The Arduino Synthesizer
214,802
540
51
About: I'm a Community Manager at Instructables and the voice of the robot on Twitter! www.twitter.com/instructables Tell me what projects you want to see in our Twitter feed! When I'm...
The Arduino is able to output sound through a library that has been developed called the Tone Library.
By creating an interface and a program that can call certain values to be output to an audio out, the Arduino Synthesizer is a robust tool for making a rudimentary noise machine. It uses granular synthesis techniques to generate a distinctive sound that can be a whole lot of fun for musicians, artists, tinkerers, and hobbyists.
Step 1: How It Works
Sound is created by playing the same sound grain, or samples (small pieces of around 1 to 50ms) over and over again at very high speed. Our ears and brains turn this into an audible hybrid of the repetition rate and the original grain, and it sounds like a constant tone.
The grain consists of two triangular waves of adjustable frequency, and adjustable decay rate.
The repetition rate is set by another control.
Step 2: Materials and Tools
To make this project, you will need the following things.
Parts:
(5X) 5K potentiometer
(5X) Potentiometer knobs
(3X) LEDs
(1X) SPDT switch
(1X) Light Dependent Photo Resistor
(1X) Arduino
(1X) Arduino Protoboard
(1X) Tactile Switch
(1X) Project enclosure
(1X) 1/8" Audio Jack
(1X) a whole lot of solid core wire
(1X) heat shrink
(1X) breadboard
(1X) jumper wire
(3X) 10K ohm resistors
(3X) 220 resistors
(1X) 9V battery
(1X) 9V battery clip
(1X) size M coaxial DC power plug
Tools:
  • soldering iron
  • solder
  • flux
  • glue
  • multimeter
  • drill
Step 3: Code, Circuit Diagram, and Power.
I have attached the code for the Arduino to this Instructable. You will need a USB 2.0 to upload it to your board. After you have uploaded the code from your computer, go ahead and attach the Proto Shield to your Arduino.
You have many options when it comes to power. The Arduino is capable of running on a 9v wall wart power supply, or you may use a 9V battery with a battery clip to a size M coaxial DC power plug. You may also power via your USB cable.
The circuit diagram was made with Fritzing, it has also been attached to this step.
Step 4: Using a Breadboard.
By using a breadboard to build the circuit first, it is much easier to transfer the circuit to your Protoboard later. Run wires from the GND and 5V to the - and + rails of your breadboard.
Then, connect the signal wires from the potentiometers to Analog Input 0-4 on the Arduino. The right and left side leads will get connected to the ground rail, and positive rail of the breadboard.
Connecting the potentiometers will control the grain, frequency, and decay of the synthesizer.
Analog in 0: Grain 1 pitch
Analog in 1: Grain 2 decay
Analog in 2: Grain 1 decay
Analog in 3: Grain 2 pitch
Analog in 4: Grain repetition frequency
Step 5: Wire Your Audio Jack.
Solder wires to the your 1/8" mono audio jack, make your leads fairly long. Connect your positive lead to PWM~ 3 on the Arduino. You will need a 10K ohm resistor between the arduino board and the positive lead of your audio jack. Connect the negative lead of your jack to ground rail of the breadboard.
Step 6: Connect Your Photoresistor.
One lead of your photoresistor is wired directly to your 5V positive rail on the breadboard, as well as Analog Input 5 on the Arduino. The other lead of the photoresistor is connected to a 10K ohm resisted ground rail.
Step 7: Connect a SPDT Switch.
Connect the signal, middle, lead of your SPDT switch to Digital pin 02 on the Arduino. The remaining leads are connected to ground, and the 5V positive rail that is resisted by a 10K ohm resistor.
Step 8: Wire the Tactile Switch.
The tactile switch has four leads. Allow the switch to straddle the bridge of the breadboard. Connect one of the two parallel pins to your 5V positive rail on the bread board, and the other to a 10K ohm resisted ground pin.  The last connection of your tactile switch connects a signal wire between the switch and Digital Pin 6 on the Arduino.
