Universal Cable Shortener
21,524
270
26
The Cable Eater is a must have to reduce the length of a long cable
that runs off your desk and tends to be crushed by the wheels of your desk chair...
I designed this so i can keep my headset wire safe (2 meters long and 3mm thick), and thanks to it, I transformed my 2m long wire into a 30cm long !
Length gain : up to 99% with a standard 3mm wire !
See Step 5 to download the model and follow the print instructions.
Step 1: Place Your Cable
Take the A part, and put your cable in the center
Step 2: Secure It
Block your cable using part B, snap-fitting it on the A part pivots.
Step 3: Cover It
Snap-fit part C pivot to the part B center hole.
/!\ Make sure your cable is passing between the 4 little 'teeth' of part C /!\
Step 4: Just Roll and Enjoy It
Rollup your cable by holding Part C in one hand (part C should face the ground), while turning Part A CLOCKWISE (turning the other way might damage your cable) till the desired length !
To unroll your cable, do not turn the parts, it's not necessary. Just hold the 2 strands with both hands, and pull.
Step 5: How to Print It ?
Working with PLA, but ABS with its flexibility might be easier to assemble (didn't tried yet).
As there are some snap-fit parts, I would recommend to print at low speed (40mm/s and 25mm/s for small perimeters).
For a smooth finish and a tight fit, prefer 0.1mm layer height, but 0.2mm should do the work.
About the infill : As the A and C parts are pretty flat and large, you may want to keep a high density (75-100%). However B part infill can be reduced to 50%, but keep in mind that this piece will need to be strong and a bit flexible (mine was printed at 100% PLA, it's quite strong but not very flexible).
Heated bed is recommended for PLA to avoid wrapping issues.
Printing time (0.1mm - 40mm/s - 75%) : A part : 2h30 B part : 15min C part : 2h15
Standard version diameter : 10cm.
Small version : 7cm.
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Jewelry Challenge
      Jewelry Challenge
    26 Discussions
    revmatthews
    2 years ago
    Question: Could I take an old-fashioned yo-yo, modify it with plastic nuts/bolts, and get a retro version of your design?
    One of my rainy day hobbies is archiving this site's best of the best. This will be one of them. Thanks!
    Kayfixrevmatthews
    Reply 2 years ago
    Well, first of all thanks for your interest in this project !
    Second: you could/should ! totally do that ! And if you do, take pictures ! You can even make an instructable of it for those who don't own a 3d printer and do have a yo-yo
    If you want some extras pictures/measures just contact me.
    Samuel88288Samuel88288
    Reply 2 years ago
    I couldn't figure out a good way to get both pieces to stay together so it wouldnt fall apart though.
    KayfixSamuel88288
    Reply 2 years ago
    It seems a bit more complex !
    This is the most trickiest problem I had to solve in my design, I tried different systems before I found the more reliable. It ain't perfect though.
    Samuel88288Kayfix
    Reply 2 years ago
    Is there anything holding the pieces together in your design?
    KayfixSamuel88288
    Reply 2 years ago
    Part A holds part B and part B holds part C, all by a simple horizontal snap-fit system (see assembly video on step 6).
    Meerkat Lover
    2 years ago
    In response to using this for power cables. I don't know the technical jargon, but believe that power cables that are in use are not to be rolled up as it creates the tendency to overheat and electromagnetic field something or other.
    Buonarotti
    2 years ago
    This is cool.
    I bet you can scale this device up to help with cable management for power cords and other parts of the under-desk computer environment mess.
    What do you think?
    KayfixBuonarotti
    Reply 2 years ago
    Hi, I didn't try with power cords or even display cables, but I assume they are a bit stiff to be rolled in this design.
    It's particularly hepful with headset cables, mouse, keyboard, USB etc.
    However I can easily scale it up.
    ddj0195
    2 years ago
    Nice! But what keeps part A and part C held together? Maybe a couple exta pictures shoing the underside of part C would clarify this for me. We have a 3D printer at our library. I can't wait to print one of these for controlling excess wire lenghts.
    Kayfixddj0195
    Reply 2 years ago
    You're right ! This is not represented, I'll try to add a sketch of it.
    It's actually a snap-fit system just like part B clips with part A.
    Here, part C is basically a part A with just one central pivot that you'll need to slide into part B (which has a central hole).
    All pivots are enlarged on top to block the parts together.
    I shall do a quick tutorial video.
    Hope it's a bit clearer for you !
    Thanks for your enthousiasm
    ddj0195Kayfix
    Reply 2 years ago
    The additional photographs are excellent. thank you.
    Kayfixddj0195
    Reply 2 years ago
    There's a quick video recap on step 6 now
    caffewmilk
    2 years ago
    Very nice project. Perhaps a video of you putting it together and demonstrating its use would also help. Thanks for sharing.
    Kayfixcaffewmilk
    Reply 2 years ago
    Thanks!
    Indeed I'll try to make a quick tutorial video as soon as possible.
    Clutterfree
    2 years ago
    Wow, boy could I usee this! Where do I find the actual cable eater? Thank you
    KayfixClutterfree
    Reply 2 years ago
    Hello!
    Well, everywhere there's a 3D printer, there is a potential cable eater =)
    But the original cable eater is blue, and I keep it at my place :p
    Feel free to contact me privately if you want me to print it for you. For now, have no idea about the cost though (+shipping from France).
    Best regards.
    ClutterfreeKayfix
    Reply 2 years ago
    Thank you but I have no idea what or how a 3D printer works. Guess I' just behind the times.
    I love France and been there a couple of times. Great food!.
    Have a great day!
    Karen
    ethanpnorton
    2 years ago
    Great design. I am adding this to my 3D printing list!
