The 3¢ Sticker - Make a Vinyl DIY Sticker
20,411
367
28
About: We love to create and we love trying new things. As we learn and grow we want to share our experiences with you and hopefully inspire you in some small way.
Through some trial and lots of error, we finally came up with a feasible way to make some vinyl-esque stickers. Using a combination of shipping labels and clear vinyl laminate we achieved what we think is the cheapest method with the best results. Sure, there are better ways to make them, like buying printable vinyl sheets, but this way is much cheaper and the results are pretty decent.
What you'll need
  • Printable shipping labels - we recommend full sheet labels; the stickiest you can find (we recommend checking eBay).
  • Clear vinyl laminate - this can be found at just about any home improvement store (Lowe's, Home Depot, etc.) It's usually located near the cabinets along with the drawer liners.
  • Something to smooth the laminate onto the paper (squeegee, scraper, etc.)
  • Printer (any kind will do)
  • Design software (nothing fancy - you could use Inkscape, paint.net, etc) Inkscape is what we used.
  • Scissors or paper trimmer
Make sure you check out the video, it shows a bit more of each step than the images do. Please enjoy and if you make it or something like it, we'd love to see it.
Step 1: Designing the Sticker
The whole thing of course, starts with your sticker design. You could do any shape you want, but the easiest solution would be a square or rectangle design. This will be even easier if you have a craft paper trimmer, especially a sliding cutter. We designed ours in Inkscape. Try to avoid curved cuts unless you're really good with a knife or scissors.
Step 2: Printing and Sticker Paper Selection
The next step is to print your design onto a good quality sticker paper. We tried a few different kinds and found that the standard scrap booking sticker paper or really any of the other big box store brands didn't work so well. They would lose there adhesion over time. So, we decided to try shipping labels instead. This worked great. They are super sticky and near impossible to remove once put in place.
The best we had found to this point came in a pack of 100 sheets and only cost 10.99 on eBay. These are super easy to find if you search for them on eBay. So, to this point we are at .11 cents per sheet or about .02 cents per sticker. Not a bad start.
Step 3: Choosing a Laminate
The next thing we wanted to do was give the sticker some protection and a little bit of that vinyl shine. In our first attempt we tried using Mod-Podge. It didn't work so well and it was prone to streaking and causing the colors to run.
The alternative was a type of laminate sheet. Luckily, we found a roll of clear vinyl laminate at our local home improvement store. It is advertised for laminating documents and pictures, but is sold along with the drawer liners or contact paper. A roll of this is about 5 or 6 dollars and you can get a lot of sheets out of it. About 72 sheets to be exact, if you get the 36 foot roll. So that puts us at about .08 per sheet or about .01 cent per sticker.
Step 4: Applying the Vinyl Laminate
To apply it, you need to roll it over the sticker sheet while pressing it down at the same time. A squeegee or some sort of smooth scraper works well for this. We used a drywall mud smoother. The main thing, is to keep the air bubbles out from between the sticker sheet and the laminate.
Step 5: Cutting Out the Stickers
Once the laminate is applied, you simply removed it from your work surface and cut them out using whatever method you choose. We used a paper trimmer for the straight edges and a pair of scissors to round the corners.
Step 6: All Done!
So, that's it. The total amount per sticker using this method is roughly .03 cents per sticker. Which is very cost effective if you don't mind putting in the time to make them which isn't a substantial investment anyway. We were able to make a sheet of these from start to finished stickers in about 4 or 5 minutes and most of that time is spent cutting.
For those who are interested, here is a cost breakdown (minus the cost of printer ink):
The sticker paper – $10.99 total about .11 cents per sheet / .02 cents per sticker
The contact paper – $5.48 total about .08 cents per sheet / .01 cent per sticker
We hope you enjoyed this DIY project and the video that goes along with it.
If you have any questions or comments please let us know, we'd be more than happy to help you out. Thanks for checking out this Instructable.