Step 9: Connect the LEDs.
Step 10: Test It!
This is the completed breadboarded circuit. Test with a pair of headphones, or connect to a small speaker. If you are using headphones, this is a mono output, and it will be loud. Do not put your headphones directly near your ear when firing up this synth.
Step 11: Drill the Enclosure.
Drill out holes in the project enclosure for each of the components that were placed in the breadboard. I used a gold paint pen to mark where I wanted my holes.
Drill five holes for the potentiometers.
Five small holes in a square for the tactile switch.
Three pairs of small holes for each of the LEDs
Two holes close together for the photoresistor.
One hole for your audio jack.
One additional hole for the SPDT switch.
Step 12: Start Adding Components to the Enclosure.
Thread the five potentiometers through the holes that have been drilled, then secure them into place.
Step 13: Add the Rest of the Components.
Secure the LEDs, SPDT switch, tactile switch, audio jack, and photoresistor into place. A dab of hot glue worked great to quickly mount all of these components.
Step 14: Wire the Audio Jack to the Protoboard.
The next few steps outline how to move the circuit from the breadboard to the Protoboard. Because all of your components are secured to the enclosure, it will be simple to run wires from your components to the board.
Solder lead wires to all of the components within the the enclosure, using red and black wires respectively to denote which leads are positive and negative.
On the Protoboard, connect one wire to digital pin 3, and solder into place, run a jumper wire to the center of the board so that you may break the line with the same 10K ohm resistor from the breadboard.
When you solder these into place, make sure you drop enough solder on to the board to connect the wire to the resistor.
Step 15: Solder in the Resistors for Photo Resistor, Tactile Switch, and SPDT Switch
Extend two jumper wires from the ground rail, and a jumper wire from the positive rail, out to the middle of the board. Form connections to your remaining 10K ohm resistors.
Connect a small jumper wire from Analog 5 that will run to the lead of the photo resistor.
Step 16: Solder Your LEDs Into Place
Connect 3 220 Ohm resisotrs to pins 9-11 on the Protoboard, sink the other ends of the resistors into the open holes of the protoboard, and then solder those wires to you LEDs.
Daisy chain the ground wires for the LEDs, then run a single grounding wire back to the ground rail on the Protoboard.
Step 17: Wire the Potentiometers to the Protoboard.
Daisy chain the positive and ground leads from the potentiometers together, then insert them into their respective rails on the Protoboard.
Wire the signal wires of the potentiometers to Analog 0-4, I kept the grain and frequency knobs on the first row of knobs, and the sync knobs below them.
Again, the signal wires sync accordingly:
Step 18: Attach Your Knobs to Your Potentiometers.
Zero all of your potentiometers out, then align the line on the knob with the zero position on the potentiometer shaft.
Using a small flathead screwdriver, attach your potentiometer knobs.
Step 19: Connect the Protoboard to the Arduino.
Connect the short jumper wires on the Protoboard to the long leads in the enclosure. Solder the remaining wires to the ground rail, and 5V rail on the Protoboard, respectively.
Snap the Protoboard into place on top of the Arduiono.
Plug it in, seal it up, and you're ready to jam!
Step 20: Play With It!
All of the switches and potentiometers are completely interchangeable! instead of using all those potentiometers try replacing each of them with photo resistors, or combinations of the two.
References:
http://blog.lewissykes.info/daves-auduino/
http://code.google.com/p/rogue-code/wiki/ToneLibraryDocumentation
http://arduino.cc/en/Tutorial/Tone
http://itp.nyu.edu/physcomp/Labs/ToneOutput
http://code.google.com/p/tinkerit/wiki/Auduino
2 People Made This Project!
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
51 Discussions
PhonX1
Question 9 months ago
I can't download tone library where the zip file?
AAxelB
Question 1 year ago
Hello everyone, I started with arduino and electronics, I tried this editing but it does not seem to work. I use potenciometers 10k, I think the problem comes from there, is it possible with some modifications in the code, to run this circuit with pot10k?
