprised how affordable it was, until I came to the rain protection.  The first few trips out I went with a standard medium duty tarp that you can just about find anywhere that sells anything.  It's a very cost-effective solution but it can be large and clunky.  When looking at my favorite online shopping site, I found some very cool looking tarps that start around $50.  For what it does, it didn't really seem all that worth it so I started another search for a DIY project.
I came across a very insightful video on youtube by FloridaAdventurers.  Now he said he was able to make his for $3, but I went with a thicker material (3.5 mil as opposed to his 2 mil) and I included the cost of the paracord and duct tape, as well as my tarp is a little bigger.
Supplies:
Step 1: How Long Do You Want It?
I found a roll of Plastic Sheeting at my local Home Depot.  It measured 10 ft x 25 ft.  For this tarp I wanted to make a 10 ft x 12 ft tarp that would be a little more than the length of my 10 ft stretch-out hammock.
I measured out my 12 ft, marked it and cut it.
Step 2: Cutting the Angles
The roll comes folded up so that it's about 1 ft wide.  To measure for my angled cuts, I complete unfolded it and then folded it in half down the center where my ridge line would be.
I didn't want the angle to be too steep, so I measured in 3 ft from the edge on either side and made a mark.  With a very large straight-edge I drew my line from the mark I just made to approximately 1 in. from the top corner.  I left the 1 in. space for the duct tape that would eventually hold the center line in place.
Once I had my lines drawn, I used tarp clamps to hold the edges of the tarp together while I made my cuts.  Once I cut one side I cut the other and removed the scrap.
Step 3: Laying the Lines
Next thing I wanted to do is run paracord (type III 550 7-strand) throughout the tarp providing a pseudo skeleton.  Due to some space limitations indoors, i clamped the middle of the first line to the center of the tarp and strung it to the corner.
I used some white, Scotch Tough, duct tape to adhere the line to the tarp.  The tape itself comes in a roll of 135 ft and cost around $8, which is enough for about 3 tarps.  I put tape from about 1/2 in. from the clamp and 1/2 in. from the edge of the plastic.
Once that half of the line was done. I removed the clamp and repeated this process for the other line going to the other corner.
Step 4: The Flipside
After I was satisfied with the lines on one side of the tarp, I flipped it over and clamped both lines to the center of the tarp.
One at a time I placed the same amount of tape from center to edge.
Step 5: Ridge Line and Finishing Touches
Once the cross lines were in place i unfolded the tarp and laid it out so that the center line would lay flat.
I placed last rope that would be the ridge line and secured it in place on each point and the center with a small piece of tape.  Then, going from the center out to the point, put a long piece of tape.  I repeated that for the opposite side of that rope.
With all the lines in place, I wanted to add some extra strength to the edges of the tarp.  I pulled out some duct tape that would be long enough for one side and laid it upside down (sticky side up).  I gently raised the plastic up and pulled it half way over the tape.  I folded over the remaining tape.
After I edged all 6 sides I basked in the glory that was my new 6-sided tarp.  Enjoy
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    7 Discussions
    THEMONEY
    1 year ago
    Brilliant! So good of you to share it!
    lechampiondumonde
    3 years ago
    Looks really good! I might try making this with polyolefin, which is more expensive but has a better strength to weight ratio than 3.5mm plastic sheeting. I just posted another tarp design using polyolefin. Check it out if you want. Cheers!
    xcoreinmolinex
    5 years ago
    Very cool instructable! have you weighed it?
    Breygon
    5 years ago
    I've not come across hexagonal tarps before, is there a specific reason for this choice over a rectangular one?
    blaazemanBreygon
    Reply 5 years ago on Introduction
    A hexagon tarp will give you almost the same coverage but with a little less weight and will be more compact when packing it down.
    Breygon
    5 years ago
    schoonovermr
    I made one of these from the floridaadventures video and it rocks but i really love your additions of the paracord built in. i might have to remodel mine...