2 People Made This Project!
  • Pie Contest
    Pie Contest
  • Fat Challenge
    Fat Challenge
  • Jewelry Challenge
    Jewelry Challenge
28 Discussions
nehmo
3 years ago
A corner cutter (corner rounder punch) that cuts a rounded corner is better than scissors.
lynmillernehmo
Reply 2 years ago
Or a fingernail clipper :)
aaron0127
3 years ago
Looks great thanks
GingerS25
3 years ago
Great idea! This is off topic but I noticed you tried Mod Podge but it made the ink run. The way you stop this is by spraying the paper with a couple coats of clear acrylic fixative. Then you can use any of the Mod Podges. One good one that would be extremely durable is the Dishwasher Safe Mod Podge. Thanks again!
waylightcreateGingerS25
Reply 3 years ago
Cool. Didn't know about that. Thanks for letting us know. That would come in handy on other projects.
ConnieS36
3 years ago
I make vinyl decals to sell but, have to say i love this idea. I use a plotter to cut with so i do a lot of layering. This would be an awesome alternative when you have a design where it bleeds from one color to the next and dont have the expensive color cutters. Fabulous idea!
blue LED
3 years ago
Very good use of simple materials to achieve a good product..... in other words WOW!Way Cool
Toyocampergirl
3 years ago
You didn't take into account the cost of the printer ink in the price per sticker. The printer at work costs and average of $0.12 per page. I've used weatherproof shipping labels by Avery and they hold up to being on a water bottle in a bucket of ice water. They do however cost $0.09 each but virtually no labor!
waylightcreateToyocampergirl
Reply 3 years ago
I wasn't aware that there were weatherproof shipping labels. $.09 doesn't seem too bad. I didn't take the printer ink into account because I am not sure how much it costs per sheet with our printer. We refill our cartridges for fairly cheap, so I can't imagine it's too much. Thanks for the tip on the weatherproof labels I am very intrigued by this.
dollarseed
3 years ago
I really like the concept of using the laminate cover sheet. The last stickers I had professionally made for my wood shop cost an average of 2 cents each and are only 1.25x1.25 which barely leaves the image large enough to be legible. Kudos, you may find one of mine in your mail box soon :)
waylightcreatedollarseed
Reply 3 years ago
Awesome. I hope to see one soon. And I agree. The ones you can get online are really nice, but we couldn't justified the price and the amount that we would have to order to get a decent price. This is just a nice solution for all of the frugal people out there.
jolshefsky
3 years ago
I've made stickers using this method before and you can get very good results from DIY efforts. I have switched back to gourmet lamination (Avery, specifically, from cheaper GBC) because I prefer the waxed-paper backing that I find substantially easier to peel (GBC has plastic backing that flexes exactly the same as the lamination, so it's difficult to pick an edge apart.)
One problem is that it's not waterproof. It looks like it should be, but the exposed edge of the paper wicks water. It does dry, so if you use an ink that is not water-soluble (e.g. color laser; some inkjet) it will work okay for the occasional drop of water. If your ink is water-soluble, the text will bleed if it ever gets wet and end up looking very bad. In theory you could print on a plastic label (e.g. these polyester ones which I've never tried) then laminate and it'll be thoroughly protected.
Another cool option is to use clear labels (like these ones I've never tried). Obviously this would work best if you have a background that complements your ink color, so typically a light background (silvery, mirrored, etc.) for dark inks.
waylightcreatejolshefsky
Reply 3 years ago
Wow! Thanks. Very good suggestions. Very helpful. I know for a fact that these are not waterproof, but the price is right. I guess it depends on your intentions. Thanks for sharing this advice.
JakeTobak
3 years ago
Try leaving some outside to see how they stand up to UV rays from direct sun exposure. I suspect they'll fade pretty quickly when exposed to the elements, in which case you'll want to find another type of vinyl for using outdoors. I bet there's some Oracal vinyl that would work without driving the cost up.
waylightcreateJakeTobak
Reply 3 years ago
Awesome advice. We didn't design these for outside use, but I suppose some people would need them to stand up to the elements. I think they would most likely fade as well. I'll have to look into the Oracal vinyl. Thanks for the suggestion.
jchristian15JakeTobak
Reply 3 years ago
Great idea to check on the UV exposure. I'm going to try this with some club labels.
I8mAll
3 years ago
This instructable stands out as a very good example of how to think around a need to come out with what you want at a price no commercial company could dream of. So... Well done on a number of levels.