Thank you for your help !
claude_cundiff
2 years ago
This is great! Thank you! One of my goals before my departure from this world is to recreate the TB303 and perhaps make my own synths...so I guess that's more than one item in the ole bucket list.
LoekJ
2 years ago
could you tell me what to do when you get this error?
Arduino: 1.8.1 (Windows 10), Board:"Arduino/Genuino Uno"
De schets gebruikt 4324 bytes (13%) programma-opslagruimte. Maximum is 32256 bytes.
Globale variabelen gebruiken 967 bytes (47%) van het dynamisch geheugen. Resteren 1081 bytes voor lokale variabelen. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\\.\COM4": Het systeem kan het opgegeven bestand niet vinden.
The translation:
Sketch Uses 4324 bytes (13%) program storage. Max is 32256 bytes.
Global variables using 967 bytes (47%) of the dynamic memory. This leaves 1081 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open (): Unable to open device "\\ \ COM4.": The System Can not Find The specified file.
Probleem bij het uploaden naar het board. Zie http://www.arduino.cc/en/Guide/Troubleshooting#up... voor suggesties.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
sergio4688
2 years ago
In addition to the input Jack, How could add another input Mini Jack?
ColinM74
2 years ago
could you tell me what values the photoresistor needs please?
licheong
2 years ago
When the output connect it to headphone, it is too loud because it is speaker-out level. Better add a 10k-1k resistor divider to protect your headphone!
ninuxi
3 years ago
I've play my bike With this arduino synth and Ipad with audiobus (Caramel, Stereo Designer, Muckraker, GliderVerb) https://youtu.be/mlR3V7W1JzA
solohust
3 years ago
All the links to RadioShack 404.
leolodreamland
3 years ago
i cannot compile this. added the latest tone library but it just sticks compiling. tried classic 1.05 and classic 1.06 as well as latest full...
mathesen1097
4 years ago on Introduction
What do the switches, photoresistor, and leds do? I wanted to replace the photoresistor with a distance sensor that used a laser and phototransistor.
randelia
5 years ago on Introduction
Code does not work on Leonardo. Code uses timer2 - leonardo does not have a timer2.
Does anyone have an update for how to run this on a Leonardo? I read something about using timer3 & tuning it's 16bit timer as compared to timer2 being 8bit...
Using Arduino 1.0.5 IDE - i get these compiler errors (all relating to timer2):
sketch_dec10b.ino: In function 'void audioOn()':
sketch_dec10b:259: error: 'TCCR2A' was not declared in this scope
sketch_dec10b:259: error: 'COM2B1' was not declared in this scope
sketch_dec10b:259: error: 'WGM20' was not declared in this scope
sketch_dec10b:260: error: 'TCCR2B' was not declared in this scope
sketch_dec10b:260: error: 'CS20' was not declared in this scope
sketch_dec10b.ino: In function 'void loop()':
sketch_dec10b:481: error: 'OCR2B' was not declared in this scope
sketch_dec10b.ino: In function 'void TIMER2_OVF_vect()':
sketch_dec10b:525: error: 'OCR2B' was not declared in this scope
AlexD6randelia
Reply 4 years ago on Introduction
Did you ever find a solution? I'm trying to use a micro arduino and am having the same issue.
randeliaAlexD6
Never found a solution - reworking timers & interrupts for a new architecture is over my head! However you should check out Mozzi - it runs on Leonardo so it should work on Micro. I haven't played with it much but if you're looking to make cool noises/music on an arduino you should check it out.
http://sensorium.github.io/Mozzi/
jservin1
Hello,
I was wondering if the a5k pots are a necessity? I have a bunch of b5k pots laying around but am not certain that this would effect the sound of the unit. I don't believe it would because the pots are processing data and not audio signal. Please correct
me if im wrong.
audreyobscurajservin1
Reply 5 years ago on Introduction
the A or B orientation just indicates which direction you have to turn them to add resistance..... either one should work :D
